SIS MP success
Jiri Gaisler
jiri at gaisler.se
Thu Dec 13 08:16:01 UTC 2018
> I use the SIS every day for RTEMS development and test suite runs. The
> SMP support would be a very valuable for RTEMS development. If we can
> get also code coverage from it, then it would be perfect.
I can look at the coverage support. Is there a standardized format for
coverage data that I should use?
> I will try to move the grlib from bsps/sparc/shared/* to
> bsps/shared/grlib before the RTEMS 5 release so that it can be used
> from SPARC and RISC-V BSPs.
Thanks, this would be *really* helpful..! My current setup is a bit
messy since I need to pull in the drivers and driver manager from the
SPARC port to build the RISC-V bsp.
Type: application/pgp-keys
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181213/7f8e4c8c/attachment.bin>
