SIS MP success
Jiri Gaisler
jiri at gaisler.se
Wed Dec 12 09:01:57 UTC 2018
After implementing the interrupt broadcast function, and stop telling
the software that there are 5 cores in the system when there really only
are 4, all tests run fine ..:-) I can run all SMP tests with a time slot
of 50 clocks except smpclock01.exe, which fails with:
*** BEGIN OF TEST SMPCLOCK 1 ***
*** TEST VERSION: 5.0.0.b7a1f9efadd928cda0f56123a1b6245b30b076fc-modified
*** TEST STATE: EXPECTED-PASS
*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB
b4e80fb8e29c47fa970b5cdb815c26f1af4fd173, Newlib
2ab57ad59bc35dafffa69cd4da5e228971de069f)
../../../../../../rtems/c/src/../../testsuites/smptests/smpclock01/init.c:
117 cpu_self->Watchdog.ticks == ticks + 1
IU in error mode (128)
12095340 40012200 91d02000 ta 0
sis> q
Lowering the time slot to 15 clocks fixes this error and the test passes.
I will clean up my sources, and work a bit on improving breakpoint
handling and tracing. The MP function broke erc32 and leon2 support, so
I will fix that too. After that I can post a patch if anyone is
interested. Threaded simulation could come after that ...
Jiri.
