Status of smptests ...?
Jiri Gaisler jiri at gaisler.se
Tue Dec 11 15:55:02 UTC 2018
On 12/11/18 3:47 PM, Sebastian Huber wrote:
> On 11/12/2018 15:42, Jiri Gaisler wrote:
>> On 12/11/18 3:24 PM, Sebastian Huber wrote:
>>> Hello Jiri,
>>> On 11/12/2018 15:15, Jiri Gaisler wrote:
>>>> What is the status of the smptests of RTEMS 5 ?
>>>> I have added SMP capability to the sis simulator, and have tested it
>>>> with the smptests from rtems git. I have noticed that the reference
>>>> output (*.scn) are not equivalent to what the simulator or real
>>>> hardware
>>>> outputs. It seems that the cpus are numbered backwards compared to the
>>>> .scn files.
>>> the .scn files are not up to date. Also the test output is quite test
>>> dependent and repeated test runs my produce different output.
>>> The best method to check if a test passed is to check if the
>>> *** END OF TEST XYZ ***
>>> message is printed. Which real target did you use to run the tests? I
>>> will do a test run tomorrow on a N2X.
>> My hardware setup is a Pender XC6S FPGA board with a 4-core leon3 design
>> compiled from the latest public leon3/grlib VHDL sources. The hardware
>> does not have an FPU at the moment which might be why some tests are
>> failing - I will investigate...
> With this you should get rid of the FPU usage:
>  diff --git a/bsps/sparc/leon3/config/leon3.cfg
> b/bsps/sparc/leon3/config/leon3.cfg
> index d931d6c5f1..e3eca059ec 100644
> --- a/bsps/sparc/leon3/config/leon3.cfg
> +++ b/bsps/sparc/leon3/config/leon3.cfg
> @@ -8,7 +8,7 @@ RTEMS_CPU=sparc
>  #  This contains the compiler options necessary to select the CPU model
>  #  and (hopefully) optimize for it.
> -CPU_CFLAGS = -mcpu=leon3
> +CPU_CFLAGS = -mcpu=leon3 -msoft-float
>  # optimize flag: typically -O2
>  CFLAGS_OPTIMIZE_V = -O2 -g
Thanks for reminding me - this did the trick. I will run all tests and
compare with your log.
