[PATCH] Add aligned_alloc() and memalign()
Wed Dec 19 08:27:17 UTC 2018
Ensure that the C++17 aligned new operator works.
Close #3666.
 cpukit/Makefile.am                     |  1 +
 cpukit/libcsupport/src/alignedalloc.c  | 41 ++++++++++++++++++++
 testsuites/sptests/Makefile.am         | 12 ++++++
 testsuites/sptests/configure.ac        |  1 +
 testsuites/sptests/spcxx01/init.cc     | 68 ++++++++++++++++++++++++++++++++++
 testsuites/sptests/spcxx01/spcxx01.doc | 11 ++++++
 testsuites/sptests/spcxx01/spcxx01.scn |  7 ++++
 7 files changed, 141 insertions(+)
 create mode 100644 cpukit/libcsupport/src/alignedalloc.c
 create mode 100644 testsuites/sptests/spcxx01/init.cc
 create mode 100644 testsuites/sptests/spcxx01/spcxx01.doc
 create mode 100644 testsuites/sptests/spcxx01/spcxx01.scn
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 1b393e8c88..6695abd79d 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -78,6 +78,7 @@ librtemscpu_a_SOURCES += libcrypt/crypt-sha512.c
 librtemscpu_a_SOURCES += libcrypt/misc.c
 librtemscpu_a_SOURCES += libcsupport/src/access.c
 librtemscpu_a_SOURCES += libcsupport/src/arc4random_getentropy_fail.c
+librtemscpu_a_SOURCES += libcsupport/src/alignedalloc.c
 librtemscpu_a_SOURCES += libcsupport/src/__assert.c
 librtemscpu_a_SOURCES += libcsupport/src/assoc32tostring.c
 librtemscpu_a_SOURCES += libcsupport/src/assoclocalbyname.c
diff --git a/cpukit/libcsupport/src/alignedalloc.c b/cpukit/libcsupport/src/alignedalloc.c
new file mode 100644
index 0000000000..0ecf7393d8
--- /dev/null
+++ b/cpukit/libcsupport/src/alignedalloc.c
@@ -0,0 +1,41 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018 embedded brains GmbH
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stdlib.h>
+#include <rtems/malloc.h>
+void *aligned_alloc( size_t alignment, size_t size )
+  return rtems_heap_allocate_aligned_with_boundary( size, alignment, 0 );
+void *memalign( size_t, size_t ) RTEMS_ALIAS( aligned_alloc );
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 8f92873d2b..a3c9b1e3bf 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -772,6 +772,18 @@ spcpuset01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spcpuset01) \
 	$(support_includes) -DSMPTEST
 endif
+if HAS_CPLUSPLUS
+if TEST_spcxx01
+sp_tests += spcxx01
+sp_screens += spcxx01/spcxx01.scn
+sp_docs += spcxx01/spcxx01.doc
+spcxx01_SOURCES = spcxx01/init.cc
+spcxx01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spcxx01) \
+	$(support_includes)
+spcxx01_CXXFLAGS = $(AM_CXXFLAGS) -std=gnu++17
+endif
+endif
 if TEST_spedfsched01
 sp_tests += spedfsched01
 sp_screens += spedfsched01/spedfsched01.scn
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index d25d9e9e32..322219696d 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -124,6 +124,7 @@ RTEMS_TEST_CHECK([spcontext01])
 RTEMS_TEST_CHECK([spcoverage])
 RTEMS_TEST_CHECK([spcpucounter01])
 RTEMS_TEST_CHECK([spcpuset01])
+RTEMS_TEST_CHECK([spcxx01])
 RTEMS_TEST_CHECK([spedfsched01])
 RTEMS_TEST_CHECK([spedfsched02])
 RTEMS_TEST_CHECK([spedfsched03])
diff --git a/testsuites/sptests/spcxx01/init.cc b/testsuites/sptests/spcxx01/init.cc
index 0000000000..986731634b
--- /dev/null
+++ b/testsuites/sptests/spcxx01/init.cc
@@ -0,0 +1,68 @@
+ * are met:
+#ifdef HAVE_CONFIG_H
+#endif
+#include <new>
+#include <rtems.h>
+#include <tmacros.h>
+const char rtems_test_name[] = "SPCXX 1";
+extern "C" void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  int *i = static_cast<decltype(i)>(
+    ::operator new(sizeof(*i), std::align_val_t(256))
+  RTEMS_OBFUSCATE_VARIABLE(i);
+  rtems_test_assert(i != nullptr);
+  rtems_test_assert(reinterpret_cast<uintptr_t>(i) % 256 == 0);
+  ::delete(i);
+  TEST_END();
+  exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spcxx01/spcxx01.doc b/testsuites/sptests/spcxx01/spcxx01.doc
index 0000000000..669e6820ab
--- /dev/null
+++ b/testsuites/sptests/spcxx01/spcxx01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spcxx01
+directives:
+  - ::operator new()
+concepts:
+  - Ensure that the aligned new operator works.
diff --git a/testsuites/sptests/spcxx01/spcxx01.scn b/testsuites/sptests/spcxx01/spcxx01.scn
index 0000000000..111050e731
--- /dev/null
+++ b/testsuites/sptests/spcxx01/spcxx01.scn
@@ -0,0 +1,7 @@
+*** BEGIN OF TEST SPCXX 1 ***
+*** TEST VERSION: 5.0.0.cfa82b34b0c53ab4e3d84dd8ab5225793d48fcd0
+*** TEST STATE: EXPECTED-PASS
+*** TEST BUILD:
+*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB ddba5372522da341fa20b2c75dfe966231cb6790, Newlib df6915f029ac9acd2b479ea898388cbd7dda4974)
+*** END OF TEST SPCXX 1 ***
2.16.4
