[PATCH] test-template: Change license to BSD-2-Clause
Sebastian Huber
Thu Dec 13 07:15:18 UTC 2018
rtems-test-template/psxtest/TEST.doc | 34 +++++++++++++--------
rtems-test-template/psxtest/init.c | 35 ++++++++++++++--------
rtems-test-template/psxtest_with_thread/TEST.doc | 34 +++++++++++++--------
rtems-test-template/psxtest_with_thread/init.c | 35 ++++++++++++++--------
rtems-test-template/psxtmtest_blocking/TEST.doc | 34 +++++++++++++--------
rtems-test-template/psxtmtest_blocking/init.c | 35 ++++++++++++++--------
.../psxtmtest_init_destroy/TEST.doc | 34 +++++++++++++--------
rtems-test-template/psxtmtest_init_destroy/init.c | 35 ++++++++++++++--------
rtems-test-template/psxtmtest_single/TEST.doc | 34 +++++++++++++--------
rtems-test-template/psxtmtest_single/init.c | 35 ++++++++++++++--------
.../psxtmtest_unblocking_nopreempt/TEST.doc | 34 +++++++++++++--------
.../psxtmtest_unblocking_nopreempt/init.c | 35 ++++++++++++++--------
.../psxtmtest_unblocking_preempt/TEST.doc | 34 +++++++++++++--------
.../psxtmtest_unblocking_preempt/init.c | 35 ++++++++++++++--------
rtems-test-template/smptest/TEST.doc | 34 +++++++++++++--------
rtems-test-template/smptest/init.c | 35 ++++++++++++++--------
rtems-test-template/spfatal/TEST.doc | 34 +++++++++++++--------
rtems-test-template/spfatal/testcase.h | 35 ++++++++++++++--------
rtems-test-template/sptest/TEST.doc | 34 +++++++++++++--------
rtems-test-template/sptest/init.c | 35 ++++++++++++++--------
.../sptest_operation_from_tsr/TEST.doc | 34 +++++++++++++--------
.../sptest_operation_from_tsr/init.c | 35 ++++++++++++++--------
rtems-test-template/sptest_with_task/TEST.doc | 34 +++++++++++++--------
rtems-test-template/sptest_with_task/init.c | 35 ++++++++++++++--------
rtems-test-template/tmtest/TEST.doc | 34 +++++++++++++--------
rtems-test-template/tmtest/init.c | 35 ++++++++++++++--------
26 files changed, 585 insertions(+), 312 deletions(-)
diff --git a/rtems-test-template/psxtest/TEST.doc b/rtems-test-template/psxtest/TEST.doc
index 0870f93..784a5fb 100644
--- a/rtems-test-template/psxtest/TEST.doc
+++ b/rtems-test-template/psxtest/TEST.doc
@@ -1,17 +1,27 @@
-# COPYRIGHT (c) <YYYY>.
-# <author goes here>
+# SPDX-License-Identifier: BSD-2-Clause
-# Permission to use, copy, modify, and/or distribute this software
-# for any purpose with or without fee is hereby granted.
-# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
-# WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
-# WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
-# BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
-# OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
-# WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
-# ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+# Copyright (C) <FIRST YEAR>, <LAST YEAR> <COPYRIGHT HOLDER>
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
This file describes the directives and concepts tested by this test set.
diff --git a/rtems-test-template/psxtest/init.c b/rtems-test-template/psxtest/init.c
index 077d27b..69b4657 100644
--- a/rtems-test-template/psxtest/init.c
+++ b/rtems-test-template/psxtest/init.c
@@ -1,17 +1,28 @@
- * COPYRIGHT (c) <YYYY>.
- * <author goes here>
+ * SPDX-License-Identifier: BSD-2-Clause
- * Permission to use, copy, modify, and/or distribute this software
- * for any purpose with or without fee is hereby granted.
- * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
- * WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
- * WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
- * BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
- * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
- * WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
- * ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+ * Copyright (C) <FIRST YEAR>, <LAST YEAR> <COPYRIGHT HOLDER>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include "test_support.h"
diff --git a/rtems-test-template/psxtest_with_thread/TEST.doc b/rtems-test-template/psxtest_with_thread/TEST.doc
--- a/rtems-test-template/psxtest_with_thread/TEST.doc
+++ b/rtems-test-template/psxtest_with_thread/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/psxtest_with_thread/init.c b/rtems-test-template/psxtest_with_thread/init.c
index b2d6e93..3f9dab7 100644
--- a/rtems-test-template/psxtest_with_thread/init.c
+++ b/rtems-test-template/psxtest_with_thread/init.c
@@ -1,17 +1,28 @@
+ * are met:
diff --git a/rtems-test-template/psxtmtest_blocking/TEST.doc b/rtems-test-template/psxtmtest_blocking/TEST.doc
index 96c278f..e9e9efd 100644
--- a/rtems-test-template/psxtmtest_blocking/TEST.doc
+++ b/rtems-test-template/psxtmtest_blocking/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
This test benchmarks the following operations:
diff --git a/rtems-test-template/psxtmtest_blocking/init.c b/rtems-test-template/psxtmtest_blocking/init.c
index abef9f2..041023d 100644
--- a/rtems-test-template/psxtmtest_blocking/init.c
+++ b/rtems-test-template/psxtmtest_blocking/init.c
@@ -1,17 +1,28 @@
+ * are met:
#ifdef HAVE_CONFIG_H
diff --git a/rtems-test-template/psxtmtest_init_destroy/TEST.doc b/rtems-test-template/psxtmtest_init_destroy/TEST.doc
index bf8741c..871e345 100644
--- a/rtems-test-template/psxtmtest_init_destroy/TEST.doc
+++ b/rtems-test-template/psxtmtest_init_destroy/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/psxtmtest_init_destroy/init.c b/rtems-test-template/psxtmtest_init_destroy/init.c
index f8f1470..cd3513c 100644
--- a/rtems-test-template/psxtmtest_init_destroy/init.c
+++ b/rtems-test-template/psxtmtest_init_destroy/init.c
@@ -1,17 +1,28 @@
+ * are met:
diff --git a/rtems-test-template/psxtmtest_single/TEST.doc b/rtems-test-template/psxtmtest_single/TEST.doc
--- a/rtems-test-template/psxtmtest_single/TEST.doc
+++ b/rtems-test-template/psxtmtest_single/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/psxtmtest_single/init.c b/rtems-test-template/psxtmtest_single/init.c
index 04dceee..6f1c3eb 100644
--- a/rtems-test-template/psxtmtest_single/init.c
+++ b/rtems-test-template/psxtmtest_single/init.c
@@ -1,17 +1,28 @@
+ * are met:
diff --git a/rtems-test-template/psxtmtest_unblocking_nopreempt/TEST.doc b/rtems-test-template/psxtmtest_unblocking_nopreempt/TEST.doc
--- a/rtems-test-template/psxtmtest_unblocking_nopreempt/TEST.doc
+++ b/rtems-test-template/psxtmtest_unblocking_nopreempt/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/psxtmtest_unblocking_nopreempt/init.c b/rtems-test-template/psxtmtest_unblocking_nopreempt/init.c
index ee03db2..ae449e4 100644
--- a/rtems-test-template/psxtmtest_unblocking_nopreempt/init.c
+++ b/rtems-test-template/psxtmtest_unblocking_nopreempt/init.c
@@ -1,17 +1,28 @@
+ * are met:
diff --git a/rtems-test-template/psxtmtest_unblocking_preempt/TEST.doc b/rtems-test-template/psxtmtest_unblocking_preempt/TEST.doc
--- a/rtems-test-template/psxtmtest_unblocking_preempt/TEST.doc
+++ b/rtems-test-template/psxtmtest_unblocking_preempt/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/psxtmtest_unblocking_preempt/init.c b/rtems-test-template/psxtmtest_unblocking_preempt/init.c
index c865d80..1c14df3 100644
--- a/rtems-test-template/psxtmtest_unblocking_preempt/init.c
+++ b/rtems-test-template/psxtmtest_unblocking_preempt/init.c
@@ -1,17 +1,28 @@
+ * are met:
diff --git a/rtems-test-template/smptest/TEST.doc b/rtems-test-template/smptest/TEST.doc
--- a/rtems-test-template/smptest/TEST.doc
+++ b/rtems-test-template/smptest/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/smptest/init.c b/rtems-test-template/smptest/init.c
index 5a47906..dcdb2bc 100644
--- a/rtems-test-template/smptest/init.c
+++ b/rtems-test-template/smptest/init.c
@@ -1,17 +1,28 @@
+ * are met:
diff --git a/rtems-test-template/spfatal/TEST.doc b/rtems-test-template/spfatal/TEST.doc
--- a/rtems-test-template/spfatal/TEST.doc
+++ b/rtems-test-template/spfatal/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/spfatal/testcase.h b/rtems-test-template/spfatal/testcase.h
index 7764d81..4a3107e 100644
--- a/rtems-test-template/spfatal/testcase.h
+++ b/rtems-test-template/spfatal/testcase.h
@@ -1,17 +1,28 @@
+ * are met:
/* XXX these will have to be tailored */
diff --git a/rtems-test-template/sptest/TEST.doc b/rtems-test-template/sptest/TEST.doc
--- a/rtems-test-template/sptest/TEST.doc
+++ b/rtems-test-template/sptest/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/sptest/init.c b/rtems-test-template/sptest/init.c
index aca3c01..1bca7b7 100644
--- a/rtems-test-template/sptest/init.c
+++ b/rtems-test-template/sptest/init.c
@@ -1,17 +1,28 @@
+ * are met:
#include <tmacros.h>
diff --git a/rtems-test-template/sptest_operation_from_tsr/TEST.doc b/rtems-test-template/sptest_operation_from_tsr/TEST.doc
--- a/rtems-test-template/sptest_operation_from_tsr/TEST.doc
+++ b/rtems-test-template/sptest_operation_from_tsr/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/sptest_operation_from_tsr/init.c b/rtems-test-template/sptest_operation_from_tsr/init.c
index 063da86..4693b3b 100644
--- a/rtems-test-template/sptest_operation_from_tsr/init.c
+++ b/rtems-test-template/sptest_operation_from_tsr/init.c
@@ -1,17 +1,28 @@
+ * are met:
diff --git a/rtems-test-template/sptest_with_task/TEST.doc b/rtems-test-template/sptest_with_task/TEST.doc
--- a/rtems-test-template/sptest_with_task/TEST.doc
+++ b/rtems-test-template/sptest_with_task/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/sptest_with_task/init.c b/rtems-test-template/sptest_with_task/init.c
index 6b01c3c..36792d6 100644
--- a/rtems-test-template/sptest_with_task/init.c
+++ b/rtems-test-template/sptest_with_task/init.c
@@ -1,17 +1,28 @@
+ * are met:
diff --git a/rtems-test-template/tmtest/TEST.doc b/rtems-test-template/tmtest/TEST.doc
--- a/rtems-test-template/tmtest/TEST.doc
+++ b/rtems-test-template/tmtest/TEST.doc
@@ -1,17 +1,27 @@
+# are met:
diff --git a/rtems-test-template/tmtest/init.c b/rtems-test-template/tmtest/init.c
index 62ab244..56b9515 100644
--- a/rtems-test-template/tmtest/init.c
+++ b/rtems-test-template/tmtest/init.c
@@ -1,17 +1,28 @@
+ * are met:
#include <timesys.h>
2.16.4
