POSIX Signature Test for utmpx.h (GCI2018)
Abhimanyu Raghuvanshi
abhimanyuraghuvanshi29 at gmail.com
Wed Dec 12 14:25:21 UTC 2018
Patch Attached
>From 855ee6828d3ee171df52308e399749fc9bee42ed Mon Sep 17 00:00:00 2001
From: ABR290B <abhimanyuraghuvanshi29 at gmail.com>
Date: Wed, 12 Dec 2018 19:53:35 +0530
Subject: [PATCH] POSIX Signature Test for utmpx.h (GCI2018)
testsuites/psxtests/Makefile.am | 9 ++++-
testsuites/psxtests/psxhdrs/utmpx/endutxent.c | 34 ++++++++++++++++++
testsuites/psxtests/psxhdrs/utmpx/getutxent.c | 34 ++++++++++++++++++
testsuites/psxtests/psxhdrs/utmpx/getutxid.c | 35 +++++++++++++++++++
.../psxtests/psxhdrs/utmpx/getutxline.c | 35 +++++++++++++++++++
.../psxtests/psxhdrs/utmpx/pututxline.c | 35 +++++++++++++++++++
testsuites/psxtests/psxhdrs/utmpx/setutxent.c | 34 ++++++++++++++++++
7 files changed, 215 insertions(+), 1 deletion(-)
create mode 100644 testsuites/psxtests/psxhdrs/utmpx/endutxent.c
create mode 100644 testsuites/psxtests/psxhdrs/utmpx/getutxent.c
create mode 100644 testsuites/psxtests/psxhdrs/utmpx/getutxid.c
create mode 100644 testsuites/psxtests/psxhdrs/utmpx/getutxline.c
create mode 100644 testsuites/psxtests/psxhdrs/utmpx/pututxline.c
create mode 100644 testsuites/psxtests/psxhdrs/utmpx/setutxent.c
diff --git a/testsuites/psxtests/Makefile.am
b/testsuites/psxtests/Makefile.am
index 3dd8fe0139..5062857855 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1815,7 +1815,14 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
psxhdrs/setjmp/longjmp.c \
psxhdrs/setjmp/setjmp.c \
psxhdrs/setjmp/siglongjmp.c \
- psxhdrs/setjmp/sigsetjmp.c
+ psxhdrs/setjmp/sigsetjmp.c \
+ psxhdrs/utmpx/setutxent.c \
+ psxhdrs/utmpx/endutxent.c \
+ psxhdrs/utmpx/getutxent.c \
+ psxhdrs/utmpx/getutxid.c \
+ psxhdrs/utmpx/getutxline.c \
+ psxhdrs/utmpx/pututxline.c
## Not supported by RTEMS, but POSIX API Compliance tests exist.
## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
diff --git a/testsuites/psxtests/psxhdrs/utmpx/endutxent.c
b/testsuites/psxtests/psxhdrs/utmpx/endutxent.c
new file mode 100644
index 0000000000..9dd54bccda
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/utmpx/endutxent.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief endutxent() API Conformance Test
+ * COPYRIGHT (c) 2018.
+ * Abhimanyu Raghuvanshi
+ * Permission to use, copy, modify, and/or distribute this software
+ * for any purpose with or without fee is hereby granted.
+ * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
+ * WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
+ * BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
+ * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
+ * WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
+ * ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
SOFTWARE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <utmpx.h>
+int test(void);
+int test(void)
+ endutxent();
+ return (0);
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/utmpx/getutxent.c
b/testsuites/psxtests/psxhdrs/utmpx/getutxent.c
index 0000000000..25a80c4810
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/utmpx/getutxent.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief getutxent() API Conformance Test
SOFTWARE.
+#endif
+#include <utmpx.h>
+int test(void);
+int test(void)
+ struct utmpx *a = getutxent();
+ return !a;
diff --git a/testsuites/psxtests/psxhdrs/utmpx/getutxid.c
b/testsuites/psxtests/psxhdrs/utmpx/getutxid.c
index 0000000000..60fd67008c
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/utmpx/getutxid.c
@@ -0,0 +1,35 @@
+ * @file
+ * @brief getutxid() API Conformance Test
SOFTWARE.
+#endif
+#include <utmpx.h>
+int test(void);
+int test(void)
+ const struct utmpx b = {0};
+ struct utmpx *a = getutxid(&b);
+ return !a;
diff --git a/testsuites/psxtests/psxhdrs/utmpx/getutxline.c
b/testsuites/psxtests/psxhdrs/utmpx/getutxline.c
index 0000000000..11e17f06b3
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/utmpx/getutxline.c
@@ -0,0 +1,35 @@
+ * @file
+ * @brief getutxline() API Conformance Test
SOFTWARE.
+#endif
+#include <utmpx.h>
+int test(void);
+int test(void)
+ struct utmpx *a = getutxline(&b);
+ return !a;
diff --git a/testsuites/psxtests/psxhdrs/utmpx/pututxline.c
b/testsuites/psxtests/psxhdrs/utmpx/pututxline.c
index 0000000000..7613dc8e36
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/utmpx/pututxline.c
@@ -0,0 +1,35 @@
+ * @file
+ * @brief pututxline() API Conformance Test
SOFTWARE.
+#endif
+#include <utmpx.h>
+int test(void);
+int test(void)
+ struct utmpx *a = pututxline(&b);
+ return !a;
diff --git a/testsuites/psxtests/psxhdrs/utmpx/setutxent.c
b/testsuites/psxtests/psxhdrs/utmpx/setutxent.c
index 0000000000..6665aff7fc
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/utmpx/setutxent.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief setutxent() API Conformance Test
SOFTWARE.
+#endif
+#include <utmpx.h>
+int test(void);
+int test(void)
+ setutxent();
+ return (0);
2.19.1.windows.1
ABR
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181212/3c5b8f88/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181212/3c5b8f88/attachment-0001.obj>
