[PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for sys/msg.h
Jacob Shin
jacobshin313 at gmail.com
Thu Dec 13 01:04:05 UTC 2018
The Google Code-In finished before I could submit this, so I thought I would submit this instead of letting it go to waste.
testsuites/psxtests/Makefile.am | 4 ++
testsuites/psxtests/psxhdrs/sys/msg/msgctl.c | 51 ++++++++++++++++++++++++
testsuites/psxtests/psxhdrs/sys/msg/msgget.c | 50 ++++++++++++++++++++++++
testsuites/psxtests/psxhdrs/sys/msg/msgrcv.c | 56 +++++++++++++++++++++++++++
testsuites/psxtests/psxhdrs/sys/msg/msgsnd.c | 58 ++++++++++++++++++++++++++++
5 files changed, 219 insertions(+)
create mode 100755 testsuites/psxtests/psxhdrs/sys/msg/msgctl.c
create mode 100755 testsuites/psxtests/psxhdrs/sys/msg/msgget.c
create mode 100755 testsuites/psxtests/psxhdrs/sys/msg/msgrcv.c
create mode 100755 testsuites/psxtests/psxhdrs/sys/msg/msgsnd.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1ce9b20d67..46d2c33d8e 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1869,6 +1869,10 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
## lib_a_SOURCES += psxhdrs/sys/resource/getrlimit.c See ticket #3653
## lib_a_SOURCES += psxhdrs/sys/resource/setpriority.c See ticket #3654
## lib_a_SOURCES += psxhdrs/sys/resource/setrlimit.c See ticket #3655
+## lib_a_SOURCES += psxhdrs/sys/msg/msgctl.c See ticket #3658
+## lib_a_SOURCES += psxhdrs/sys/msg/msgget.c See ticket #3658
+## lib_a_SOURCES += psxhdrs/sys/msg/msgrcv.c See ticket #3658
+## lib_a_SOURCES += psxhdrs/sys/msg/msgsnd.c See ticket #3658
endif
rtems_tests_PROGRAMS = $(psx_tests)
diff --git a/testsuites/psxtests/psxhdrs/sys/msg/msgctl.c b/testsuites/psxtests/psxhdrs/sys/msg/msgctl.c
new file mode 100755
index 0000000000..df914a866e
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/msg/msgctl.c
@@ -0,0 +1,51 @@
+ * @file
+ * @brief msgctl() API Conformance Test
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018 Jacob Shin
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define _XOPEN_SOURCE
+#include <sys/msg.h>
+int test( void );
+int test( void )
+ int return_value;
+ int msqid = msgget(IPC_PRIVATE, IPC_CREAT | 0660);
+ int cmd = IPC_STAT;
+ struct msqid_ds buf;
+ return_value = msgctl(msqid, cmd, &buf);
+ return (return_value != -1);
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/sys/msg/msgget.c b/testsuites/psxtests/psxhdrs/sys/msg/msgget.c
index 0000000000..9881fe23f7
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/msg/msgget.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief msgget() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int return_value;
+ key_t key = IPC_PRIVATE;
+ int msgflg = IPC_CREAT | 0660;
+ return_value = msgget(key, msgflg);
diff --git a/testsuites/psxtests/psxhdrs/sys/msg/msgrcv.c b/testsuites/psxtests/psxhdrs/sys/msg/msgrcv.c
index 0000000000..960c4e7ad0
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/msg/msgrcv.c
@@ -0,0 +1,56 @@
+ * @file
+ * @brief msgrcv() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int return_value;
+ struct mymsg {
+ long mtype;
+ char mtext[2];
+ struct mymsg msgp;
+ size_t msgsz = 1;
+ long msgtyp = 0;
+ int msgflg = IPC_NOWAIT;
+ return_value = msgrcv(msqid, &msgp, msgsz, msgtyp, msgflg);
diff --git a/testsuites/psxtests/psxhdrs/sys/msg/msgsnd.c b/testsuites/psxtests/psxhdrs/sys/msg/msgsnd.c
index 0000000000..71f6ae8bb9
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/msg/msgsnd.c
@@ -0,0 +1,58 @@
+ * @file
+ * @brief msgsnd() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int return_value;
+ struct mymsg {
+ long mtype;
+ char mtext[2];
+ msgp.mtype = 1;
+ msgp.mtext[0] = 'c';
+ msgp.mtext[1] = '\0';
+ size_t msgsz = 1;
+ return_value = msgsnd(msqid, &msgp, msgsz, msgflg);
2.11.0
