[PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for sys/select.h
Jacob Shin
jacobshin313 at gmail.com
Thu Dec 13 00:46:38 UTC 2018
The Google Code-In finished before I could submit this, so I thought I would submit this instead of letting it go to waste.
testsuites/psxtests/Makefile.am | 8 +++-
testsuites/psxtests/psxhdrs/sys/select/FD_CLR.c | 48 ++++++++++++++++++++
testsuites/psxtests/psxhdrs/sys/select/FD_ISSET.c | 49 +++++++++++++++++++++
testsuites/psxtests/psxhdrs/sys/select/FD_SET.c | 48 ++++++++++++++++++++
testsuites/psxtests/psxhdrs/sys/select/FD_ZERO.c | 47 ++++++++++++++++++++
testsuites/psxtests/psxhdrs/sys/select/pselect.c | 53 +++++++++++++++++++++++
testsuites/psxtests/psxhdrs/sys/select/select.c | 52 ++++++++++++++++++++++
7 files changed, 304 insertions(+), 1 deletion(-)
create mode 100755 testsuites/psxtests/psxhdrs/sys/select/FD_CLR.c
create mode 100755 testsuites/psxtests/psxhdrs/sys/select/FD_ISSET.c
create mode 100755 testsuites/psxtests/psxhdrs/sys/select/FD_SET.c
create mode 100755 testsuites/psxtests/psxhdrs/sys/select/FD_ZERO.c
create mode 100755 testsuites/psxtests/psxhdrs/sys/select/pselect.c
create mode 100755 testsuites/psxtests/psxhdrs/sys/select/select.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1ce9b20d67..e3bde2f64d 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1819,7 +1819,13 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
psxhdrs/setjmp/longjmp.c \
psxhdrs/setjmp/setjmp.c \
psxhdrs/setjmp/siglongjmp.c \
- psxhdrs/setjmp/sigsetjmp.c
+ psxhdrs/setjmp/sigsetjmp.c \
+ psxhdrs/sys/select/FD_CLR.c \
+ psxhdrs/sys/select/FD_ISSET.c \
+ psxhdrs/sys/select/FD_SET.c \
+ psxhdrs/sys/select/FD_ZERO.c \
+ psxhdrs/sys/pselect.c \
+ psxhdrs/sys/select.c
## Not supported by RTEMS, but POSIX API Compliance tests exist.
## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
diff --git a/testsuites/psxtests/psxhdrs/sys/select/FD_CLR.c b/testsuites/psxtests/psxhdrs/sys/select/FD_CLR.c
new file mode 100755
index 0000000000..b165e9159e
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/select/FD_CLR.c
@@ -0,0 +1,48 @@
+ * @file
+ * @brief FD_CLR() API Conformance Test
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018 Jacob Shin
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/select.h>
+int test( void );
+int test( void )
+ int fd = 1;
+ fd_set fdset;
+ FD_CLR(fd, &fdset);
+ return 1;
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/sys/select/FD_ISSET.c b/testsuites/psxtests/psxhdrs/sys/select/FD_ISSET.c
index 0000000000..0b3190b817
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/select/FD_ISSET.c
@@ -0,0 +1,49 @@
+ * @file
+ * @brief FD_ISSET() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int return_value;
+ int fd = 1;
+ fd_set fdset;
+ return_value = FD_ISSET(fd, &fdset);
+ return return_value;
diff --git a/testsuites/psxtests/psxhdrs/sys/select/FD_SET.c b/testsuites/psxtests/psxhdrs/sys/select/FD_SET.c
index 0000000000..0de0b346fa
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/select/FD_SET.c
@@ -0,0 +1,48 @@
+ * @file
+ * @brief FD_SET() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int fd = 1;
+ fd_set fdset;
+ FD_SET(fd, &fdset);
+ return 1;
diff --git a/testsuites/psxtests/psxhdrs/sys/select/FD_ZERO.c b/testsuites/psxtests/psxhdrs/sys/select/FD_ZERO.c
index 0000000000..d39d9e78c4
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/select/FD_ZERO.c
@@ -0,0 +1,47 @@
+ * @file
+ * @brief FD_ZERO() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ fd_set fdset;
+ FD_ZERO(&fdset);
+ return 1;
diff --git a/testsuites/psxtests/psxhdrs/sys/select/pselect.c b/testsuites/psxtests/psxhdrs/sys/select/pselect.c
index 0000000000..1b2922528e
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/select/pselect.c
@@ -0,0 +1,53 @@
+ * @file
+ * @brief pselect() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int return_value;
+ int nfds = 1;
+ fd_set readfds;
+ fd_set writefds;
+ fd_set errorfds;
+ struct timespec timeout;
+ sigset_t sigmask;
+ return_value = pselect(nfds, &readfds, &writefds, &errorfds, &timeout, &sigmask);
diff --git a/testsuites/psxtests/psxhdrs/sys/select/select.c b/testsuites/psxtests/psxhdrs/sys/select/select.c
index 0000000000..12fc927404
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/select/select.c
@@ -0,0 +1,52 @@
+ * @file
+ * @brief select() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int return_value;
+ int nfds = 1;
+ fd_set readfds;
+ fd_set writefds;
+ fd_set errorfds;
+ struct timeval timeout;
+ return_value = select(nfds, &readfds, &writefds, &errorfds, &timeout);
2.11.0
