[PATCH] Add low level event recording support
Wed Dec 19 13:20:58 UTC 2018
Add low level event recording infrastructure for system and user
defined events.  The infrastructure is able to record high frequency
events such as
 * SMP lock acquire/release,
 * interrupt entry/exit,
 * thread switches,
 * UMA zone allocate/free, and
 * Ethernet packet input/output, etc.
It allows post-mortem analysis in fatal error handlers, e.g. the last
events are in the record buffer, the newest event overwrites the oldest
event.  It is possible to detect record buffer overflows for consumers
that expect a continuous stream of events, e.g. to display the system
state in real-time.
The implementation supports high-end SMP machines (more than 1GHz
processor frequency, more than four processors).
Add a new API instead. The implementation uses per-processor data
structures and no atomic read-modify-write operations.  It is uses
per-processor ring buffers to record the events.
The CPU counter is used to get the time of events. It is combined with
periodic uptime events to synchronize it with CLOCK_REALTIME.
The existing capture engine tries to solve this problem also, but its
performance is not good enough for high-end production systems.  The
main issues are the variable-size buffers and the use of SMP locks for
synchronization.  To fix this, the API would change significantly.
Update #3665.
 cpukit/Makefile.am                        |   6 +
 cpukit/headers.am                         |   3 +
 cpukit/include/rtems/confdefs.h           |  31 ++
 cpukit/include/rtems/record.h             | 333 ++++++++++++++
 cpukit/include/rtems/recordclient.h       | 137 ++++++
 cpukit/include/rtems/recorddata.h         | 293 ++++++++++++
 cpukit/include/rtems/score/percpu.h       |   4 +
 cpukit/include/rtems/sysinit.h            |   1 +
 cpukit/libmisc/record/record-client.c     | 429 ++++++++++++++++++
 cpukit/libmisc/record/record-server.c     | 286 ++++++++++++
 cpukit/libmisc/record/record-static.c     | 131 ++++++
 cpukit/libmisc/record/record-text.c       | 173 ++++++++
 cpukit/libmisc/record/record-userext.c    | 125 ++++++
 cpukit/libmisc/record/record.c            | 132 ++++++
 testsuites/libtests/Makefile.am           |  18 +
 testsuites/libtests/configure.ac          |   2 +
 testsuites/libtests/record01/init.c       | 709 ++++++++++++++++++++++++++++++
 testsuites/libtests/record01/record01.doc |  15 +
 testsuites/libtests/record01/record01.scn |   7 +
 testsuites/libtests/record02/init.c       | 132 ++++++
 testsuites/libtests/record02/record02.doc |  12 +
 testsuites/libtests/record02/record02.scn |  81 ++++
 22 files changed, 3060 insertions(+)
 create mode 100644 cpukit/include/rtems/record.h
 create mode 100644 cpukit/include/rtems/recordclient.h
 create mode 100644 cpukit/include/rtems/recorddata.h
 create mode 100644 cpukit/libmisc/record/record-client.c
 create mode 100644 cpukit/libmisc/record/record-server.c
 create mode 100644 cpukit/libmisc/record/record-static.c
 create mode 100644 cpukit/libmisc/record/record-text.c
 create mode 100644 cpukit/libmisc/record/record-userext.c
 create mode 100644 cpukit/libmisc/record/record.c
 create mode 100644 testsuites/libtests/record01/init.c
 create mode 100644 testsuites/libtests/record01/record01.doc
 create mode 100644 testsuites/libtests/record01/record01.scn
 create mode 100644 testsuites/libtests/record02/init.c
 create mode 100644 testsuites/libtests/record02/record02.doc
 create mode 100644 testsuites/libtests/record02/record02.scn
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 23f4f40521..6695abd79d 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -307,6 +307,12 @@ librtemscpu_a_SOURCES += libmisc/monitor/mon-symbols.c
 librtemscpu_a_SOURCES += libmisc/monitor/mon-task.c
 librtemscpu_a_SOURCES += libmisc/mouse/mouse_parser.c
 librtemscpu_a_SOURCES += libmisc/mouse/serial_mouse.c
+librtemscpu_a_SOURCES += libmisc/record/record.c
+librtemscpu_a_SOURCES += libmisc/record/record-client.c
+librtemscpu_a_SOURCES += libmisc/record/record-server.c
+librtemscpu_a_SOURCES += libmisc/record/record-static.c
+librtemscpu_a_SOURCES += libmisc/record/record-text.c
+librtemscpu_a_SOURCES += libmisc/record/record-userext.c
 librtemscpu_a_SOURCES += libmisc/redirector/stdio-redirect.c
 librtemscpu_a_SOURCES += libmisc/rtems-fdt/rtems-fdt.c
 librtemscpu_a_SOURCES += libmisc/rtems-fdt/rtems-fdt-shell.c
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 3ab97a95ca..fba976e5b1 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -136,6 +136,9 @@ include_rtems_HEADERS += include/rtems/qreslib.h
 include_rtems_HEADERS += include/rtems/ramdisk.h
 include_rtems_HEADERS += include/rtems/rbheap.h
 include_rtems_HEADERS += include/rtems/rbtree.h
+include_rtems_HEADERS += include/rtems/record.h
+include_rtems_HEADERS += include/rtems/recordclient.h
+include_rtems_HEADERS += include/rtems/recorddata.h
 include_rtems_HEADERS += include/rtems/ringbuf.h
 include_rtems_HEADERS += include/rtems/rtc.h
 include_rtems_HEADERS += include/rtems/rtems-debugger-remote-tcp.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 45e70313fb..89b47050d6 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2123,6 +2123,10 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     defined(CONFIGURE_STACK_CHECKER_ENABLED) || \
     (defined(RTEMS_NEWLIB) && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY))
   static const rtems_extensions_table Configuration_Initial_Extensions[] = {
+    #if CONFIGURE_RECORD_PER_PROCESSOR_ITEMS > 0 && \
+      defined(CONFIGURE_RECORD_EXTENSIONS_ENABLED)
+      RECORD_EXTENSION,
+    #endif
     #if !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY)
       RTEMS_NEWLIB_EXTENSION,
     #endif
@@ -2965,6 +2969,33 @@ struct _reent *__getreent(void)
       _CONFIGURE_MAXIMUM_PROCESSORS,
     #endif
+    #include <rtems/record.h>
+    #if (CONFIGURE_RECORD_PER_PROCESSOR_ITEMS & (CONFIGURE_RECORD_PER_PROCESSOR_ITEMS - 1)) != 0
+      #error "CONFIGURE_RECORD_PER_PROCESSOR_ITEMS must be a power of two"
+    #endif
+    #if CONFIGURE_RECORD_PER_PROCESSOR_ITEMS < 16
+      #error "CONFIGURE_RECORD_PER_PROCESSOR_ITEMS must be at least 16"
+    #endif
+    const unsigned int _Record_Item_count = CONFIGURE_RECORD_PER_PROCESSOR_ITEMS;
+    struct Record_Configured_control {
+      Record_Control    Control;
+      rtems_record_item Items[ CONFIGURE_RECORD_PER_PROCESSOR_ITEMS ];
+    PER_CPU_DATA_ITEM( Record_Configured_control, _Record_Per_CPU );
+    RTEMS_SYSINIT_ITEM(
+      _Record_Initialize,
+      RTEMS_SYSINIT_RECORD,
+      RTEMS_SYSINIT_ORDER_MIDDLE
+  #endif
 #endif
 #if defined(RTEMS_SMP)
diff --git a/cpukit/include/rtems/record.h b/cpukit/include/rtems/record.h
new file mode 100644
index 0000000000..b8f7560fbe
--- /dev/null
+++ b/cpukit/include/rtems/record.h
@@ -0,0 +1,333 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018 embedded brains GmbH
+ * are met:
+#ifndef _RTEMS_RECORD_H
+#define _RTEMS_RECORD_H
+#include "recorddata.h"
+#include <rtems/score/atomic.h>
+#include <rtems/score/cpu.h>
+#include <rtems/score/percpudata.h>
+#include <rtems/score/watchdog.h>
+#include <rtems/rtems/intr.h>
+#include <rtems/rtems/tasks.h>
+#include <rtems/counter.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+struct Record_Control {
+  Atomic_Uint       head;
+  unsigned int      tail;
+  unsigned int      mask;
+  Watchdog_Control  Watchdog;
+  rtems_record_item Header[ 3 ];
+  rtems_record_item Items[ RTEMS_ZERO_LENGTH_ARRAY ];
+typedef struct Record_Control Record_Control;
+typedef RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
+  struct Record_Configured_control Record_Configured_control;
+typedef struct {
+  Record_Control        *control;
+  unsigned int           head;
+  uint32_t               now;
+  rtems_interrupt_level  level;
+} rtems_record_context;
+PER_CPU_DATA_ITEM_DECLARE( Record_Configured_control, _Record_Per_CPU );
+extern const unsigned int _Record_Item_count;
+void _Record_Initialize( void );
+bool _Record_Thread_create(
+  struct _Thread_Control *executing,
+  struct _Thread_Control *created
+void _Record_Thread_start(
+  struct _Thread_Control *started
+void _Record_Thread_restart(
+  struct _Thread_Control *restarted
+void _Record_Thread_delete(
+  struct _Thread_Control *deleted
+void _Record_Thread_switch(
+  struct _Thread_Control *heir
+void _Record_Thread_begin( struct _Thread_Control *executing );
+void _Record_Thread_exitted( struct _Thread_Control *executing );
+void _Record_Thread_terminate(
+#define RECORD_EXTENSION \
+    _Record_Thread_create, \
+    _Record_Thread_start, \
+    _Record_Thread_restart, \
+    _Record_Thread_delete, \
+    _Record_Thread_switch, \
+    _Record_Thread_begin, \
+    _Record_Thread_exitted, \
+    NULL, \
+    _Record_Thread_terminate \
+RTEMS_INLINE_ROUTINE unsigned int _Record_Index(
+  const Record_Control *control,
+  unsigned int          index
+  return index & control->mask;
+RTEMS_INLINE_ROUTINE unsigned int _Record_Head( const Record_Control *control )
+  return _Atomic_Load_uint( &control->head, ATOMIC_ORDER_RELAXED );
+RTEMS_INLINE_ROUTINE unsigned int _Record_Tail( const Record_Control *control )
+  return control->tail;
+RTEMS_INLINE_ROUTINE bool _Record_Is_overflow(
+  unsigned int          tail,
+  unsigned int          head
+  return head - tail >= control->mask + 1U;
+RTEMS_INLINE_ROUTINE unsigned int _Record_Capacity(
+  unsigned int          head
+  return ( tail - head - 1U ) & control->mask;
+RTEMS_INLINE_ROUTINE rtems_counter_ticks _Record_Now( void )
+  return rtems_counter_read();
+typedef struct RTEMS_PACKED {
+  uint32_t format;
+  uint32_t magic;
+  rtems_record_item Version;
+  rtems_record_item Count;
+  rtems_record_item Frequency;
+} Record_Stream_header;
+void _Record_Stream_header_initialize( Record_Stream_header *header );
+ * @addtogroup RTEMSRecord
+ * @brief Prepares to add and commit record items.
+ * This function disables interrupts.
+ * @param context The record context which must be used for the following
+ *   rtems_record_add() and rtems_record_commit() calls.  The record context
+ *   may have an arbitrary content at function entry.
+ * @see rtems_record_produce().
+RTEMS_INLINE_ROUTINE void rtems_record_prepare( rtems_record_context *context )
+  const Per_CPU_Control *cpu_self;
+  rtems_interrupt_local_disable( level );
+  context->now = RTEMS_RECORD_TIME_EVENT( _Record_Now(), 0 );
+  context->level = level;
+  cpu_self = _Per_CPU_Get();
+  control = cpu_self->record;
+  context->control = control;
+  head = _Record_Head( control );
+  context->head = head;
+ * @brief Adds a record item.
+ * @param context The record context initialized via rtems_record_prepare().
+ * @param event The record event without a time stamp for the item.
+ * @param data The record data for the item.
+RTEMS_INLINE_ROUTINE void rtems_record_add(
+  rtems_record_context *context,
+  rtems_record_event    event,
+  rtems_record_data     data
+  rtems_record_item *item;
+  control = context->control;
+  head = context->head;
+  item = &control->Items[ _Record_Index( control, head ) ];
+  context->head = head + 1;
+  item->event = context->now | event;
+  item->data = data;
+ * @brief Commits a set of record items.
+RTEMS_INLINE_ROUTINE void rtems_record_commit( rtems_record_context *context )
+  _Atomic_Store_uint(
+    &context->control->head,
+    context->head,
+    ATOMIC_ORDER_RELEASE
+  rtems_interrupt_local_enable( context->level );
+ * @brief Produces a record item.
+void rtems_record_produce( rtems_record_event event, rtems_record_data data );
+ * @brief Produces two record items.
+ * @param event_0 The record event without a time stamp for the first item.
+ * @param data_0 The record data for the first item.
+ * @param event_1 The record event without a time stamp for the second item.
+ * @param data_1 The record data for the second item.
+void rtems_record_produce_2(
+  rtems_record_event event_0,
+  rtems_record_data  data_0,
+  rtems_record_event event_1,
+  rtems_record_data  data_1
+ * @brief Produces n record items.
+ * @param item The record items without a time stamps.
+ * @param n The count of record items.
+void rtems_record_produce_n(
+  const rtems_record_item *items,
+  size_t                   n
+typedef void ( *rtems_record_drain_visitor )(
+  size_t                   count,
+  void                    *arg
+ * @brief Drains the record items on all processors.
+ * Calls the visitor function for each drained item set.
+ * @param visitor The visitor function.
+ * @param arg The argument for the visitor function.
+void rtems_record_drain( rtems_record_drain_visitor visitor, void *arg );
+ * @brief Drains the record items on all processors an writes them to the file
+ * descriptor.
+ * @param fd The file descriptor.
+ * @param written Set to true if items were written to the file descriptor,
+ *   otherwise set to false.
+ * @retval The bytes written to the file descriptor.
+ssize_t rtems_record_writev( int fd, bool *written );
+ * @brief Runs a record TCP server loop.
+ * @param port The TCP port to listen in host byte order.
+ * @param period The drain period in clock ticks.
+void rtems_record_server( uint16_t port, rtems_interval period );
+ * @brief Starts a record TCP server task.
+ * @param priority The task priority.
+rtems_status_code rtems_record_start_server(
+  rtems_task_priority priority,
+  uint16_t            port,
+  rtems_interval      period
+#ifdef __cplusplus
+#endif /* _RTEMS_RECORD_H */
diff --git a/cpukit/include/rtems/recordclient.h b/cpukit/include/rtems/recordclient.h
index 0000000000..21c16665a2
--- /dev/null
+++ b/cpukit/include/rtems/recordclient.h
@@ -0,0 +1,137 @@
+ * are met:
+ * This file must be compatible to general purpose POSIX system, e.g. Linux,
+ * FreeBSD.  It may be used for utility programs.
+#ifndef _RTEMS_RECORDCLIENT_H
+#define _RTEMS_RECORDCLIENT_H
+#include <stddef.h>
+#ifdef __cplusplus
+extern "C" {
+#define RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT 32
+typedef enum {
+  RTEMS_RECORD_CLIENT_SUCCESS,
+  RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC,
+  RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT,
+  RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION,
+  RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU
+} rtems_record_client_status;
+typedef rtems_record_client_status ( *rtems_record_client_handler )(
+  uint32_t            seconds,
+  uint32_t            nanoseconds,
+  uint32_t            cpu,
+  uint64_t            data,
+  void               *arg
+typedef struct {
+  struct {
+    uint64_t bt;
+    uint32_t time;
+  } uptime;
+  uint32_t tail[ 2 ];
+  uint32_t head[ 2 ];
+  size_t index;
+} rtems_record_client_per_cpu;
+typedef struct rtems_record_client_context {
+  uint64_t to_bt_scaler;
+  rtems_record_client_per_cpu per_cpu[ RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT ];
+  uint64_t data;
+  uint32_t cpu;
+  uint32_t event;
+  uint32_t count;
+  union {
+    rtems_record_item_32 format_32;
+    rtems_record_item_64 format_64;
+  } item;
+  size_t todo;
+  void *pos;
+  rtems_record_client_status ( *consume )(
+    struct rtems_record_client_context *,
+    const void *,
+    size_t
+  rtems_record_client_handler handler;
+  void *handler_arg;
+  uint32_t header[ 2 ];
+} rtems_record_client_context;
+ * @brief Initializes a record client.
+ * The record client consumes a record item stream produces by the record
+ * server.
+ * @param ctx The record client context to initialize.
+ * @param handler The handler is invoked for each received record item.
+ * @param arg The handler argument.
+void rtems_record_client_init(
+  rtems_record_client_context *ctx,
+  rtems_record_client_handler  handler,
+  void                        *arg
+ * @brief Runs the record client to consume new stream data.
+ * @param ctx The record client context.
+ * @param buf The buffer with new stream data.
+ * @param n The size of the buffer.
+rtems_record_client_status rtems_record_client_run(
+  const void                  *buf,
+  size_t                       n
+#ifdef __cplusplus
+#endif /* _RTEMS_RECORDCLIENT_H */
diff --git a/cpukit/include/rtems/recorddata.h b/cpukit/include/rtems/recorddata.h
index 0000000000..e029ece53f
--- /dev/null
+++ b/cpukit/include/rtems/recorddata.h
@@ -0,0 +1,293 @@
+ * are met:
+#ifndef _RTEMS_RECORDDATA_H
+#define _RTEMS_RECORDDATA_H
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+ * @defgroup RTEMSRecord Event Recording
+ * @brief Low-level event recording support.
+ * @brief The record version.
+ * The record version reflects the record event definitions.  It is reported by
+ * the RTEMS_RECORD_VERSION event.
+#define RTEMS_RECORD_THE_VERSION 1
+ * @brief The items are in 32-bit little-endian format.
+#define RTEMS_RECORD_FORMAT_LE_32 0x11111111
+ * @brief The items are in 64-bit little-endian format.
+#define RTEMS_RECORD_FORMAT_LE_64 0x22222222
+ * @brief The items are in 32-bit big-endian format.
+#define RTEMS_RECORD_FORMAT_BE_32 0x33333333
+ * @brief The items are in 64-bit big-endian format.
+#define RTEMS_RECORD_FORMAT_BE_64 0x44444444
+ * @brief Magic number to identify a record item stream.
+ * This is a random number.
+#define RTEMS_RECORD_MAGIC 0x82e14ec1
+ * @brief The record events.
+typedef enum {
+  /* There are 512 events reserved for the system */
+  RTEMS_RECORD_EMPTY,
+  RTEMS_RECORD_VERSION,
+   * Keep the following system events in lexicographical order, increment
+   * RTEMS_RECORD_THE_VERSION after each change.
+  RTEMS_RECORD_ACCEPT,
+  RTEMS_RECORD_BIND,
+  RTEMS_RECORD_CHOWN,
+  RTEMS_RECORD_CLOSE,
+  RTEMS_RECORD_CONNECT,
+  RTEMS_RECORD_COUNT,
+  RTEMS_RECORD_FCHMOD,
+  RTEMS_RECORD_FCNTL,
+  RTEMS_RECORD_FDATASYNC,
+  RTEMS_RECORD_FREQUENCY,
+  RTEMS_RECORD_FSTAT,
+  RTEMS_RECORD_FSYNC,
+  RTEMS_RECORD_FTRUNCATE,
+  RTEMS_RECORD_HEAD,
+  RTEMS_RECORD_HEAP_ALLOC,
+  RTEMS_RECORD_HEAP_FREE,
+  RTEMS_RECORD_HEAP_SIZE,
+  RTEMS_RECORD_HEAP_USAGE,
+  RTEMS_RECORD_INTERUPT_BEGIN,
+  RTEMS_RECORD_INTERUPT_END,
+  RTEMS_RECORD_INTERUPT_INSTALL,
+  RTEMS_RECORD_INTERUPT_REMOVE,
+  RTEMS_RECORD_IOCTL,
+  RTEMS_RECORD_KEVENT,
+  RTEMS_RECORD_KQUEUE,
+  RTEMS_RECORD_LINK,
+  RTEMS_RECORD_LSEEK,
+  RTEMS_RECORD_MKNOD,
+  RTEMS_RECORD_MMAP,
+  RTEMS_RECORD_MOUNT,
+  RTEMS_RECORD_OPEN,
+  RTEMS_RECORD_OVERFLOW,
+  RTEMS_RECORD_POLL,
+  RTEMS_RECORD_PROCESSOR,
+  RTEMS_RECORD_READ,
+  RTEMS_RECORD_READLINK,
+  RTEMS_RECORD_READV,
+  RTEMS_RECORD_RECV,
+  RTEMS_RECORD_RECVFROM,
+  RTEMS_RECORD_RECVMSG,
+  RTEMS_RECORD_RENAME,
+  RTEMS_RECORD_RTEMS_BARRIER_CREATE,
+  RTEMS_RECORD_RTEMS_BARRIER_DELETE,
+  RTEMS_RECORD_RTEMS_BARRIER_RELEASE,
+  RTEMS_RECORD_RTEMS_BARRIER_WAIT,
+  RTEMS_RECORD_RTEMS_EVENT_RECEIVE,
+  RTEMS_RECORD_RTEMS_EVENT_SEND,
+  RTEMS_RECORD_RTEMS_EVENT_SYSTEM_RECEIVE,
+  RTEMS_RECORD_RTEMS_EVENT_SYSTEM_SEND,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_BROADCAST,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_CREATE,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_DELETE,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_FLUSH,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_RECEIVE,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_SEND,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_URGENT,
+  RTEMS_RECORD_RTEMS_PARTITION_CREATE,
+  RTEMS_RECORD_RTEMS_PARTITION_DELETE,
+  RTEMS_RECORD_RTEMS_PARTITION_GET_BUFFER,
+  RTEMS_RECORD_RTEMS_PARTITION_RETURN_BUFFER,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CANCEL,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CREATE,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_DELETE,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_PERIOD,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_CREATE,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_DELETE,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_FLUSH,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_OBTAIN,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_RELEASE,
+  RTEMS_RECORD_RTEMS_TIMER_CANCEL,
+  RTEMS_RECORD_RTEMS_TIMER_CREATE,
+  RTEMS_RECORD_RTEMS_TIMER_DELETE,
+  RTEMS_RECORD_RTEMS_TIMER_FIRE_AFTER,
+  RTEMS_RECORD_RTEMS_TIMER_FIRE_WHEN,
+  RTEMS_RECORD_RTEMS_TIMER_RESET,
+  RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_AFTER,
+  RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_WHEN,
+  RTEMS_RECORD_SELECT,
+  RTEMS_RECORD_SEND,
+  RTEMS_RECORD_SENDMSG,
+  RTEMS_RECORD_SENDTO,
+  RTEMS_RECORD_SOCKET,
+  RTEMS_RECORD_STATVFS,
+  RTEMS_RECORD_SYMLINK,
+  RTEMS_RECORD_TAIL,
+  RTEMS_RECORD_THREAD_BEGIN,
+  RTEMS_RECORD_THREAD_CREATE,
+  RTEMS_RECORD_THREAD_DELETE,
+  RTEMS_RECORD_THREAD_EXIT,
+  RTEMS_RECORD_THREAD_EXITTED,
+  RTEMS_RECORD_THREAD_PRIO_CURRENT_HIGH,
+  RTEMS_RECORD_THREAD_PRIO_CURRENT_LOW,
+  RTEMS_RECORD_THREAD_PRIO_REAL_HIGH,
+  RTEMS_RECORD_THREAD_PRIO_REAL_LOW,
+  RTEMS_RECORD_THREAD_RESTART,
+  RTEMS_RECORD_THREAD_STACK_CURRENT,
+  RTEMS_RECORD_THREAD_STACK_SIZE,
+  RTEMS_RECORD_THREAD_STACK_USAGE,
+  RTEMS_RECORD_THREAD_START,
+  RTEMS_RECORD_THREAD_SWITCH_IN,
+  RTEMS_RECORD_THREAD_SWITCH_OUT,
+  RTEMS_RECORD_THREAD_TERMINATE,
+  RTEMS_RECORD_UMA_ALLOC_PTR,
+  RTEMS_RECORD_UMA_ALLOC_ZONE,
+  RTEMS_RECORD_UMA_FREE_PTR,
+  RTEMS_RECORD_UMA_FREE_ZONE,
+  RTEMS_RECORD_UNLINK,
+  RTEMS_RECORD_UNMOUNT,
+  RTEMS_RECORD_UPTIME_HIGH,
+  RTEMS_RECORD_UPTIME_LOW,
+  RTEMS_RECORD_WORKSPACE_ALLOC,
+  RTEMS_RECORD_WORKSPACE_FREE,
+  RTEMS_RECORD_WORKSPACE_SIZE,
+  RTEMS_RECORD_WORKSPACE_USAGE,
+  RTEMS_RECORD_WRITE,
+  RTEMS_RECORD_WRITEV,
+  /* There are 512 events reserved for the user */
+  RTEMS_RECORD_USER = 512,
+  RTEMS_RECORD_LAST = 1023
+} rtems_record_event;
+ * @brief Bits in the record item event member reserved for the actual event.
+#define RTEMS_RECORD_EVENT_BITS 10
+ * @brief Bits in the record item event member reserved for the time of the
+ * event.
+#define RTEMS_RECORD_TIME_BITS 22
+ * @brief Builds a time event for the specified time stamp and event.
+ * The events are stored in the record item with a time stamp.  There are 22
+ * bits allocated to the time stamp and 10 bits allocated to the event.  The 22
+ * bits are enough to get reliable time stamps on a system with a 4GHz CPU
+ * counter and a 1000Hz clock tick.
+#define RTEMS_RECORD_TIME_EVENT( time, event ) \
+  ( ( ( time ) << RTEMS_RECORD_EVENT_BITS ) | ( event ) )
+ * @brief Gets the time of a time event.
+#define RTEMS_RECORD_GET_TIME( time_event ) \
+  ( ( time_event ) >> RTEMS_RECORD_EVENT_BITS )
+ * @brief Gets the event of a time event.
+#define RTEMS_RECORD_GET_EVENT( time_event ) \
+  ( ( time_event ) & ( ( 1U << RTEMS_RECORD_EVENT_BITS ) - 1U ) )
+ * @brief The record data integer type.
+ * It is big enough to store 32-bit integers and pointers.
+typedef unsigned long rtems_record_data;
+ * @brief The native record item.
+typedef struct __attribute__((__packed__)) {
+  uint32_t          event;
+  rtems_record_data data;
+} rtems_record_item;
+ * @brief The 32-bit format record item.
+typedef struct {
+  uint32_t event;
+  uint32_t data;
+} rtems_record_item_32;
+ * @brief The 64-bit format record item.
+  uint32_t event;
+  uint64_t data;
+} rtems_record_item_64;
+const char *rtems_record_event_text( rtems_record_event event );
+#ifdef __cplusplus
+#endif /* _RTEMS_RECORDDATA_H */
diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
index 712d1cde36..22c5c30a00 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -69,6 +69,8 @@ extern "C" {
 #if !defined( ASM )
+struct Record_Control;
 struct _Thread_Control;
 struct Scheduler_Context;
@@ -513,6 +515,8 @@ typedef struct Per_CPU_Control {
     bool boot;
   #endif
+  struct Record_Control *record;
   Per_CPU_Stats Stats;
 } Per_CPU_Control;
diff --git a/cpukit/include/rtems/sysinit.h b/cpukit/include/rtems/sysinit.h
index 2c718af8de..60fd9ddf41 100644
--- a/cpukit/include/rtems/sysinit.h
+++ b/cpukit/include/rtems/sysinit.h
@@ -33,6 +33,7 @@ extern "C" {
 #define RTEMS_SYSINIT_MP_EARLY                   000500
 #define RTEMS_SYSINIT_DATA_STRUCTURES            000600
 #define RTEMS_SYSINIT_MP                         000700
+#define RTEMS_SYSINIT_RECORD                     000800
 #define RTEMS_SYSINIT_USER_EXTENSIONS            000900
 #define RTEMS_SYSINIT_CLASSIC_TASKS              000a00
 #define RTEMS_SYSINIT_CLASSIC_TIMER              000b00
diff --git a/cpukit/libmisc/record/record-client.c b/cpukit/libmisc/record/record-client.c
index 0000000000..6abda2b4c3
--- /dev/null
+++ b/cpukit/libmisc/record/record-client.c
@@ -0,0 +1,429 @@
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/recordclient.h>
+#include <string.h>
+static void set_to_bt_scaler(
+  uint32_t                     frequency
+  uint64_t bin_per_s;
+  bin_per_s = UINT64_C( 1 ) << 32;
+  ctx->to_bt_scaler = ( ( bin_per_s << 31 ) + frequency - 1 ) / frequency;
+static void check_overflow(
+  const rtems_record_client_context *ctx,
+  const rtems_record_client_per_cpu *per_cpu,
+  uint32_t                           new_head
+  uint32_t last_tail;
+  uint32_t last_head;
+  uint32_t capacity;
+  uint32_t new_content;
+  last_tail = per_cpu->tail[ per_cpu->index ];
+  last_head = per_cpu->head[ per_cpu->index ];
+  if ( last_tail == last_head ) {
+    return;
+  capacity = ( last_tail - last_head - 1 ) & ( ctx->count - 1 );
+  new_content = new_head - last_head;
+  if ( new_content <= capacity ) {
+    return;
+  ( *ctx->handler )(
+    0,
+    0,
+    ctx->cpu,
+    new_content - capacity,
+    ctx->handler_arg
+static rtems_record_client_status visit( rtems_record_client_context *ctx )
+  rtems_record_client_per_cpu *per_cpu;
+  uint32_t                     time;
+  rtems_record_event           event;
+  uint64_t                     data;
+  uint64_t                     bt;
+  uint32_t                     seconds;
+  uint32_t                     nanosec;
+  per_cpu = &ctx->per_cpu[ ctx->cpu ];
+  time = RTEMS_RECORD_GET_TIME( ctx->event );
+  event = RTEMS_RECORD_GET_EVENT( ctx->event );
+  data = ctx->data;
+  switch ( event ) {
+    case RTEMS_RECORD_PROCESSOR:
+      if ( data >= RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT ) {
+        return RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU;
+      ctx->cpu = (uint32_t) data;
+      break;
+    case RTEMS_RECORD_UPTIME_LOW:
+      per_cpu->uptime.bt = (uint32_t) data;
+      per_cpu->uptime.time = time;
+      time = 0;
+      break;
+    case RTEMS_RECORD_UPTIME_HIGH:
+      per_cpu->uptime.bt += (int64_t) data << 32;
+      time = 0;
+      break;
+    case RTEMS_RECORD_TAIL:
+      per_cpu->tail[ per_cpu->index ] = (uint32_t) data;
+      break;
+    case RTEMS_RECORD_HEAD:
+      per_cpu->head[ per_cpu->index ]= (uint32_t) data;
+      per_cpu->index ^= 1;
+      check_overflow( ctx, per_cpu, (uint32_t) data );
+      break;
+    case RTEMS_RECORD_COUNT:
+      ctx->count = (uint32_t) data;
+      break;
+    case RTEMS_RECORD_FREQUENCY:
+      set_to_bt_scaler( ctx, (uint32_t) data );
+      break;
+    case RTEMS_RECORD_VERSION:
+      if ( data != RTEMS_RECORD_THE_VERSION ) {
+        return RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION;
+      break;
+    default:
+      break;
+  if ( time != 0 ) {
+    time = ( time - per_cpu->uptime.time )
+      & ( ( UINT32_C( 1 ) << RTEMS_RECORD_TIME_BITS ) - 1 );
+    bt = ( time * ctx->to_bt_scaler ) >> 31;
+    bt += per_cpu->uptime.bt;
+  } else {
+    bt = 0;
+  seconds = (uint32_t) ( bt >> 32 );
+  nanosec = (uint32_t) ( ( UINT64_C( 1000000000 ) * (uint32_t) bt ) >> 32 );
+  return ( *ctx->handler )(
+    seconds,
+    nanosec,
+    ctx->cpu,
+    event,
+    data,
+    ctx->handler_arg
+static rtems_record_client_status consume_32(
+  const void                  *buf,
+  size_t                       n
+  while ( n > 0 ) {
+    size_t m;
+    char *pos;
+    m = ctx->todo < n ? ctx->todo : n;
+    pos = ctx->pos;
+    pos = memcpy( pos, buf, m );
+    n -= m;
+    buf = (char *) buf + m;
+    if ( m == ctx->todo ) {
+      rtems_record_client_status status;
+      ctx->todo = sizeof( ctx->item.format_32 );
+      ctx->pos = &ctx->item.format_32;
+      ctx->event = ctx->item.format_32.event;
+      ctx->data = ctx->item.format_32.data;
+      status = visit( ctx );
+      if ( status != RTEMS_RECORD_CLIENT_SUCCESS ) {
+        return status;
+    } else {
+      ctx->todo -= m;
+      ctx->pos = pos + m;
+  return RTEMS_RECORD_CLIENT_SUCCESS;
+static rtems_record_client_status consume_64(
+  const void                  *buf,
+  size_t                       n
+  while ( n > 0 ) {
+    size_t m;
+    char *pos;
+    pos = ctx->pos;
+    n -= m;
+      ctx->todo = sizeof( ctx->item.format_64 );
+      ctx->pos = &ctx->item.format_64;
+      ctx->event = ctx->item.format_64.event;
+      ctx->data = ctx->item.format_64.data;
+        return status;
+    } else {
+      ctx->todo -= m;
+static rtems_record_client_status consume_swap_32(
+  const void                  *buf,
+  size_t                       n
+  while ( n > 0 ) {
+    size_t m;
+    char *pos;
+    pos = ctx->pos;
+    n -= m;
+      ctx->event = __builtin_bswap32( ctx->item.format_32.event );
+      ctx->data = __builtin_bswap32( ctx->item.format_32.data );
+        return status;
+    } else {
+      ctx->todo -= m;
+static rtems_record_client_status consume_swap_64(
+  const void                  *buf,
+  size_t                       n
+  while ( n > 0 ) {
+    size_t m;
+    char *pos;
+    pos = ctx->pos;
+    n -= m;
+      ctx->event = __builtin_bswap32( ctx->item.format_64.event );
+      ctx->data = __builtin_bswap64( ctx->item.format_64.data );
+        return status;
+    } else {
+      ctx->todo -= m;
+static rtems_record_client_status consume_init(
+  const void                  *buf,
+  size_t                       n
+  while ( n > 0 ) {
+    size_t m;
+    char *pos;
+    pos = ctx->pos;
+    n -= m;
+      uint32_t magic;
+      magic = ctx->header[ 1 ];
+      switch ( ctx->header[ 0 ] ) {
+#if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__
+        case RTEMS_RECORD_FORMAT_LE_32:
+          ctx->consume = consume_32;
+          break;
+        case RTEMS_RECORD_FORMAT_LE_64:
+          ctx->consume = consume_64;
+          break;
+        case RTEMS_RECORD_FORMAT_BE_32:
+          ctx->consume = consume_swap_32;
+          magic = __builtin_bswap32( magic );
+          break;
+        case RTEMS_RECORD_FORMAT_BE_64:
+          ctx->consume = consume_swap_64;
+          break;
+#elif __BYTE_ORDER__ == __ORDER_BIG_ENDIAN__
+          break;
+          break;
+          break;
+          break;
+#else
+#error "unexpected __BYTE_ORDER__"
+#endif
+        default:
+          return RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT;
+      if ( magic != RTEMS_RECORD_MAGIC ) {
+        return RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC;
+      return rtems_record_client_run( ctx, buf, n );
+    } else {
+      ctx->todo -= m;
+  void                        *arg
+  ctx = memset( ctx, 0, sizeof( *ctx ) );
+  ctx->to_bt_scaler = UINT64_C( 1 ) << 31;
+  ctx->handler = handler;
+  ctx->handler_arg = arg;
+  ctx->todo = sizeof( ctx->header );
+  ctx->pos = &ctx->header;
+  ctx->consume = consume_init;
+  const void                  *buf,
+  size_t                       n
+  return ( *ctx->consume )( ctx, buf, n );
diff --git a/cpukit/libmisc/record/record-server.c b/cpukit/libmisc/record/record-server.c
index 0000000000..7a1959cefc
--- /dev/null
+++ b/cpukit/libmisc/record/record-server.c
@@ -0,0 +1,286 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/record.h>
+#include <rtems.h>
+#include <sys/endian.h>
+#include <sys/socket.h>
+#include <sys/uio.h>
+#include <unistd.h>
+#include <netinet/in.h>
+#ifdef RTEMS_SMP
+#define CHUNKS (3 * CPU_MAXIMUM_PROCESSORS)
+#else
+#define CHUNKS 4
+#endif
+typedef struct {
+  int           available;
+  struct iovec *current;
+  struct iovec  iov[CHUNKS];
+} writev_visitor_context;
+static void writev_visitor(
+  size_t                   count,
+  void                    *arg
+  writev_visitor_context *ctx;
+  ctx = arg;
+  if ( ctx->available > 0 ) {
+    ctx->current->iov_base = RTEMS_DECONST( rtems_record_item *, items );
+    ctx->current->iov_len = count * sizeof( *items );
+    --ctx->available;
+    ++ctx->current;
+  writev_visitor_context ctx;
+  int n;
+  ctx.available = CHUNKS;
+  ctx.current = &ctx.iov[ 0 ];
+  rtems_record_drain( writev_visitor, &ctx );
+  n = CHUNKS - ctx.available;
+  if ( n > 0 ) {
+    *written = true;
+    return writev( fd, &ctx.iov[ 0 ], n );
+  } else {
+    *written = false;
+    return 0;
+#define WAKEUP_EVENT RTEMS_EVENT_0
+static void wakeup( rtems_id task )
+  (void) rtems_event_send( task, WAKEUP_EVENT );
+static void wait( rtems_option options )
+  rtems_event_set events;
+  (void) rtems_event_receive(
+    WAKEUP_EVENT,
+    RTEMS_EVENT_ANY | options,
+    RTEMS_NO_TIMEOUT,
+    &events
+static void wakeup_timer( rtems_id timer, void *arg )
+  rtems_id *server;
+  server = arg;
+  wakeup( *server );
+  (void) rtems_timer_reset( timer );
+#if BYTE_ORDER == LITTLE_ENDIAN
+#if __INTPTR_WIDTH__ == 32
+  header->format = RTEMS_RECORD_FORMAT_LE_32,
+#elif __INTPTR_WIDTH__ == 64
+  header->format = RTEMS_RECORD_FORMAT_LE_64,
+#error "unexpected __INTPTR_WIDTH__"
+#endif
+#elif BYTE_ORDER == BIG_ENDIAN
+  header->format = RTEMS_RECORD_FORMAT_BE_32,
+  header->format = RTEMS_RECORD_FORMAT_BE_64,
+#else
+#endif
+#else
+#error "unexpected BYTE_ORDER"
+#endif
+  header->magic = RTEMS_RECORD_MAGIC;
+  header->Version.event = RTEMS_RECORD_TIME_EVENT( 0, RTEMS_RECORD_VERSION );
+  header->Version.data = RTEMS_RECORD_THE_VERSION;
+  header->Count.event = RTEMS_RECORD_TIME_EVENT( 0, RTEMS_RECORD_COUNT );
+  header->Count.data = _Record_Item_count;
+  header->Frequency.event =
+    RTEMS_RECORD_TIME_EVENT( 0, RTEMS_RECORD_FREQUENCY );
+  header->Frequency.data = rtems_counter_frequency();
+static void send_header( int fd )
+  Record_Stream_header header;
+  _Record_Stream_header_initialize( &header );
+  (void) write( fd, &header, sizeof( header ) );
+  rtems_status_code sc;
+  rtems_id self;
+  rtems_id timer;
+  struct sockaddr_in addr;
+  int sd;
+  int rv;
+  sd = -1;
+  self = rtems_task_self();
+  sc = rtems_timer_create( rtems_build_name( 'R', 'C', 'R', 'D' ), &timer );
+  if ( sc != RTEMS_SUCCESSFUL ) {
+    return;
+  sd = socket( PF_INET, SOCK_STREAM, 0 );
+  if (sd < 0) {
+    goto error;
+  memset( &addr, 0, sizeof( addr ) );
+  addr.sin_family = AF_INET;
+  addr.sin_port = htons( port );
+  addr.sin_addr.s_addr = htonl( INADDR_ANY );
+  rv = bind( sd, (const struct sockaddr *) &addr, sizeof( addr ) );
+  if (rv != 0) {
+    goto error;
+  rv = listen( sd, 0 );
+  if (rv != 0) {
+    goto error;
+  while ( true ) {
+    int cd;
+    bool written;
+    ssize_t n;
+    cd = accept( sd, NULL, NULL );
+    if ( cd < 0 ) {
+      break;
+    wait( RTEMS_NO_WAIT );
+    (void) rtems_timer_fire_after( timer, period, wakeup_timer, &self );
+    send_header( cd );
+    while ( true ) {
+      n = rtems_record_writev( cd, &written );
+      if ( written && n <= 0 ) {
+        break;
+      wait( RTEMS_WAIT );
+    (void) rtems_timer_cancel( timer );
+    (void) close( cd );
+error:
+  (void) close( sd );
+  (void) rtems_timer_delete( timer );
+typedef struct {
+  rtems_id       task;
+  uint16_t       port;
+  rtems_interval period;
+} server_arg;
+static void server( rtems_task_argument arg )
+  server_arg     *sarg;
+  uint16_t        port;
+  sarg = (server_arg *) arg;
+  port = sarg->port;
+  period = sarg->period;
+  wakeup(sarg->task);
+  rtems_record_server( port, period );
+  rtems_task_exit();
+  uint16_t            port,
+  rtems_id          id;
+  server_arg        sarg;
+  sarg.port = port;
+  sarg.period = period;
+  sarg.task = rtems_task_self();
+  sc = rtems_task_create(
+    rtems_build_name( 'R', 'C', 'R', 'D' ),
+    priority,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &id
+    return sc;
+  (void) rtems_task_start( id, server, (rtems_task_argument) &sarg );
+  return RTEMS_SUCCESSFUL;
diff --git a/cpukit/libmisc/record/record-static.c b/cpukit/libmisc/record/record-static.c
index 0000000000..b96ae6d0b1
--- /dev/null
+++ b/cpukit/libmisc/record/record-static.c
@@ -0,0 +1,131 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/config.h>
+#include <rtems/sysinit.h>
+#include <rtems/score/timecounter.h>
+#include <rtems/score/watchdogimpl.h>
+static Watchdog_Interval _Record_Tick_interval;
+  uint32_t  cpu_max;
+  uint32_t  cpu_index;
+  uintptr_t offset;
+  cpu_max = rtems_configuration_get_maximum_processors();
+  offset = PER_CPU_DATA_OFFSET( _Record_Per_CPU );
+  for ( cpu_index = 0; cpu_index < cpu_max; ++cpu_index ) {
+    Per_CPU_Control *cpu;
+    cpu = _Per_CPU_Get_by_index( cpu_index );
+    control = PER_CPU_DATA_GET_BY_OFFSET( cpu, Record_Control, offset );
+    control->mask = _Record_Item_count - 1U;
+    cpu->record = control;
+static void _Record_Watchdog(
+  Watchdog_Control *watchdog,
+  ISR_Level  level;
+  sbintime_t now;
+  _ISR_Local_disable( level );
+  _Watchdog_Per_CPU_reinsert_ticks(
+    watchdog,
+    cpu,
+    _Record_Tick_interval
+  _ISR_Local_enable( level );
+  now = _Timecounter_Sbinuptime();
+  rtems_record_produce_2(
+    (uint32_t) ( now >> 0 ),
+    (uint32_t) ( now >> 32 )
+static void _Record_Initialize_watchdogs( void )
+  Watchdog_Interval interval;
+  uint32_t          cpu_max;
+  sbintime_t        now;
+  interval = rtems_counter_frequency() / _Watchdog_Ticks_per_second;
+  interval = ( UINT32_C( 1 ) << 22 ) / interval;
+  if ( interval == 0 ) {
+    interval = 1;
+  _Record_Tick_interval = interval;
+    control = cpu->record;
+    _Watchdog_Preinitialize( &control->Watchdog, cpu );
+    _Watchdog_Initialize( &control->Watchdog, _Record_Watchdog );
+      &control->Watchdog,
+      cpu,
+RTEMS_SYSINIT_ITEM(
+  _Record_Initialize_watchdogs,
+  RTEMS_SYSINIT_DEVICE_DRIVERS,
+  RTEMS_SYSINIT_ORDER_LAST
diff --git a/cpukit/libmisc/record/record-text.c b/cpukit/libmisc/record/record-text.c
index 0000000000..cc41647a0d
--- /dev/null
+++ b/cpukit/libmisc/record/record-text.c
@@ -0,0 +1,173 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/recorddata.h>
+static const char * const event_text[] = {
+  [ RTEMS_RECORD_EMPTY ] = "EMPTY",
+  [ RTEMS_RECORD_VERSION ] = "VERSION",
+  [ RTEMS_RECORD_ACCEPT ] = "ACCEPT",
+  [ RTEMS_RECORD_BIND ] = "BIND",
+  [ RTEMS_RECORD_CHOWN ] = "CHOWN",
+  [ RTEMS_RECORD_CLOSE ] = "CLOSE",
+  [ RTEMS_RECORD_CONNECT ] = "CONNECT",
+  [ RTEMS_RECORD_COUNT ] = "COUNT",
+  [ RTEMS_RECORD_FCHMOD ] = "FCHMOD",
+  [ RTEMS_RECORD_FCNTL ] = "FCNTL",
+  [ RTEMS_RECORD_FDATASYNC ] = "FDATASYNC",
+  [ RTEMS_RECORD_FREQUENCY ] = "FREQUENCY",
+  [ RTEMS_RECORD_FSTAT ] = "FSTAT",
+  [ RTEMS_RECORD_FSYNC ] = "FSYNC",
+  [ RTEMS_RECORD_FTRUNCATE ] = "FTRUNCATE",
+  [ RTEMS_RECORD_HEAD ] = "HEAD",
+  [ RTEMS_RECORD_HEAP_ALLOC ] = "HEAP_ALLOC",
+  [ RTEMS_RECORD_HEAP_FREE ] = "HEAP_FREE",
+  [ RTEMS_RECORD_HEAP_SIZE ] = "HEAP_SIZE",
+  [ RTEMS_RECORD_HEAP_USAGE ] = "HEAP_USAGE",
+  [ RTEMS_RECORD_INTERUPT_BEGIN ] = "INTERUPT_BEGIN",
+  [ RTEMS_RECORD_INTERUPT_END ] = "INTERUPT_END",
+  [ RTEMS_RECORD_INTERUPT_INSTALL ] = "INTERUPT_INSTALL",
+  [ RTEMS_RECORD_INTERUPT_REMOVE ] = "INTERUPT_REMOVE",
+  [ RTEMS_RECORD_IOCTL ] = "IOCTL",
+  [ RTEMS_RECORD_KEVENT ] = "KEVENT",
+  [ RTEMS_RECORD_KQUEUE ] = "KQUEUE",
+  [ RTEMS_RECORD_LINK ] = "LINK",
+  [ RTEMS_RECORD_LSEEK ] = "LSEEK",
+  [ RTEMS_RECORD_MKNOD ] = "MKNOD",
+  [ RTEMS_RECORD_MMAP ] = "MMAP",
+  [ RTEMS_RECORD_MOUNT ] = "MOUNT",
+  [ RTEMS_RECORD_OPEN ] = "OPEN",
+  [ RTEMS_RECORD_OVERFLOW ] = "OVERFLOW",
+  [ RTEMS_RECORD_POLL ] = "POLL",
+  [ RTEMS_RECORD_PROCESSOR ] = "PROCESSOR",
+  [ RTEMS_RECORD_READ ] = "READ",
+  [ RTEMS_RECORD_READLINK ] = "READLINK",
+  [ RTEMS_RECORD_READV ] = "READV",
+  [ RTEMS_RECORD_RECV ] = "RECV",
+  [ RTEMS_RECORD_RECVFROM ] = "RECVFROM",
+  [ RTEMS_RECORD_RECVMSG ] = "RECVMSG",
+  [ RTEMS_RECORD_RENAME ] = "RENAME",
+  [ RTEMS_RECORD_RTEMS_BARRIER_CREATE ] = "RTEMS_BARRIER_CREATE",
+  [ RTEMS_RECORD_RTEMS_BARRIER_DELETE ] = "RTEMS_BARRIER_DELETE",
+  [ RTEMS_RECORD_RTEMS_BARRIER_RELEASE ] = "RTEMS_BARRIER_RELEASE",
+  [ RTEMS_RECORD_RTEMS_BARRIER_WAIT ] = "RTEMS_BARRIER_WAIT",
+  [ RTEMS_RECORD_RTEMS_EVENT_RECEIVE ] = "RTEMS_EVENT_RECEIVE",
+  [ RTEMS_RECORD_RTEMS_EVENT_SEND ] = "RTEMS_EVENT_SEND",
+  [ RTEMS_RECORD_RTEMS_EVENT_SYSTEM_RECEIVE ] = "RTEMS_EVENT_SYSTEM_RECEIVE",
+  [ RTEMS_RECORD_RTEMS_EVENT_SYSTEM_SEND ] = "RTEMS_EVENT_SYSTEM_SEND",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_BROADCAST ] = "RTEMS_MESSAGE_QUEUE_BROADCAST",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_CREATE ] = "RTEMS_MESSAGE_QUEUE_CREATE",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_DELETE ] = "RTEMS_MESSAGE_QUEUE_DELETE",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_FLUSH ] = "RTEMS_MESSAGE_QUEUE_FLUSH",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_RECEIVE ] = "RTEMS_MESSAGE_QUEUE_RECEIVE",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_SEND ] = "RTEMS_MESSAGE_QUEUE_SEND",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_URGENT ] = "RTEMS_MESSAGE_QUEUE_URGENT",
+  [ RTEMS_RECORD_RTEMS_PARTITION_CREATE ] = "RTEMS_PARTITION_CREATE",
+  [ RTEMS_RECORD_RTEMS_PARTITION_DELETE ] = "RTEMS_PARTITION_DELETE",
+  [ RTEMS_RECORD_RTEMS_PARTITION_GET_BUFFER ] = "RTEMS_PARTITION_GET_BUFFER",
+  [ RTEMS_RECORD_RTEMS_PARTITION_RETURN_BUFFER ] = "RTEMS_PARTITION_RETURN_BUFFER",
+  [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CANCEL ] = "RTEMS_RATE_MONOTONIC_CANCEL",
+  [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CREATE ] = "RTEMS_RATE_MONOTONIC_CREATE",
+  [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_DELETE ] = "RTEMS_RATE_MONOTONIC_DELETE",
+  [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_PERIOD ] = "RTEMS_RATE_MONOTONIC_PERIOD",
+  [ RTEMS_RECORD_RTEMS_SEMAPHORE_CREATE ] = "RTEMS_SEMAPHORE_CREATE",
+  [ RTEMS_RECORD_RTEMS_SEMAPHORE_DELETE ] = "RTEMS_SEMAPHORE_DELETE",
+  [ RTEMS_RECORD_RTEMS_SEMAPHORE_FLUSH ] = "RTEMS_SEMAPHORE_FLUSH",
+  [ RTEMS_RECORD_RTEMS_SEMAPHORE_OBTAIN ] = "RTEMS_SEMAPHORE_OBTAIN",
+  [ RTEMS_RECORD_RTEMS_SEMAPHORE_RELEASE ] = "RTEMS_SEMAPHORE_RELEASE",
+  [ RTEMS_RECORD_RTEMS_TIMER_CANCEL ] = "RTEMS_TIMER_CANCEL",
+  [ RTEMS_RECORD_RTEMS_TIMER_CREATE ] = "RTEMS_TIMER_CREATE",
+  [ RTEMS_RECORD_RTEMS_TIMER_DELETE ] = "RTEMS_TIMER_DELETE",
+  [ RTEMS_RECORD_RTEMS_TIMER_FIRE_AFTER ] = "RTEMS_TIMER_FIRE_AFTER",
+  [ RTEMS_RECORD_RTEMS_TIMER_FIRE_WHEN ] = "RTEMS_TIMER_FIRE_WHEN",
+  [ RTEMS_RECORD_RTEMS_TIMER_RESET ] = "RTEMS_TIMER_RESET",
+  [ RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_AFTER ] = "RTEMS_TIMER_SERVER_FIRE_AFTER",
+  [ RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_WHEN ] = "RTEMS_TIMER_SERVER_FIRE_WHEN",
+  [ RTEMS_RECORD_SELECT ] = "SELECT",
+  [ RTEMS_RECORD_SEND ] = "SEND",
+  [ RTEMS_RECORD_SENDMSG ] = "SENDMSG",
+  [ RTEMS_RECORD_SENDTO ] = "SENDTO",
+  [ RTEMS_RECORD_SOCKET ] = "SOCKET",
+  [ RTEMS_RECORD_STATVFS ] = "STATVFS",
+  [ RTEMS_RECORD_SYMLINK ] = "SYMLINK",
+  [ RTEMS_RECORD_TAIL ] = "TAIL",
+  [ RTEMS_RECORD_THREAD_BEGIN ] = "THREAD_BEGIN",
+  [ RTEMS_RECORD_THREAD_CREATE ] = "THREAD_CREATE",
+  [ RTEMS_RECORD_THREAD_DELETE ] = "THREAD_DELETE",
+  [ RTEMS_RECORD_THREAD_EXIT ] = "THREAD_EXIT",
+  [ RTEMS_RECORD_THREAD_EXITTED ] = "THREAD_EXITTED",
+  [ RTEMS_RECORD_THREAD_PRIO_CURRENT_HIGH ] = "THREAD_PRIO_CURRENT_HIGH",
+  [ RTEMS_RECORD_THREAD_PRIO_CURRENT_LOW ] = "THREAD_PRIO_CURRENT_LOW",
+  [ RTEMS_RECORD_THREAD_PRIO_REAL_HIGH ] = "THREAD_PRIO_REAL_HIGH",
+  [ RTEMS_RECORD_THREAD_PRIO_REAL_LOW ] = "THREAD_PRIO_REAL_LOW",
+  [ RTEMS_RECORD_THREAD_RESTART ] = "THREAD_RESTART",
+  [ RTEMS_RECORD_THREAD_STACK_CURRENT ] = "THREAD_STACK_CURRENT",
+  [ RTEMS_RECORD_THREAD_STACK_SIZE ] = "THREAD_STACK_SIZE",
+  [ RTEMS_RECORD_THREAD_STACK_USAGE ] = "THREAD_STACK_USAGE",
+  [ RTEMS_RECORD_THREAD_START ] = "THREAD_START",
+  [ RTEMS_RECORD_THREAD_SWITCH_IN ] = "THREAD_SWITCH_IN",
+  [ RTEMS_RECORD_THREAD_SWITCH_OUT ] = "THREAD_SWITCH_OUT",
+  [ RTEMS_RECORD_THREAD_TERMINATE ] = "THREAD_TERMINATE",
+  [ RTEMS_RECORD_UMA_ALLOC_PTR ] = "UMA_ALLOC_PTR",
+  [ RTEMS_RECORD_UMA_ALLOC_ZONE ] = "UMA_ALLOC_ZONE",
+  [ RTEMS_RECORD_UMA_FREE_PTR ] = "UMA_FREE_PTR",
+  [ RTEMS_RECORD_UMA_FREE_ZONE ] = "UMA_FREE_ZONE",
+  [ RTEMS_RECORD_UNLINK ] = "UNLINK",
+  [ RTEMS_RECORD_UNMOUNT ] = "UNMOUNT",
+  [ RTEMS_RECORD_UPTIME_HIGH ] = "UPTIME_HIGH",
+  [ RTEMS_RECORD_UPTIME_LOW ] = "UPTIME_LOW",
+  [ RTEMS_RECORD_WORKSPACE_ALLOC ] = "WORKSPACE_ALLOC",
+  [ RTEMS_RECORD_WORKSPACE_FREE ] = "WORKSPACE_FREE",
+  [ RTEMS_RECORD_WORKSPACE_SIZE ] = "WORKSPACE_SIZE",
+  [ RTEMS_RECORD_WORKSPACE_USAGE ] = "WORKSPACE_USAGE",
+  [ RTEMS_RECORD_WRITE ] = "WRITE",
+  [ RTEMS_RECORD_WRITEV ] = "WRITEV"
+  size_t n;
+  n = event;
+  if ( n < sizeof( event_text ) / sizeof( event_text[ 0 ] ) ) {
+    return event_text[ n ];
+  return NULL;
diff --git a/cpukit/libmisc/record/record-userext.c b/cpukit/libmisc/record/record-userext.c
index 0000000000..3d30620e5c
--- /dev/null
+++ b/cpukit/libmisc/record/record-userext.c
@@ -0,0 +1,125 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/score/thread.h>
+  rtems_record_produce(
+    created->Object.id
+  return true;
+    started->Object.id
+    restarted->Object.id
+    deleted->Object.id
+  rtems_record_item items[ 3 ];
+  items[ 0 ].event = RTEMS_RECORD_THREAD_SWITCH_OUT;
+  items[ 0 ].data = executing->Object.id;
+  items[ 1 ].event = RTEMS_RECORD_THREAD_STACK_CURRENT;
+  items[ 1 ].data =
+#if defined(__GNUC__)
+    (uintptr_t) __builtin_frame_address( 0 )
+      - (uintptr_t) executing->Start.Initial_stack.area;
+#else
+    0;
+#endif
+  items[ 2 ].event = RTEMS_RECORD_THREAD_SWITCH_IN;
+  items[ 2 ].data = heir->Object.id;
+  rtems_record_produce_n( items, RTEMS_ARRAY_SIZE( items ) );
+    executing->Object.id
+void _Record_Thread_terminate( struct _Thread_Control *executing )
diff --git a/cpukit/libmisc/record/record.c b/cpukit/libmisc/record/record.c
index 0000000000..3f1751de1c
--- /dev/null
+++ b/cpukit/libmisc/record/record.c
@@ -0,0 +1,132 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/score/assert.h>
+  rtems_record_context context;
+  rtems_record_prepare( &context );
+  rtems_record_add( &context, event, data );
+  rtems_record_commit( &context );
+  rtems_record_add( &context, event_0, data_0 );
+  rtems_record_add( &context, event_1, data_1 );
+  size_t                   n
+  _Assert( n > 0 );
+  do {
+    rtems_record_add( &context, items->event, items->data );
+    ++items;
+    --n;
+  } while ( n > 0 );
+  uint32_t cpu_max;
+    tail = _Record_Tail( control );
+    head = _Atomic_Load_uint( &control->head, ATOMIC_ORDER_ACQUIRE );
+    if ( tail == head ) {
+      continue;
+    control->tail = head;
+    control->Header[ 0 ].event = RTEMS_RECORD_PROCESSOR;
+    control->Header[ 0 ].data = cpu_index;
+    control->Header[ 1 ].event = RTEMS_RECORD_TAIL;
+    control->Header[ 1 ].data = tail;
+    control->Header[ 2 ].event = RTEMS_RECORD_HEAD;
+    control->Header[ 2 ].data = head;
+    ( *visitor )( control->Header, RTEMS_ARRAY_SIZE( control->Header ), arg );
+    if ( _Record_Is_overflow( control, tail, head ) ) {
+      tail = head + 1;
+    tail = _Record_Index( control, tail );
+    head = _Record_Index( control, head );
+    if ( tail < head ) {
+      ( *visitor )( &control->Items[ tail ], head - tail, arg );
+    } else {
+      ( *visitor )( &control->Items[ tail ], control->mask + 1 - tail, arg );
+      if ( head > 0 ) {
+        ( *visitor )( &control->Items[ 0 ], head, arg );
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index 810f65db8e..765096c443 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -994,6 +994,24 @@ realloc_norun_SOURCES = POSIX/realloc.c
 realloc_norun_LDADD = $(RTEMS_ROOT)cpukit/librtemsdefaultconfig.a $(LDADD)
 endif
+if TEST_record01
+lib_tests += record01
+lib_screens += record01/record01.scn
+lib_docs += record01/record01.doc
+record01_SOURCES = record01/init.c
+record01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_record01) \
+	$(support_includes) -I$(RTEMS_SOURCE_ROOT)/cpukit/libnetworking
+endif
+if TEST_record02
+lib_tests += record02
+lib_screens += record02/record02.scn
+lib_docs += record02/record02.doc
+record02_SOURCES = record02/init.c
+record02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_record02) \
+endif
 if TEST_rtmonuse
 lib_tests += rtmonuse
 lib_screens += rtmonuse/rtmonuse.scn
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index a2a0df01f1..c76fb799b4 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -189,6 +189,8 @@ RTEMS_TEST_CHECK([rbheap01])
 RTEMS_TEST_CHECK([read])
 RTEMS_TEST_CHECK([readv])
 RTEMS_TEST_CHECK([realloc])
+RTEMS_TEST_CHECK([record01])
+RTEMS_TEST_CHECK([record02])
 RTEMS_TEST_CHECK([rtmonuse])
 RTEMS_TEST_CHECK([setjmp])
 RTEMS_TEST_CHECK([sha])
diff --git a/testsuites/libtests/record01/init.c b/testsuites/libtests/record01/init.c
index 0000000000..f172332408
--- /dev/null
+++ b/testsuites/libtests/record01/init.c
@@ -0,0 +1,709 @@
+ * are met:
+#ifdef HAVE_CONFIG_H
+#endif
+#include <rtems.h>
+#ifdef RTEMS_NETWORKING
+#include <rtems/rtems_bsdnet.h>
+#endif
+#include <tmacros.h>
+const char rtems_test_name[] = "RECORD 1";
+#define ITEM_COUNT 4
+#define ITEM_SIZE (ITEM_COUNT * sizeof(rtems_record_item))
+typedef struct {
+  Record_Control control;
+  rtems_record_item items[ITEM_COUNT];
+} test_context;
+static test_context test_instance;
+const unsigned int _Record_Item_count = ITEM_COUNT;
+#define UE(user) (RTEMS_RECORD_USER + (user))
+#define TE(t, e) RTEMS_RECORD_TIME_EVENT(t, e)
+static const rtems_record_item expected_items_0[ITEM_COUNT] = {
+  { .event = TE(2, UE(1)), .data = 3 }
+static const rtems_record_item expected_items_1[ITEM_COUNT] = {
+  { .event = TE(2, UE(1)), .data = 3 },
+  { .event = TE(6, UE(5)), .data = 7 }
+static const rtems_record_item expected_items_2[ITEM_COUNT] = {
+  { .event = TE(6, UE(5)), .data = 7 },
+  { .event = TE(10, UE(9)), .data = 11 }
+static const rtems_record_item expected_items_3[ITEM_COUNT] = {
+  { .event = TE(10, UE(9)), .data = 11 },
+  { .event = TE(14, UE(13)), .data = 15 }
+static const rtems_record_item expected_items_4[ITEM_COUNT] = {
+  { .event = TE(18, UE(17)), .data = 19 },
+static const rtems_record_item expected_items_5[ITEM_COUNT] = {
+static const rtems_record_item expected_items_6[ITEM_COUNT] = {
+static const rtems_record_item expected_items_7[ITEM_COUNT] = {
+static const rtems_record_item expected_items_8[] = {
+  { .event = TE(0, RTEMS_RECORD_PROCESSOR), .data = 0 },
+  { .event = TE(0, RTEMS_RECORD_TAIL), .data = 0 },
+  { .event = TE(0, RTEMS_RECORD_HEAD), .data = 3 },
+  { .event = TE(5, UE(4)), .data = 6 },
+  { .event = TE(8, UE(7)), .data = 9 }
+static const rtems_record_item expected_items_9[] = {
+  { .event = TE(0, RTEMS_RECORD_TAIL), .data = 3 },
+  { .event = TE(0, RTEMS_RECORD_HEAD), .data = 5 },
+  { .event = TE(11, UE(10)), .data = 12 },
+static const rtems_record_item expected_items_10[] = {
+  { .event = TE(0, RTEMS_RECORD_TAIL), .data = 5 },
+  { .event = TE(0, RTEMS_RECORD_HEAD), .data = 8 },
+  { .event = TE(17, UE(16)), .data = 18 },
+  { .event = TE(20, UE(19)), .data = 21 },
+  { .event = TE(23, UE(22)), .data = 24 }
+static const rtems_record_item expected_items_11[] = {
+  { .event = TE(0, RTEMS_RECORD_TAIL), .data = 8 },
+  { .event = TE(0, RTEMS_RECORD_HEAD), .data = 9 },
+  { .event = TE(26, UE(25)), .data = 27 }
+static const rtems_record_item expected_items_12[] = {
+  { .event = TE(0, RTEMS_RECORD_TAIL), .data = 9 },
+  { .event = TE(0, RTEMS_RECORD_HEAD), .data = 15 },
+  { .event = TE(38, UE(37)), .data = 39 },
+  { .event = TE(41, UE(40)), .data = 42 },
+  { .event = TE(44, UE(43)), .data = 45 }
+static void init_context(test_context *ctx)
+  memset(ctx, 0, sizeof(*ctx));
+  ctx->control.mask = ITEM_COUNT - 1;
+static void test_capacity(const Record_Control *control)
+  unsigned int capacity;
+  capacity = _Record_Capacity(control, 0, 0);
+  rtems_test_assert(capacity == 3);
+  capacity = _Record_Capacity(control, 0, 1);
+  rtems_test_assert(capacity == 2);
+  capacity = _Record_Capacity(control, 0, 2);
+  rtems_test_assert(capacity == 1);
+  capacity = _Record_Capacity(control, 0, 3);
+  rtems_test_assert(capacity == 0);
+  capacity = _Record_Capacity(control, 3, 3);
+  capacity = _Record_Capacity(control, 3, 0);
+  capacity = _Record_Capacity(control, 3, 1);
+  capacity = _Record_Capacity(control, 3, 2);
+static void test_index(const Record_Control *control)
+  unsigned int index;
+  index = _Record_Index(control, 0);
+  rtems_test_assert(index == 0);
+  index = _Record_Index(control, 1);
+  rtems_test_assert(index == 1);
+  index = _Record_Index(control, 2);
+  rtems_test_assert(index == 2);
+  index = _Record_Index(control, 3);
+  rtems_test_assert(index == 3);
+  index = _Record_Index(control, 4);
+static void test_add_2_items(test_context *ctx, Record_Control *control)
+  rtems_record_context rc;
+  init_context(ctx);
+  rtems_record_prepare(&rc);
+  rtems_test_assert(rc.control == control);
+  rtems_test_assert(rc.head == 0);
+  rtems_test_assert(_Record_Head(control) == 0);
+  rtems_test_assert(_Record_Tail(control) == 0);
+  rc.now = RTEMS_RECORD_TIME_EVENT(2, 0);
+  rtems_record_add(&rc, UE(1), 3);
+  rtems_test_assert(rc.head == 1);
+  rtems_test_assert(memcmp(control->Items, expected_items_0, ITEM_SIZE) == 0);
+  rc.now = RTEMS_RECORD_TIME_EVENT(6, 0);
+  rtems_record_add(&rc, UE(5), 7);
+  rtems_record_commit(&rc);
+  rtems_test_assert(rc.head == 2);
+  rtems_test_assert(memcmp(control->Items, expected_items_1, ITEM_SIZE) == 0);
+  rtems_test_assert(_Record_Head(control) == 2);
+static void test_add_3_items(test_context *ctx, Record_Control *control)
+  rtems_test_assert(memcmp(control->Items, expected_items_5, ITEM_SIZE) == 0);
+  rtems_test_assert(memcmp(control->Items, expected_items_6, ITEM_SIZE) == 0);
+  rc.now = RTEMS_RECORD_TIME_EVENT(10, 0);
+  rtems_record_add(&rc, UE(9), 11);
+  rtems_test_assert(rc.head == 3);
+  rtems_test_assert(memcmp(control->Items, expected_items_7, ITEM_SIZE) == 0);
+  rtems_test_assert(_Record_Head(control) == 3);
+static void set_time(rtems_record_item *item, uint32_t time)
+  uint32_t event;
+  event = item->event;
+  event &= 0x3ff;
+  event |= time << 10;
+  item->event = event;
+static void test_produce(test_context *ctx, Record_Control *control)
+  rtems_record_produce(UE(1), 3);
+  set_time(&control->Items[0], 2);
+  rtems_test_assert(_Record_Head(control) == 1);
+  rtems_record_produce(UE(5), 7);
+  set_time(&control->Items[1], 6);
+  rtems_record_produce(UE(9), 11);
+  set_time(&control->Items[2], 10);
+  rtems_test_assert(memcmp(control->Items, expected_items_2, ITEM_SIZE) == 0);
+  rtems_record_produce(UE(13), 15);
+  set_time(&control->Items[3], 14);
+  rtems_test_assert(memcmp(control->Items, expected_items_3, ITEM_SIZE) == 0);
+  rtems_test_assert(_Record_Head(control) == 4);
+  rtems_record_produce(UE(17), 19);
+  set_time(&control->Items[0], 18);
+  rtems_test_assert(memcmp(control->Items, expected_items_4, ITEM_SIZE) == 0);
+  rtems_test_assert(_Record_Head(control) == 5);
+static void test_produce_2(test_context *ctx, Record_Control *control)
+  rtems_record_produce_2(UE(1), 3, UE(5), 7);
+  rtems_record_produce_2(UE(13), 15, UE(17), 19);
+static void test_produce_n(test_context *ctx, Record_Control *control)
+  rtems_record_item items[5];
+  items[0].event = UE(1);
+  items[0].data = 3;
+  items[1].event = UE(5);
+  items[1].data = 7;
+  items[2].event = UE(9);
+  items[2].data = 11;
+  items[3].event = UE(13);
+  items[3].data = 15;
+  items[4].event = UE(17);
+  items[4].data = 19;
+  rtems_record_produce_n(items, RTEMS_ARRAY_SIZE(items));
+typedef struct {
+  size_t todo;
+  const rtems_record_item *items;
+} visitor_context;
+static void visitor(const rtems_record_item *items, size_t count, void *arg)
+  visitor_context *vctx;
+  vctx = arg;
+  rtems_test_assert(vctx->todo >= count);
+  while (count > 0) {
+    rtems_test_assert(memcmp(items, vctx->items, sizeof(*items)) == 0);
+    ++items;
+    ++vctx->items;
+    --count;
+    --vctx->todo;
+static void test_drain(test_context *ctx, Record_Control *control)
+  visitor_context vctx;
+  vctx.todo = 0;
+  vctx.items = NULL;
+  rtems_record_drain(visitor, &vctx);
+  rtems_test_assert(vctx.todo == 0);
+  rtems_record_produce(UE(4), 6);
+  set_time(&control->Items[1], 5);
+  rtems_record_produce(UE(7), 9);
+  set_time(&control->Items[2], 8);
+  vctx.todo = RTEMS_ARRAY_SIZE(expected_items_8);
+  vctx.items = expected_items_8;
+  vctx.todo = 0;
+  rtems_record_produce(UE(10), 12);
+  set_time(&control->Items[3], 11);
+  set_time(&control->Items[0], 14);
+  vctx.todo = RTEMS_ARRAY_SIZE(expected_items_9);
+  vctx.items = expected_items_9;
+  vctx.todo = 0;
+  rtems_record_produce(UE(16), 18);
+  set_time(&control->Items[1], 17);
+  rtems_record_produce(UE(19), 21);
+  set_time(&control->Items[2], 20);
+  rtems_record_produce(UE(22), 24);
+  set_time(&control->Items[3], 23);
+  vctx.todo = RTEMS_ARRAY_SIZE(expected_items_10);
+  vctx.items = expected_items_10;
+  vctx.todo = 0;
+  rtems_record_produce(UE(25), 27);
+  set_time(&control->Items[0], 26);
+  vctx.todo = RTEMS_ARRAY_SIZE(expected_items_11);
+  vctx.items = expected_items_11;
+  vctx.todo = 0;
+  rtems_record_produce(UE(28), 30);
+  set_time(&control->Items[1], 29);
+  rtems_record_produce(UE(31), 33);
+  set_time(&control->Items[2], 32);
+  rtems_record_produce(UE(34), 36);
+  set_time(&control->Items[3], 35);
+  rtems_record_produce(UE(37), 39);
+  set_time(&control->Items[0], 38);
+  rtems_record_produce(UE(40), 42);
+  set_time(&control->Items[1], 41);
+  rtems_record_produce(UE(43), 45);
+  set_time(&control->Items[2], 44);
+  vctx.todo = RTEMS_ARRAY_SIZE(expected_items_12);
+  vctx.items = expected_items_12;
+  vctx.todo = 0;
+#define PORT 1234
+static uint32_t get_format(void)
+  uint32_t format;
+  format = RTEMS_RECORD_FORMAT_LE_32;
+  format = RTEMS_RECORD_FORMAT_LE_64;
+#else
+#endif
+  format = RTEMS_RECORD_FORMAT_BE_32;
+  format = RTEMS_RECORD_FORMAT_BE_64;
+#else
+#endif
+#else
+#endif
+  return format;
+static int connect_client(void)
+  int fd;
+  int rv;
+  ssize_t n;
+  uint32_t v;
+  rtems_record_item item;
+  fd = socket(PF_INET, SOCK_STREAM, 0);
+  rtems_test_assert(fd >= 0);
+  memset(&addr, 0, sizeof(addr));
+  addr.sin_port = htons(PORT);
+  addr.sin_addr.s_addr = htonl(INADDR_ANY);
+  rv = connect(fd, (struct sockaddr *) &addr, sizeof(addr));
+  rtems_test_assert(rv == 0);
+  n = read(fd, &v, sizeof(v));
+  rtems_test_assert(n == 4);
+  rtems_test_assert(v == get_format());
+  rtems_test_assert(v == RTEMS_RECORD_MAGIC);
+  n = read(fd, &item, sizeof(item));
+  rtems_test_assert(n == (ssize_t) sizeof(item));
+  rtems_test_assert(item.event == TE(0, RTEMS_RECORD_VERSION));
+  rtems_test_assert(item.data == RTEMS_RECORD_THE_VERSION);
+  rtems_test_assert(item.event == TE(0, RTEMS_RECORD_COUNT));
+  rtems_test_assert(item.data == ITEM_COUNT);
+  rtems_test_assert(item.event == TE(0, RTEMS_RECORD_FREQUENCY));
+  rtems_test_assert(item.data == rtems_counter_frequency());
+  return fd;
+static void produce_and_read(int fd, Record_Control *control)
+  rtems_record_item items[6];
+  ssize_t n;
+  n = read(fd, items, sizeof(expected_items_8));
+  rtems_test_assert(n == (ssize_t) sizeof(expected_items_8));
+    memcmp(items, expected_items_8, sizeof(expected_items_8)) == 0
+  n = read(fd, items, sizeof(expected_items_9));
+  rtems_test_assert(n == (ssize_t) sizeof(expected_items_9));
+    memcmp(items, expected_items_9, sizeof(expected_items_9)) == 0
+  n = read(fd, items, sizeof(expected_items_10));
+  rtems_test_assert(n == (ssize_t) sizeof(expected_items_10));
+    memcmp(items, expected_items_10, sizeof(expected_items_10)) == 0
+  n = read(fd, items, sizeof(expected_items_11));
+  rtems_test_assert(n == (ssize_t) sizeof(expected_items_11));
+    memcmp(items, expected_items_11, sizeof(expected_items_11)) == 0
+  n = read(fd, items, sizeof(expected_items_12));
+  rtems_test_assert(n == (ssize_t) sizeof(expected_items_12));
+    memcmp(items, expected_items_12, sizeof(expected_items_12)) == 0
+static void test_server(test_context *ctx, Record_Control *control)
+  int rv;
+  int fd;
+  rv = rtems_bsdnet_initialize_network();
+  sc = rtems_record_start_server(1, PORT, 1);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  fd = connect_client();
+  produce_and_read(fd, control);
+  rv = close(fd);
+#endif
+static void Init(rtems_task_argument arg)
+  test_context *ctx;
+  Per_CPU_Control *cpu_self;
+  TEST_BEGIN();
+  ctx = &test_instance;
+  cpu_self = _Per_CPU_Get_snapshot();
+  cpu_self->record = &ctx->control;
+  test_capacity(&ctx->control);
+  test_index(&ctx->control);
+  test_add_2_items(ctx, &ctx->control);
+  test_add_3_items(ctx, &ctx->control);
+  test_produce(ctx, &ctx->control);
+  test_produce_2(ctx, &ctx->control);
+  test_produce_n(ctx, &ctx->control);
+  test_drain(ctx, &ctx->control);
+  test_server(ctx, &ctx->control);
+#endif
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 7
+#define CONFIGURE_MAXIMUM_TASKS 3
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#else
+#define CONFIGURE_MAXIMUM_TASKS 1
+#endif
+#define CONFIGURE_INIT_TASK_PRIORITY 2
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/record01/record01.doc b/testsuites/libtests/record01/record01.doc
index 0000000000..a0592be97d
--- /dev/null
+++ b/testsuites/libtests/record01/record01.doc
@@ -0,0 +1,15 @@
+This file describes the directives and concepts tested by this test set.
+test set name: record01
+directives:
+  - rtems_record_drain()
+  - rtems_record_produce()
+  - rtems_record_produce_2()
+  - rtems_record_produce_n()
+  - rtems_record_start_server()
+concepts:
+  - Ensure that the event recording works.
diff --git a/testsuites/libtests/record01/record01.scn b/testsuites/libtests/record01/record01.scn
index 0000000000..022e69bffb
--- /dev/null
+++ b/testsuites/libtests/record01/record01.scn
@@ -0,0 +1,7 @@
+*** BEGIN OF TEST RECORD 1 ***
+*** TEST VERSION: 5.0.0.7c19e50bdd3b6ae234b171992f2e109d4f804cda
+*** TEST STATE: EXPECTED-PASS
+*** TEST BUILD:
+*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB ddba5372522da341fa20b2c75dfe966231cb6790, Newlib df6915f029ac9acd2b479ea898388cbd7dda4974)
+*** END OF TEST RECORD 1 ***
diff --git a/testsuites/libtests/record02/init.c b/testsuites/libtests/record02/init.c
index 0000000000..9416fde4d4
--- /dev/null
+++ b/testsuites/libtests/record02/init.c
@@ -0,0 +1,132 @@
+ * are met:
+#endif
+#include <rtems.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "RECORD 2";
+typedef struct {
+  rtems_record_client_context client;
+} test_context;
+static rtems_record_client_status client_handler(
+  uint32_t            seconds,
+  uint32_t            cpu,
+  uint64_t            data,
+  void               *arg
+  const char *event_text;
+  (void) arg;
+  if ( seconds != 0 && nanoseconds != 0 ) {
+    printf( "%" PRIu32 ".%09" PRIu32 ":", seconds, nanoseconds );
+  } else {
+    printf( "*:" );
+  event_text = rtems_record_event_text( event );
+  if ( event_text != NULL ) {
+    printf( "%" PRIu32 ":%s:%" PRIx64 "\n", cpu, event_text, data );
+  } else {
+    printf( "%" PRIu32 ":%i:%" PRIx64 "\n", cpu, event, data );
+static void drain_visitor(
+  size_t                   count,
+  void                    *arg
+  rtems_record_client_status cs;
+  ctx = arg;
+  cs = rtems_record_client_run(&ctx->client, items, count * sizeof(*items));
+  rtems_test_assert(cs == RTEMS_RECORD_CLIENT_SUCCESS);
+  int i;
+  TEST_BEGIN();
+  for (i = 0; i < 10; ++i) {
+    rtems_task_wake_after(1);
+  rtems_record_client_init(&ctx->client, client_handler, NULL);
+  _Record_Stream_header_initialize(&header);
+  cs = rtems_record_client_run(&ctx->client, &header, sizeof(header));
+  rtems_record_drain(drain_visitor, ctx);
+  TEST_END();
+#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS 128
+#define CONFIGURE_RECORD_EXTENSIONS_ENABLED
diff --git a/testsuites/libtests/record02/record02.doc b/testsuites/libtests/record02/record02.doc
index 0000000000..a34aa7e30f
--- /dev/null
+++ b/testsuites/libtests/record02/record02.doc
@@ -0,0 +1,12 @@
+test set name: record02
+directives:
+  - rtems_record_client_init()
+  - rtems_record_client_run()
+concepts:
+  - Simple event recording use case.
diff --git a/testsuites/libtests/record02/record02.scn b/testsuites/libtests/record02/record02.scn
index 0000000000..6959de2963
--- /dev/null
+++ b/testsuites/libtests/record02/record02.scn
@@ -0,0 +1,81 @@
+*** BEGIN OF TEST RECORD 2 ***
+*** TEST BUILD:
+*:0:VERSION:1
+*:0:COUNT:80
+*:0:FREQUENCY:f4240
+*:0:PROCESSOR:0
+*:0:TAIL:0
+*:0:HEAD:44
+*:0:THREAD_CREATE:9010001
+*:0:THREAD_START:9010001
+*:0:UPTIME_LOW:99179
+*:0:UPTIME_HIGH:1
+1.000537999:0:THREAD_CREATE:a010001
+1.000841999:0:THREAD_START:a010001
+1.003689999:0:THREAD_BEGIN:a010001
+1.005582999:0:THREAD_SWITCH_OUT:a010001
+1.005582999:0:THREAD_STACK_CURRENT:d60
+1.005582999:0:THREAD_SWITCH_IN:9010001
+1.005678999:0:THREAD_BEGIN:9010001
+1.013831999:0:THREAD_SWITCH_OUT:9010001
+1.013831999:0:THREAD_STACK_CURRENT:d48
+1.013831999:0:THREAD_SWITCH_IN:a010001
+1.014073999:0:THREAD_SWITCH_OUT:a010001
+1.014073999:0:THREAD_STACK_CURRENT:d60
+1.014073999:0:THREAD_SWITCH_IN:9010001
+1.023820999:0:THREAD_SWITCH_OUT:9010001
+1.023820999:0:THREAD_STACK_CURRENT:d48
+1.023820999:0:THREAD_SWITCH_IN:a010001
+1.024062999:0:THREAD_SWITCH_OUT:a010001
+1.024062999:0:THREAD_STACK_CURRENT:d60
+1.024062999:0:THREAD_SWITCH_IN:9010001
+1.033820999:0:THREAD_SWITCH_OUT:9010001
+1.033820999:0:THREAD_STACK_CURRENT:d48
+1.033820999:0:THREAD_SWITCH_IN:a010001
+1.034062999:0:THREAD_SWITCH_OUT:a010001
+1.034062999:0:THREAD_STACK_CURRENT:d60
+1.034062999:0:THREAD_SWITCH_IN:9010001
+1.043820999:0:THREAD_SWITCH_OUT:9010001
+1.043820999:0:THREAD_STACK_CURRENT:d48
+1.043820999:0:THREAD_SWITCH_IN:a010001
+1.044062999:0:THREAD_SWITCH_OUT:a010001
+1.044062999:0:THREAD_STACK_CURRENT:d60
+1.044062999:0:THREAD_SWITCH_IN:9010001
+1.053820999:0:THREAD_SWITCH_OUT:9010001
+1.053820999:0:THREAD_STACK_CURRENT:d48
+1.053820999:0:THREAD_SWITCH_IN:a010001
+1.054062999:0:THREAD_SWITCH_OUT:a010001
+1.054062999:0:THREAD_STACK_CURRENT:d60
+1.054062999:0:THREAD_SWITCH_IN:9010001
+1.063820999:0:THREAD_SWITCH_OUT:9010001
+1.063820999:0:THREAD_STACK_CURRENT:d48
+1.063820999:0:THREAD_SWITCH_IN:a010001
+1.064062999:0:THREAD_SWITCH_OUT:a010001
+1.064062999:0:THREAD_STACK_CURRENT:d60
+1.064062999:0:THREAD_SWITCH_IN:9010001
+1.073820999:0:THREAD_SWITCH_OUT:9010001
+1.073820999:0:THREAD_STACK_CURRENT:d48
+1.073820999:0:THREAD_SWITCH_IN:a010001
+1.074062999:0:THREAD_SWITCH_OUT:a010001
+1.074062999:0:THREAD_STACK_CURRENT:d60
+1.074062999:0:THREAD_SWITCH_IN:9010001
+1.083820999:0:THREAD_SWITCH_OUT:9010001
+1.083820999:0:THREAD_STACK_CURRENT:d48
+1.083820999:0:THREAD_SWITCH_IN:a010001
+1.084062999:0:THREAD_SWITCH_OUT:a010001
+1.084062999:0:THREAD_STACK_CURRENT:d60
+1.084062999:0:THREAD_SWITCH_IN:9010001
+1.093820999:0:THREAD_SWITCH_OUT:9010001
+1.093820999:0:THREAD_STACK_CURRENT:d48
+1.093820999:0:THREAD_SWITCH_IN:a010001
+1.094062999:0:THREAD_SWITCH_OUT:a010001
+1.094062999:0:THREAD_STACK_CURRENT:d60
+1.094062999:0:THREAD_SWITCH_IN:9010001
+1.103820999:0:THREAD_SWITCH_OUT:9010001
+1.103820999:0:THREAD_STACK_CURRENT:d48
+1.103820999:0:THREAD_SWITCH_IN:a010001
+*** END OF TEST RECORD 2 ***
2.16.4
