POSIX Signature Test for nl_type.h (GCI2018)
Abhimanyu Raghuvanshi abhimanyuraghuvanshi29 at gmail.com
Wed Dec 12 08:25:05 UTC 2018
Attaching the patch file
>From 3fad278aa27a0ebbd584e4ae9eb6ab0a0d498c00 Mon Sep 17 00:00:00 2001
From: ABR290B <abhimanyuraghuvanshi29 at gmail.com>
Date: Wed, 12 Dec 2018 13:53:05 +0530
Subject: [PATCH] POSIX Signature Test for nl_types.h (GCI2018)
 testsuites/psxtests/Makefile.am               |  5 ++-
 .../psxtests/psxhdrs/nl_types/catclose.c      | 36 +++++++++++++++++++
 .../psxtests/psxhdrs/nl_types/catgets.c       | 36 +++++++++++++++++++
 .../psxtests/psxhdrs/nl_types/catopen.c       | 35 ++++++++++++++++++
 4 files changed, 111 insertions(+), 1 deletion(-)
 create mode 100644 testsuites/psxtests/psxhdrs/nl_types/catclose.c
 create mode 100644 testsuites/psxtests/psxhdrs/nl_types/catgets.c
 create mode 100644 testsuites/psxtests/psxhdrs/nl_types/catopen.c
diff --git a/testsuites/psxtests/Makefile.am
b/testsuites/psxtests/Makefile.am
index 3dd8fe0139..9cff5084bb 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1815,7 +1815,10 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
  psxhdrs/setjmp/longjmp.c \
  psxhdrs/setjmp/setjmp.c \
  psxhdrs/setjmp/siglongjmp.c \
- psxhdrs/setjmp/sigsetjmp.c
+ psxhdrs/setjmp/sigsetjmp.c \
+ psxhdrs/nl_types/catclose.c \
+ psxhdrs/nl_types/catopen.c \
+ psxhdrs/nl_types/catgets.c
 ## Not supported by RTEMS, but POSIX API Compliance tests exist.
 ## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
diff --git a/testsuites/psxtests/psxhdrs/nl_types/catclose.c
b/testsuites/psxtests/psxhdrs/nl_types/catclose.c
new file mode 100644
index 0000000000..1e09fd46d0
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/nl_types/catclose.c
@@ -0,0 +1,36 @@
+ *  @file
+ *  @brief catclose() API Conformance Test
+ *  COPYRIGHT (c) 2018.
+ *  Abhimanyu Raghuvanshi
+ *  Permission to use, copy, modify, and/or distribute this software
+ *  for any purpose with or without fee is hereby granted.
+ *  THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
+ *  WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
+ *  WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
+ *  BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
+ *  OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
+ *  WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
+ *  ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
SOFTWARE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <nl_types.h>
+int test(void);
+int test(void)
+  nl_catd a;
+  catclose(a);
+  return 0;
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/nl_types/catgets.c
b/testsuites/psxtests/psxhdrs/nl_types/catgets.c
index 0000000000..e9ff8bef40
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/nl_types/catgets.c
@@ -0,0 +1,36 @@
+ *  @file
+ *  @brief catgets() API Conformance Test
SOFTWARE.
+#endif
+int test(void);
+int test(void)
+  nl_catd a = 0;
+  char *b = catgets(a, NL_SETD, 1, "/path/to/file");
+  return b != 0;
diff --git a/testsuites/psxtests/psxhdrs/nl_types/catopen.c
b/testsuites/psxtests/psxhdrs/nl_types/catopen.c
index 0000000000..637f100267
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/nl_types/catopen.c
@@ -0,0 +1,35 @@
+ *  @file
+ *  @brief catopen() API Conformance Test
SOFTWARE.
+#endif
+int test(void);
+int test(void)
+  nl_catd msg_file = catopen("/path/to/file", 0);
+  return msg_file != (nl_catd) -1;
2.19.1.windows.1
ABR
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181212/6813d127/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181212/6813d127/attachment.obj>
