[PATCH 1/2] sb/execute: Port the rtemstoolkit performance fixes for python3
chrisj at rtems.org chrisj at rtems.org
Tue Dec 18 04:25:05 UTC 2018
Close #3664.
 source-builder/sb/execute.py | 332 +++++++++++++++++++++++++++++------
 1 file changed, 278 insertions(+), 54 deletions(-)
diff --git a/source-builder/sb/execute.py b/source-builder/sb/execute.py
index 12d8114..0c25163 100755
--- a/source-builder/sb/execute.py
+++ b/source-builder/sb/execute.py
@@ -1,6 +1,6 @@
 # RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2010-2016 Chris Johns (chrisj at rtems.org)
+# Copyright 2010-2017 Chris Johns (chrisj at rtems.org)
 # All rights reserved.
 # This file is part of the RTEMS Tools package in 'rtems-tools'.
@@ -8,7 +8,7 @@
 # Permission to use, copy, modify, and/or distribute this software for any
 # purpose with or without fee is hereby granted, provided that the above
 # copyright notice and this permission notice appear in all copies.
 # THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
 # WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
 # MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
@@ -16,6 +16,7 @@
 # WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
 # ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
 # OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
 # Execute commands or scripts.
@@ -26,15 +27,21 @@
 from __future__ import print_function
 import functools
+import io
 import os
 import re
 import sys
 import subprocess
 import threading
+import time
+import traceback
 import error
 import log
+# Trace exceptions
+trace_threads = False
 # Redefine the PIPE from subprocess
 PIPE = subprocess.PIPE
@@ -86,75 +93,240 @@ def arg_subst_str(command, subst):
     def add(x, y): return x + ' ' + str(y)
     return functools.reduce(add, cmd, '')
-class execute:
-    """Execute commands or scripts. The 'output' is a funtion
-    that handles the output from the process."""
-    def __init__(self, output = None, error_prefix = '', verbose = False):
+class execute(object):
+    """Execute commands or scripts. The 'output' is a funtion that handles the
+    output from the process. The 'input' is a function that blocks and returns
+    data to be written to stdin"""
+    def __init__(self, output = None, input = None, cleanup = None,
+                 error_prefix = '', verbose = False):
+        self.lock = threading.Lock()
         self.output = output
+        self.input = input
+        self.cleanup = cleanup
         self.error_prefix = error_prefix
         self.verbose = verbose
         self.shell_exe = None
         self.shell_commands = False
         self.path = None
         self.environment = None
-    def capture(self, proc, timeout = None):
-        """Create 2 threads to read stdout and stderr and send to the
-        output handler. Based on the 'communicate' code in the subprocess
-        module."""
-        def _readthread(fh, out, prefix = ''):
+        self.outputting = False
+        self.timing_out = False
+        self.proc = None
+    def capture(self, proc, command = 'pipe', timeout = None):
+        """Create 3 threads to read stdout and stderr and send to the output handler
+        and call an input handler is provided. Based on the 'communicate' code
+        in the subprocess module."""
+        def _writethread(exe, fh, input):
+            """Call the input handler and write it to the stdin. The input handler should
+            block and return None or False if this thread is to exit and True if this
+            is a timeout check."""
+            if trace_threads:
+                print('execute:_writethread: start')
+            encoding = True
+            try:
+                tmp = bytes('temp', sys.stdin.encoding)
+            except:
+                encoding = False
+            try:
+                while True:
+                    if trace_threads:
+                        print('execute:_writethread: call input', input)
+                    lines = input()
+                    if type(lines) == str or type(lines) == bytes:
+                        try:
+                            if encoding:
+                                lines = bytes(lines, sys.stdin.encoding)
+                            fh.write(lines)
+                            fh.flush()
+                        except:
+                            break
+                    if lines == None or \
+                       lines == False or \
+                       (lines == True and fh.closed):
+                        break
+            except:
+                if trace_threads:
+                    print('execute:_writethread: exception')
+                    print(traceback.format_exc())
+                pass
+            try:
+                fh.close()
+            except:
+                pass
+            if trace_threads:
+                print('execute:_writethread: finished')
+        def _readthread(exe, fh, out, prefix = ''):
             """Read from a file handle and write to the output handler
             until the file closes."""
-            count = 0
-            while True:
-                line = fh.readline()
-                # str and bytes are the same type in Python2
-                if type(line) is not str and type(line) is bytes:
-                    line = line.decode(sys.stdout.encoding)
-                count += 1
-                if len(line) == 0:
-                    break
+            def _output_line(line, exe, prefix, out, count):
+                #exe.lock.acquire()
+                #exe.outputting = True
+                #exe.lock.release()
                 if out:
                     out(prefix + line)
                 else:
                     log.output(prefix + line)
                     if count > 10:
                         log.flush()
-                        count = 0
-        def _timerthread(proc, timer):
-            """Timer thread calls the timer handler if one
-            is present once a second. The user provides a handler
-            and returns False to kill the process or True continue."""
-            while True:
+            if trace_threads:
+                print('execute:_readthread: start')
+            count = 0
+            line = ''
+            try:
+                while True:
+                    # The io module file handling return up to the size passed
+                    # in to the read call. The io handle has the default
+                    # buffering size. On any error assume the handle has gone
+                    # and the process is shutting down.
+                    try:
+                        data = fh.read1(4096)
+                    except:
+                        data = ''
+                    if len(data) == 0:
+                        if len(line) > 0:
+                            _output_line(line + '\n', exe, prefix, out, count)
+                        break
+                    # str and bytes are the same type in Python2
+                    if type(data) is not str and type(data) is bytes:
+                        data = data.decode(sys.stdout.encoding)
+                    last_ch = data[-1]
+                    sd = (line + data).split('\n')
+                    if last_ch != '\n':
+                        line = sd[-1]
+                    else:
+                        line = ''
+                    sd = sd[:-1]
+                    if len(sd) > 0:
+                        for l in sd:
+                            _output_line(l + '\n', exe, prefix, out, count)
+                            count += 1
+                        if count > 10:
+                            count -= 10
+            except:
+                raise
+                if trace_threads:
+                    print('execute:_readthread: exception')
+                pass
+            try:
+                fh.close()
+            except:
+                pass
+            if len(line):
+                _output_line(line, exe, prefix, out, 100)
+            if trace_threads:
+                print('execute:_readthread: finished')
+        def _timerthread(exe, interval, function):
+            """Timer thread is used to timeout a process if no output is
+            produced for the timeout interval."""
+            count = interval
+            while exe.timing_out:
                 time.sleep(1)
-                if not timer(proc):
-                    proc.stdout.close()
-                    proc.stderr.close()
+                if count > 0:
+                    count -= 1
+                exe.lock.acquire()
+                if exe.outputting:
+                    count = interval
+                    exe.outputting = False
+                exe.lock.release()
+                if count == 0:
+                    try:
+                        proc.kill()
+                    except:
+                        pass
+                    else:
+                        function()
+                    break
+        name = os.path.basename(command[0])
+        stdin_thread = None
+        stdout_thread = None
+        stderr_thread = None
+        timeout_thread = None
         if proc.stdout:
             stdout_thread = threading.Thread(target = _readthread,
-                                             args = (proc.stdout,
+                                             name = '_stdout[%s]' % (name),
+                                             args = (self,
+                                                     io.open(proc.stdout.fileno(),
+                                                             mode = 'rb',
+                                                             closefd = False),
                                                      self.output,
-            stdout_thread.setDaemon(True)
+            stdout_thread.daemon = True
             stdout_thread.start()
         if proc.stderr:
             stderr_thread = threading.Thread(target = _readthread,
-                                             args = (proc.stderr,
+                                             name = '_stderr[%s]' % (name),
+                                             args = (self,
+                                                     io.open(proc.stderr.fileno(),
+                                                             mode = 'rb',
+                                                             closefd = False),
                                                      self.output,
                                                      self.error_prefix))
-            stderr_thread.setDaemon(True)
+            stderr_thread.daemon = True
             stderr_thread.start()
-        if proc.stdout:
-            stdout_thread.join()
-        if proc.stderr:
-            stderr_thread.join()
-        return proc.wait()
+        if self.input and proc.stdin:
+            stdin_thread = threading.Thread(target = _writethread,
+                                            name = '_stdin[%s]' % (name),
+                                            args = (self,
+                                                    proc.stdin,
+                                                    self.input))
+            stdin_thread.daemon = True
+            stdin_thread.start()
+        if timeout:
+            self.timing_out = True
+            timeout_thread = threading.Thread(target = _timerthread,
+                                              name = '_timeout[%s]' % (name),
+                                              args = (self,
+                                                      timeout[0],
+                                                      timeout[1]))
+            timeout_thread.daemon = True
+            timeout_thread.start()
+        try:
+            self.lock.acquire()
+            try:
+                self.proc = proc
+            except:
+                raise
+            finally:
+                self.lock.release()
+            exitcode = proc.wait()
+        except:
+            proc.kill()
+            raise
+        finally:
+            try:
+                self.proc = None
+            except:
+                raise
+            finally:
+            if self.cleanup:
+                self.cleanup(proc)
+            if timeout_thread:
+                timeout_thread.join(10)
+            if stdin_thread:
+                stdin_thread.join(2)
+            if stdout_thread:
+                stdout_thread.join(2)
+            if stderr_thread:
+                stderr_thread.join(2)
+        return exitcode
     def open(self, command, capture = True, shell = False,
              cwd = None, env = None,
-             stdin = None, stdout = None, stderr = None):
+             stdin = None, stdout = None, stderr = None,
+             timeout = None):
         """Open a command with arguments. Provide the arguments as a list or
         a string."""
         if self.verbose:
@@ -166,9 +338,13 @@ class execute:
             if shell:
                 what = 'shell'
             log.output(what + ': ' + s)
+        if self.output is None:
+            raise error.general('capture needs an output handler')
         if shell and self.shell_exe:
             command = arg_list(command)
             command[:0] = self.shell_exe
+        if not stdin and self.input:
+            stdin = subprocess.PIPE
         if not stdout:
             stdout = subprocess.PIPE
         if not stderr:
@@ -191,10 +367,13 @@ class execute:
             proc = subprocess.Popen(command, shell = shell,
                                     cwd = cwd, env = env,
                                     stdin = stdin, stdout = stdout,
-                                    stderr = stderr)
+                                    stderr = stderr,
+                                    close_fds = False)
             if not capture:
                 return (0, proc)
-            exit_code = self.capture(proc)
+            exit_code = self.capture(proc, command, timeout)
             if self.verbose:
                 log.output('exit: ' + str(exit_code))
         except OSError as ose:
@@ -204,23 +383,26 @@ class execute:
         return (exit_code, proc)
     def spawn(self, command, capture = True, cwd = None, env = None,
+              timeout = None):
         """Spawn a command with arguments. Provide the arguments as a list or
         a string."""
         return self.open(command, capture, False, cwd, env,
-                         stdin, stdout, stderr)
+                         stdin, stdout, stderr, timeout)
     def shell(self, command, capture = True, cwd = None, env = None,
+              timeout = None):
         """Execute a command within a shell context. The command can contain
         argumments. The shell is specific to the operating system. For example
         it is cmd.exe on Windows XP."""
         return self.open(command, capture, True, cwd, env,
     def command(self, command, args = None, capture = True, shell = False,
+                timeout = None):
         """Run the command with the args. The args can be a list
         or a string."""
         if args and not type(args) is list:
@@ -230,18 +412,21 @@ class execute:
             cmd.extend(args)
         return self.open(cmd, capture = capture, shell = shell,
-                         stdin = stdin, stdout = stdout, stderr = stderr)
+                         stdin = stdin, stdout = stdout, stderr = stderr,
+                         timeout = timeout)
     def command_subst(self, command, substs, capture = True, shell = False,
+                      timeout = None):
         """Run the command from the config data with the
         option format string subsituted with the subst variables."""
         args = arg_subst(command, substs)
         return self.command(args[0], args[1:], capture = capture,
                             shell = shell or self.shell_commands,
     def set_shell(self, execute):
         """Set the shell to execute when issuing a shell command."""
@@ -275,6 +460,37 @@ class execute:
         self.environment = environment
         return old_environment
+    def kill(self):
+        try:
+            if self.proc is not None:
+                self.proc.kill()
+        except:
+            raise
+        finally:
+    def terminate(self):
+        try:
+                self.proc.terminate()
+        except:
+            raise
+        finally:
+    def send_signal(self, signal):
+        try:
+                print("sending sig")
+                self.proc.send_signal(signal)
+        except:
+            raise
+        finally:
 class capture_execution(execute):
     """Capture all output as a string and return it."""
@@ -303,13 +519,14 @@ class capture_execution(execute):
                          verbose = verbose)
     def open(self, command, capture = True, shell = False, cwd = None, env = None,
+             stdin = None, stdout = None, stderr = None, timeout = None):
         if not capture:
             raise error.general('output capture must be true; leave as default')
         #self.snapper.get_and_clear()
         exit_code, proc = execute.open(self, command, capture = True, shell = shell,
         return (exit_code, proc, self.snapper.get_and_clear())
     def set_output(self, output):
@@ -333,11 +550,18 @@ if __name__ == "__main__":
         if ec == 0:
             print('piping input into ' + commands['pipe'][0] + ': ' + \
                   commands['pipe'][2])
-            proc.stdin.write(bytes(commands['pipe'][2], sys.stdin.encoding))
+            try:
+                out = bytes(commands['pipe'][2], sys.stdin.encoding)
+            except:
+                out = commands['pipe'][2]
+            proc.stdin.write(out)
             proc.stdin.close()
             e.capture(proc)
             del proc
+    def capture_output(text):
+        print(text, end = '')
     cmd_shell_test = 'if "%OS%" == "Windows_NT" (echo It is WinNT) else echo Is is not WinNT'
     sh_shell_test = 'x="me"; if [ $x = "me" ]; then echo "It was me"; else "It was him"; fi'
@@ -363,7 +587,7 @@ if __name__ == "__main__":
     print(arg_subst(['nothing', 'xx-%0-yyy', '%1', '%2-something'],
                     ['subst0', 'subst1', 'subst2']))
-    e = execute(error_prefix = 'ERR: ', verbose = True)
+    e = execute(error_prefix = 'ERR: ', output = capture_output, verbose = True)
     if sys.platform == "win32":
         run_tests(e, commands['windows'], False)
         if os.path.exists('c:\\msys\\1.0\\bin\\sh.exe'):
2.19.1
