[PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for net/if.h
Jacob Shin jacobshin313 at gmail.com
Wed Dec 12 00:30:07 UTC 2018
 testsuites/psxtests/Makefile.am                    |  6 ++-
 .../psxtests/psxhdrs/net/if/if_freenameindex.c     | 47 +++++++++++++++++++++
 .../psxtests/psxhdrs/net/if/if_indextoname.c       | 49 ++++++++++++++++++++++
 testsuites/psxtests/psxhdrs/net/if/if_nameindex.c  | 47 +++++++++++++++++++++
 .../psxtests/psxhdrs/net/if/if_nametoindex.c       | 48 +++++++++++++++++++++
 5 files changed, 196 insertions(+), 1 deletion(-)
 create mode 100755 testsuites/psxtests/psxhdrs/net/if/if_freenameindex.c
 create mode 100755 testsuites/psxtests/psxhdrs/net/if/if_indextoname.c
 create mode 100755 testsuites/psxtests/psxhdrs/net/if/if_nameindex.c
 create mode 100755 testsuites/psxtests/psxhdrs/net/if/if_nametoindex.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index a2b04caf33..3f64ebca32 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1809,7 +1809,11 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
 	psxhdrs/stdlib/wcstombs.c \
 	psxhdrs/stdlib/wctomb.c \
 	psxhdrs/sys/times/times.c \
-	psxhdrs/sys/resource/getrusage.c
+	psxhdrs/sys/resource/getrusage.c \
+	psxhdrs/net/if/if_freenameindex.c \
+	psxhdrs/net/if/if_indextoname.c \
+	psxhdrs/net/if/if_nameindex.c \
+	psxhdrs/net/if/if_nametoindex.c
 ## Not supported by RTEMS, but POSIX API Compliance tests exist.
 ## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
diff --git a/testsuites/psxtests/psxhdrs/net/if/if_freenameindex.c b/testsuites/psxtests/psxhdrs/net/if/if_freenameindex.c
new file mode 100755
index 0000000000..e1792e1f80
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/net/if/if_freenameindex.c
@@ -0,0 +1,47 @@
+ *  @file
+ *  @brief if_freenameindex() API Conformance Test
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018 Jacob Shin
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <net/if.h>
+int test( void );
+int test( void )
+	struct if_nameindex *ptr = if_nameindex();
+	if_freenameindex(ptr);
+	return 1;
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/net/if/if_indextoname.c b/testsuites/psxtests/psxhdrs/net/if/if_indextoname.c
index 0000000000..0004d5426b
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/net/if/if_indextoname.c
@@ -0,0 +1,49 @@
+ *  @file
+ *  @brief if_indextoname() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+	char *return_value;
+	unsigned ifindex = 1;
+	char ifname[IF_NAMESIZE];
+	return_value = if_indextoname(ifindex, ifname);
+	return (return_value != NULL);
diff --git a/testsuites/psxtests/psxhdrs/net/if/if_nameindex.c b/testsuites/psxtests/psxhdrs/net/if/if_nameindex.c
index 0000000000..f8a71d24a9
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/net/if/if_nameindex.c
@@ -0,0 +1,47 @@
+ *  @file
+ *  @brief if_nameindex() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+	struct if_nameindex *return_value;
+	return_value = if_nameindex();
diff --git a/testsuites/psxtests/psxhdrs/net/if/if_nametoindex.c b/testsuites/psxtests/psxhdrs/net/if/if_nametoindex.c
index 0000000000..f2ab5075bb
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/net/if/if_nametoindex.c
@@ -0,0 +1,48 @@
+ *  @file
+ *  @brief if_nametoindex() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+	unsigned return_value;
+	char *ifname = "test";
+	return_value = if_nametoindex(ifname);
+	return (return_value != 0);
2.11.0
