[PATCH] config: Remove CONFIGURE_CONFDEFS_DEBUG
Fri Dec 14 07:11:12 UTC 2018
This configuration option was undocumented and not really helpful.  To
debug issues in <rtems/confdefs.h> it is better to save the
preprocessesd file (GCC "-save-temps" option) and use the GCC "-Wp,-dD"
pre-processor option.
 cpukit/include/rtems/confdefs.h | 59 -----------------------------------------
 1 file changed, 59 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 1a60cf15d4..26becd370b 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -3103,65 +3103,6 @@ struct _reent *__getreent(void)
-#if defined(CONFIGURE_CONFDEFS_DEBUG) && defined(CONFIGURE_INIT)
-   * This is a debug mechanism, so if you need to, the executable will
-   * have a structure with various partial values.  Add to this as you
-   * need to.  Viewing this structure in gdb combined with dumping
-   * the Configuration structures generated should help a lot in tracing
-   * down errors and analyzing where over and under allocations are.
-  typedef struct {
-    uint32_t SYSTEM_OVERHEAD;
-    uint32_t STATIC_EXTENSIONS;
-    uint32_t INITIALIZATION_THREADS_STACKS;
-    uint32_t PER_INTEGER_TASK;
-    uint32_t FP_OVERHEAD;
-    /* System overhead pieces */
-    uint32_t MEMORY_FOR_IDLE_TASK;
-    /* POSIX API Pieces */
-    uint32_t POSIX_QUEUED_SIGNALS;
-    /* Stack space sizes */
-    uint32_t IDLE_TASKS_STACK;
-    uint32_t INITIALIZATION_THREADS_EXTRA_STACKS;
-    uint32_t TASKS_STACK;
-    uint32_t POSIX_THREADS_STACK;
-    uint32_t GOROUTINES_STACK;
-    uint32_t ADA_TASKS_STACK;
-    uint32_t EXTRA_MPCI_RECEIVE_SERVER_STACK;
-    uint32_t EXTRA_TASK_STACKS;
-  } Configuration_Debug_t;
-  Configuration_Debug_t Configuration_Memory_Debug = {
-    /* General Information */
-    _CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD,
-    _CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS,
-    _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS,
-    _CONFIGURE_MEMORY_FOR_TASKS(1, 0),
-    _CONFIGURE_MEMORY_FOR_TASKS(0, 1),
-    _CONFIGURE_MEMORY_FOR_INTERNAL_TASKS,
-    _CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS,
-    _CONFIGURE_IDLE_TASKS_STACK,
-    _CONFIGURE_TASKS_STACK,
-    _CONFIGURE_POSIX_THREADS_STACK,
-    _CONFIGURE_GOROUTINES_STACK,
-    _CONFIGURE_ADA_TASKS_STACK,
-    CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK,
-    CONFIGURE_EXTRA_TASK_STACKS
-#endif
  *  Make sure a task/thread of some sort is configured.
2.16.4
