waf and Python 3.7
Wed Dec 19 01:31:13 UTC 2018
On 19/12/2018 11:49, Joel Sherrill wrote:
> On Tue, Dec 18, 2018 at 5:33 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 19/12/2018 06:12, Christian Mauderer wrote:
>     > I updated waf in rtems-tools with a reference to the ticket. I'm still a
>     > little unsure about our tickets: Should I create separate tickets for
>     > that problem in rtems-docs, rtems-libbsd (both have the same problem)
>     > and examples-v2 (I haven't tested that yet but I would expect the
>     > problem there too).
>     No, the same ticket should be fine. Maybe update the ticket's details to
>     highlight this is happening. Separate tickets are needed for separate branches
>     because the timeline cannot be shared.
>     > Note that rtems-docs needs an extra patch to build with python 3. There
>     > is an indentation error (mix of space and tab).
>     Yes I have tripped over this but I have not had time to push a fix. Building PDF
>     is broken for me with the latest Sphinx. I am on a fully updated FreeBSD 11.2-p5
>     and all packages are updated plus the latest Sphinx in a virtualend. The issue
>     seems to be deep in Latex and relates to unicode characters in bib entries with
>     hyperef and the other package and things being confused. I do not know if it is
>     a bug in Sphinx or our configuration.
> FWIW I am building html fine with Python 2 and Sphinx 1.6, 1.7, and 1.8.2 on three
> different CentOS computers. But PDF doesn't work on any of those platforms.
The build on sync.rtems.org for the online manuals is failing with unicode errors:
$ file `find . -name \*.rst` | grep Unicode
./eng/users-manuals.rst:                          UTF-8 Unicode text
./eng/test-plan.rst:                              UTF-8 Unicode text
./eng/vc-users.rst:                               UTF-8 Unicode text
./eng/appendix-a.rst:                             UTF-8 Unicode text
./eng/vc-authors.rst:                             UTF-8 Unicode text
./eng/license-requirements.rst:                   UTF-8 Unicode text
./eng/prequalification.rst:                       UTF-8 Unicode text
./user/tracing/examples.rst:                      UTF-8 Unicode text
./user/tracing/introduction.rst:                  UTF-8 Unicode text
./bsp-howto/i2c.rst:                              UTF-8 Unicode text
This raises 2 issues, we need the docs to build so the listed files need to be
cleaned and the second issue is being able to support unicode. That is a
separate development effort that will need to be worked on.
