[PATCH 1/2] freebsd/if_cpsw: Import.
Christian Mauderer list at c-mauderer.de
Wed Dec 19 21:53:53 UTC 2018
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
 freebsd/sys/arm/ti/cpsw/if_cpsw.c    | 2991 ++++++++++++++++++++++++++
 freebsd/sys/arm/ti/cpsw/if_cpswreg.h |  210 ++
 freebsd/sys/arm/ti/cpsw/if_cpswvar.h |  151 ++
 3 files changed, 3352 insertions(+)
 create mode 100644 freebsd/sys/arm/ti/cpsw/if_cpsw.c
 create mode 100644 freebsd/sys/arm/ti/cpsw/if_cpswreg.h
 create mode 100644 freebsd/sys/arm/ti/cpsw/if_cpswvar.h
diff --git a/freebsd/sys/arm/ti/cpsw/if_cpsw.c b/freebsd/sys/arm/ti/cpsw/if_cpsw.c
new file mode 100644
index 00000000..bd996f6d
--- /dev/null
+++ b/freebsd/sys/arm/ti/cpsw/if_cpsw.c
@@ -0,0 +1,2991 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2012 Damjan Marion <dmarion at Freebsd.org>
+ * Copyright (c) 2016 Rubicon Communications, LLC (Netgate)
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * TI Common Platform Ethernet Switch (CPSW) Driver
+ * Found in TI8148 "DaVinci" and AM335x "Sitara" SoCs.
+ * This controller is documented in the AM335x Technical Reference
+ * Manual, in the TMS320DM814x DaVinci Digital Video Processors TRM
+ * and in the TMS320C6452 3 Port Switch Ethernet Subsystem TRM.
+ * It is basically a single Ethernet port (port 0) wired internally to
+ * a 3-port store-and-forward switch connected to two independent
+ * "sliver" controllers (port 1 and port 2).  You can operate the
+ * controller in a variety of different ways by suitably configuring
+ * the slivers and the Address Lookup Engine (ALE) that routes packets
+ * between the ports.
+ * This code was developed and tested on a BeagleBone with
+ * an AM335x SoC.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/local/opt_cpsw.h>
+#include <sys/param.h>
+#include <sys/bus.h>
+#include <sys/kernel.h>
+#include <sys/lock.h>
+#include <sys/mbuf.h>
+#include <sys/module.h>
+#include <sys/mutex.h>
+#include <sys/rman.h>
+#include <sys/socket.h>
+#include <sys/sockio.h>
+#include <sys/sysctl.h>
+#include <machine/bus.h>
+#include <machine/resource.h>
+#include <machine/stdarg.h>
+#include <net/ethernet.h>
+#include <net/bpf.h>
+#include <net/if.h>
+#include <net/if_dl.h>
+#include <net/if_media.h>
+#include <net/if_types.h>
+#include <arm/ti/ti_scm.h>
+#include <arm/ti/am335x/am335x_scm.h>
+#include <dev/mii/mii.h>
+#include <dev/mii/miivar.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#ifdef CPSW_ETHERSWITCH
+#include <dev/etherswitch/etherswitch.h>
+#include <rtems/bsd/local/etherswitch_if.h>
+#endif
+#include "if_cpswreg.h"
+#include "if_cpswvar.h"
+#include <rtems/bsd/local/miibus_if.h>
+/* Device probe/attach/detach. */
+static int cpsw_probe(device_t);
+static int cpsw_attach(device_t);
+static int cpsw_detach(device_t);
+static int cpswp_probe(device_t);
+static int cpswp_attach(device_t);
+static int cpswp_detach(device_t);
+static phandle_t cpsw_get_node(device_t, device_t);
+/* Device Init/shutdown. */
+static int cpsw_shutdown(device_t);
+static void cpswp_init(void *);
+static void cpswp_init_locked(void *);
+static void cpswp_stop_locked(struct cpswp_softc *);
+/* Device Suspend/Resume. */
+static int cpsw_suspend(device_t);
+static int cpsw_resume(device_t);
+/* Ioctl. */
+static int cpswp_ioctl(struct ifnet *, u_long command, caddr_t data);
+static int cpswp_miibus_readreg(device_t, int phy, int reg);
+static int cpswp_miibus_writereg(device_t, int phy, int reg, int value);
+static void cpswp_miibus_statchg(device_t);
+/* Send/Receive packets. */
+static void cpsw_intr_rx(void *arg);
+static struct mbuf *cpsw_rx_dequeue(struct cpsw_softc *);
+static void cpsw_rx_enqueue(struct cpsw_softc *);
+static void cpswp_start(struct ifnet *);
+static void cpsw_intr_tx(void *);
+static void cpswp_tx_enqueue(struct cpswp_softc *);
+static int cpsw_tx_dequeue(struct cpsw_softc *);
+/* Misc interrupts and watchdog. */
+static void cpsw_intr_rx_thresh(void *);
+static void cpsw_intr_misc(void *);
+static void cpswp_tick(void *);
+static void cpswp_ifmedia_sts(struct ifnet *, struct ifmediareq *);
+static int cpswp_ifmedia_upd(struct ifnet *);
+static void cpsw_tx_watchdog(void *);
+/* ALE support */
+static void cpsw_ale_read_entry(struct cpsw_softc *, uint16_t, uint32_t *);
+static void cpsw_ale_write_entry(struct cpsw_softc *, uint16_t, uint32_t *);
+static int cpsw_ale_mc_entry_set(struct cpsw_softc *, uint8_t, int, uint8_t *);
+static void cpsw_ale_dump_table(struct cpsw_softc *);
+static int cpsw_ale_update_vlan_table(struct cpsw_softc *, int, int, int, int,
+	int);
+static int cpswp_ale_update_addresses(struct cpswp_softc *, int);
+/* Statistics and sysctls. */
+static void cpsw_add_sysctls(struct cpsw_softc *);
+static void cpsw_stats_collect(struct cpsw_softc *);
+static int cpsw_stats_sysctl(SYSCTL_HANDLER_ARGS);
+static etherswitch_info_t *cpsw_getinfo(device_t);
+static int cpsw_getport(device_t, etherswitch_port_t *);
+static int cpsw_setport(device_t, etherswitch_port_t *);
+static int cpsw_getconf(device_t, etherswitch_conf_t *);
+static int cpsw_getvgroup(device_t, etherswitch_vlangroup_t *);
+static int cpsw_setvgroup(device_t, etherswitch_vlangroup_t *);
+static int cpsw_readreg(device_t, int);
+static int cpsw_writereg(device_t, int, int);
+static int cpsw_readphy(device_t, int, int);
+static int cpsw_writephy(device_t, int, int, int);
+#endif
+ * Arbitrary limit on number of segments in an mbuf to be transmitted.
+ * Packets with more segments than this will be defragmented before
+ * they are queued.
+#define	CPSW_TXFRAGS		16
+/* Shared resources. */
+static device_method_t cpsw_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,		cpsw_probe),
+	DEVMETHOD(device_attach,	cpsw_attach),
+	DEVMETHOD(device_detach,	cpsw_detach),
+	DEVMETHOD(device_shutdown,	cpsw_shutdown),
+	DEVMETHOD(device_suspend,	cpsw_suspend),
+	DEVMETHOD(device_resume,	cpsw_resume),
+	/* Bus interface */
+	DEVMETHOD(bus_add_child,	device_add_child_ordered),
+	/* OFW methods */
+	DEVMETHOD(ofw_bus_get_node,	cpsw_get_node),
+	/* etherswitch interface */
+	DEVMETHOD(etherswitch_getinfo,	cpsw_getinfo),
+	DEVMETHOD(etherswitch_readreg,	cpsw_readreg),
+	DEVMETHOD(etherswitch_writereg,	cpsw_writereg),
+	DEVMETHOD(etherswitch_readphyreg,	cpsw_readphy),
+	DEVMETHOD(etherswitch_writephyreg,	cpsw_writephy),
+	DEVMETHOD(etherswitch_getport,	cpsw_getport),
+	DEVMETHOD(etherswitch_setport,	cpsw_setport),
+	DEVMETHOD(etherswitch_getvgroup,	cpsw_getvgroup),
+	DEVMETHOD(etherswitch_setvgroup,	cpsw_setvgroup),
+	DEVMETHOD(etherswitch_getconf,	cpsw_getconf),
+#endif
+	DEVMETHOD_END
+static driver_t cpsw_driver = {
+	"cpswss",
+	cpsw_methods,
+	sizeof(struct cpsw_softc),
+static devclass_t cpsw_devclass;
+DRIVER_MODULE(cpswss, simplebus, cpsw_driver, cpsw_devclass, 0, 0);
+/* Port/Slave resources. */
+static device_method_t cpswp_methods[] = {
+	DEVMETHOD(device_probe,		cpswp_probe),
+	DEVMETHOD(device_attach,	cpswp_attach),
+	DEVMETHOD(device_detach,	cpswp_detach),
+	/* MII interface */
+	DEVMETHOD(miibus_readreg,	cpswp_miibus_readreg),
+	DEVMETHOD(miibus_writereg,	cpswp_miibus_writereg),
+	DEVMETHOD(miibus_statchg,	cpswp_miibus_statchg),
+	DEVMETHOD_END
+static driver_t cpswp_driver = {
+	"cpsw",
+	cpswp_methods,
+	sizeof(struct cpswp_softc),
+static devclass_t cpswp_devclass;
+DRIVER_MODULE(etherswitch, cpswss, etherswitch_driver, etherswitch_devclass, 0, 0);
+MODULE_DEPEND(cpswss, etherswitch, 1, 1, 1);
+#endif
+DRIVER_MODULE(cpsw, cpswss, cpswp_driver, cpswp_devclass, 0, 0);
+DRIVER_MODULE(miibus, cpsw, miibus_driver, miibus_devclass, 0, 0);
+MODULE_DEPEND(cpsw, ether, 1, 1, 1);
+MODULE_DEPEND(cpsw, miibus, 1, 1, 1);
+static struct cpsw_vlangroups cpsw_vgroups[CPSW_VLANS];
+#endif
+static uint32_t slave_mdio_addr[] = { 0x4a100200, 0x4a100300 };
+static struct resource_spec irq_res_spec[] = {
+	{ SYS_RES_IRQ, 0, RF_ACTIVE | RF_SHAREABLE },
+	{ SYS_RES_IRQ, 1, RF_ACTIVE | RF_SHAREABLE },
+	{ SYS_RES_IRQ, 2, RF_ACTIVE | RF_SHAREABLE },
+	{ SYS_RES_IRQ, 3, RF_ACTIVE | RF_SHAREABLE },
+	{ -1, 0 }
+static struct {
+	void (*cb)(void *);
+} cpsw_intr_cb[] = {
+	{ cpsw_intr_rx_thresh },
+	{ cpsw_intr_rx },
+	{ cpsw_intr_tx },
+	{ cpsw_intr_misc },
+/* Number of entries here must match size of stats
+ * array in struct cpswp_softc. */
+static struct cpsw_stat {
+	int	reg;
+	char *oid;
+} cpsw_stat_sysctls[CPSW_SYSCTL_COUNT] = {
+	{0x00, "GoodRxFrames"},
+	{0x04, "BroadcastRxFrames"},
+	{0x08, "MulticastRxFrames"},
+	{0x0C, "PauseRxFrames"},
+	{0x10, "RxCrcErrors"},
+	{0x14, "RxAlignErrors"},
+	{0x18, "OversizeRxFrames"},
+	{0x1c, "RxJabbers"},
+	{0x20, "ShortRxFrames"},
+	{0x24, "RxFragments"},
+	{0x30, "RxOctets"},
+	{0x34, "GoodTxFrames"},
+	{0x38, "BroadcastTxFrames"},
+	{0x3c, "MulticastTxFrames"},
+	{0x40, "PauseTxFrames"},
+	{0x44, "DeferredTxFrames"},
+	{0x48, "CollisionsTxFrames"},
+	{0x4c, "SingleCollisionTxFrames"},
+	{0x50, "MultipleCollisionTxFrames"},
+	{0x54, "ExcessiveCollisions"},
+	{0x58, "LateCollisions"},
+	{0x5c, "TxUnderrun"},
+	{0x60, "CarrierSenseErrors"},
+	{0x64, "TxOctets"},
+	{0x68, "RxTx64OctetFrames"},
+	{0x6c, "RxTx65to127OctetFrames"},
+	{0x70, "RxTx128to255OctetFrames"},
+	{0x74, "RxTx256to511OctetFrames"},
+	{0x78, "RxTx512to1024OctetFrames"},
+	{0x7c, "RxTx1024upOctetFrames"},
+	{0x80, "NetOctets"},
+	{0x84, "RxStartOfFrameOverruns"},
+	{0x88, "RxMiddleOfFrameOverruns"},
+	{0x8c, "RxDmaOverruns"}
+ * Basic debug support.
+static void
+cpsw_debugf_head(const char *funcname)
+	int t = (int)(time_second % (24 * 60 * 60));
+	printf("%02d:%02d:%02d %s ", t / (60 * 60), (t / 60) % 60, t % 60, funcname);
+static void
+cpsw_debugf(const char *fmt, ...)
+	va_list ap;
+	va_start(ap, fmt);
+	vprintf(fmt, ap);
+	va_end(ap);
+	printf("\n");
+#define	CPSW_DEBUGF(_sc, a) do {					\
+	if ((_sc)->debug) {						\
+		cpsw_debugf_head(__func__);				\
+		cpsw_debugf a;						\
+} while (0)
+ * Locking macros
+#define	CPSW_TX_LOCK(sc) do {						\
+		mtx_assert(&(sc)->rx.lock, MA_NOTOWNED);		\
+		mtx_lock(&(sc)->tx.lock);				\
+} while (0)
+#define	CPSW_TX_UNLOCK(sc)	mtx_unlock(&(sc)->tx.lock)
+#define	CPSW_TX_LOCK_ASSERT(sc)	mtx_assert(&(sc)->tx.lock, MA_OWNED)
+#define	CPSW_RX_LOCK(sc) do {						\
+		mtx_assert(&(sc)->tx.lock, MA_NOTOWNED);		\
+		mtx_lock(&(sc)->rx.lock);				\
+} while (0)
+#define	CPSW_RX_UNLOCK(sc)		mtx_unlock(&(sc)->rx.lock)
+#define	CPSW_RX_LOCK_ASSERT(sc)	mtx_assert(&(sc)->rx.lock, MA_OWNED)
+#define CPSW_PORT_LOCK(_sc) do {					\
+		mtx_assert(&(_sc)->lock, MA_NOTOWNED);			\
+		mtx_lock(&(_sc)->lock);					\
+} while (0)
+#define	CPSW_PORT_UNLOCK(_sc)	mtx_unlock(&(_sc)->lock)
+#define	CPSW_PORT_LOCK_ASSERT(_sc)	mtx_assert(&(_sc)->lock, MA_OWNED)
+ * Read/Write macros
+#define	cpsw_read_4(_sc, _reg)		bus_read_4((_sc)->mem_res, (_reg))
+#define	cpsw_write_4(_sc, _reg, _val)					\
+	bus_write_4((_sc)->mem_res, (_reg), (_val))
+#define	cpsw_cpdma_bd_offset(i)	(CPSW_CPPI_RAM_OFFSET + ((i)*16))
+#define	cpsw_cpdma_bd_paddr(sc, slot)					\
+	BUS_SPACE_PHYSADDR(sc->mem_res, slot->bd_offset)
+#define	cpsw_cpdma_read_bd(sc, slot, val)				\
+	bus_read_region_4(sc->mem_res, slot->bd_offset, (uint32_t *) val, 4)
+#define	cpsw_cpdma_write_bd(sc, slot, val)				\
+	bus_write_region_4(sc->mem_res, slot->bd_offset, (uint32_t *) val, 4)
+#define	cpsw_cpdma_write_bd_next(sc, slot, next_slot)			\
+	cpsw_write_4(sc, slot->bd_offset, cpsw_cpdma_bd_paddr(sc, next_slot))
+#define	cpsw_cpdma_write_bd_flags(sc, slot, val)			\
+	bus_write_2(sc->mem_res, slot->bd_offset + 14, val)
+#define	cpsw_cpdma_read_bd_flags(sc, slot)				\
+	bus_read_2(sc->mem_res, slot->bd_offset + 14)
+#define	cpsw_write_hdp_slot(sc, queue, slot)				\
+	cpsw_write_4(sc, (queue)->hdp_offset, cpsw_cpdma_bd_paddr(sc, slot))
+#define	CP_OFFSET (CPSW_CPDMA_TX_CP(0) - CPSW_CPDMA_TX_HDP(0))
+#define	cpsw_read_cp(sc, queue)						\
+	cpsw_read_4(sc, (queue)->hdp_offset + CP_OFFSET)
+#define	cpsw_write_cp(sc, queue, val)					\
+	cpsw_write_4(sc, (queue)->hdp_offset + CP_OFFSET, (val))
+#define	cpsw_write_cp_slot(sc, queue, slot)				\
+	cpsw_write_cp(sc, queue, cpsw_cpdma_bd_paddr(sc, slot))
+#if 0
+/* XXX temporary function versions for debugging. */
+static void
+cpsw_write_hdp_slotX(struct cpsw_softc *sc, struct cpsw_queue *queue, struct cpsw_slot *slot)
+	uint32_t reg = queue->hdp_offset;
+	uint32_t v = cpsw_cpdma_bd_paddr(sc, slot);
+	CPSW_DEBUGF(("HDP <=== 0x%08x (was 0x%08x)", v, cpsw_read_4(sc, reg)));
+	cpsw_write_4(sc, reg, v);
+static void
+cpsw_write_cp_slotX(struct cpsw_softc *sc, struct cpsw_queue *queue, struct cpsw_slot *slot)
+	CPSW_DEBUGF(("CP <=== 0x%08x (expecting 0x%08x)", v, cpsw_read_cp(sc, queue)));
+	cpsw_write_cp(sc, queue, v);
+#endif
+ * Expanded dump routines for verbose debugging.
+static void
+cpsw_dump_slot(struct cpsw_softc *sc, struct cpsw_slot *slot)
+	static const char *flags[] = {"SOP", "EOP", "Owner", "EOQ",
+	    "TDownCmplt", "PassCRC", "Long", "Short", "MacCtl", "Overrun",
+	    "PktErr1", "PortEn/PktErr0", "RxVlanEncap", "Port2", "Port1",
+	    "Port0"};
+	struct cpsw_cpdma_bd bd;
+	const char *sep;
+	int i;
+	cpsw_cpdma_read_bd(sc, slot, &bd);
+	printf("BD Addr : 0x%08x   Next  : 0x%08x\n",
+	    cpsw_cpdma_bd_paddr(sc, slot), bd.next);
+	printf("  BufPtr: 0x%08x   BufLen: 0x%08x\n", bd.bufptr, bd.buflen);
+	printf("  BufOff: 0x%08x   PktLen: 0x%08x\n", bd.bufoff, bd.pktlen);
+	printf("  Flags: ");
+	sep = "";
+	for (i = 0; i < 16; ++i) {
+		if (bd.flags & (1 << (15 - i))) {
+			printf("%s%s", sep, flags[i]);
+			sep = ",";
+	printf("\n");
+	if (slot->mbuf) {
+		printf("  Ether:  %14D\n",
+		    (char *)(slot->mbuf->m_data), " ");
+		printf("  Packet: %16D\n",
+		    (char *)(slot->mbuf->m_data) + 14, " ");
+#define	CPSW_DUMP_SLOT(cs, slot) do {				\
+	IF_DEBUG(sc) {						\
+		cpsw_dump_slot(sc, slot);			\
+} while (0)
+static void
+cpsw_dump_queue(struct cpsw_softc *sc, struct cpsw_slots *q)
+	struct cpsw_slot *slot;
+	int i = 0;
+	int others = 0;
+	STAILQ_FOREACH(slot, q, next) {
+		if (i > CPSW_TXFRAGS)
+			++others;
+		else
+		++i;
+	if (others)
+		printf(" ... and %d more.\n", others);
+	printf("\n");
+#define CPSW_DUMP_QUEUE(sc, q) do {				\
+	IF_DEBUG(sc) {						\
+		cpsw_dump_queue(sc, q);				\
+} while (0)
+static void
+cpsw_init_slots(struct cpsw_softc *sc)
+	int i;
+	STAILQ_INIT(&sc->avail);
+	/* Put the slot descriptors onto the global avail list. */
+	for (i = 0; i < nitems(sc->_slots); i++) {
+		slot = &sc->_slots[i];
+		slot->bd_offset = cpsw_cpdma_bd_offset(i);
+		STAILQ_INSERT_TAIL(&sc->avail, slot, next);
+static int
+cpsw_add_slots(struct cpsw_softc *sc, struct cpsw_queue *queue, int requested)
+	const int max_slots = nitems(sc->_slots);
+	int i;
+	if (requested < 0)
+		requested = max_slots;
+	for (i = 0; i < requested; ++i) {
+		slot = STAILQ_FIRST(&sc->avail);
+		if (slot == NULL)
+			return (0);
+		if (bus_dmamap_create(sc->mbuf_dtag, 0, &slot->dmamap)) {
+			device_printf(sc->dev, "failed to create dmamap\n");
+			return (ENOMEM);
+		STAILQ_REMOVE_HEAD(&sc->avail, next);
+		STAILQ_INSERT_TAIL(&queue->avail, slot, next);
+		++queue->avail_queue_len;
+		++queue->queue_slots;
+	return (0);
+static void
+cpsw_free_slot(struct cpsw_softc *sc, struct cpsw_slot *slot)
+	int error;
+	if (slot->dmamap) {
+		if (slot->mbuf)
+			bus_dmamap_unload(sc->mbuf_dtag, slot->dmamap);
+		error = bus_dmamap_destroy(sc->mbuf_dtag, slot->dmamap);
+		KASSERT(error == 0, ("Mapping still active"));
+		slot->dmamap = NULL;
+	if (slot->mbuf) {
+		m_freem(slot->mbuf);
+		slot->mbuf = NULL;
+static void
+cpsw_reset(struct cpsw_softc *sc)
+	int i;
+	callout_stop(&sc->watchdog.callout);
+	/* Reset RMII/RGMII wrapper. */
+	cpsw_write_4(sc, CPSW_WR_SOFT_RESET, 1);
+	while (cpsw_read_4(sc, CPSW_WR_SOFT_RESET) & 1)
+	/* Disable TX and RX interrupts for all cores. */
+	for (i = 0; i < 3; ++i) {
+		cpsw_write_4(sc, CPSW_WR_C_RX_THRESH_EN(i), 0x00);
+		cpsw_write_4(sc, CPSW_WR_C_TX_EN(i), 0x00);
+		cpsw_write_4(sc, CPSW_WR_C_RX_EN(i), 0x00);
+		cpsw_write_4(sc, CPSW_WR_C_MISC_EN(i), 0x00);
+	/* Reset CPSW subsystem. */
+	cpsw_write_4(sc, CPSW_SS_SOFT_RESET, 1);
+	while (cpsw_read_4(sc, CPSW_SS_SOFT_RESET) & 1)
+	/* Reset Sliver port 1 and 2 */
+	for (i = 0; i < 2; i++) {
+		/* Reset */
+		cpsw_write_4(sc, CPSW_SL_SOFT_RESET(i), 1);
+		while (cpsw_read_4(sc, CPSW_SL_SOFT_RESET(i)) & 1)
+	/* Reset DMA controller. */
+	cpsw_write_4(sc, CPSW_CPDMA_SOFT_RESET, 1);
+	while (cpsw_read_4(sc, CPSW_CPDMA_SOFT_RESET) & 1)
+	/* Disable TX & RX DMA */
+	cpsw_write_4(sc, CPSW_CPDMA_TX_CONTROL, 0);
+	cpsw_write_4(sc, CPSW_CPDMA_RX_CONTROL, 0);
+	/* Clear all queues. */
+	for (i = 0; i < 8; i++) {
+		cpsw_write_4(sc, CPSW_CPDMA_TX_HDP(i), 0);
+		cpsw_write_4(sc, CPSW_CPDMA_RX_HDP(i), 0);
+		cpsw_write_4(sc, CPSW_CPDMA_TX_CP(i), 0);
+		cpsw_write_4(sc, CPSW_CPDMA_RX_CP(i), 0);
+	/* Clear all interrupt Masks */
+	cpsw_write_4(sc, CPSW_CPDMA_RX_INTMASK_CLEAR, 0xFFFFFFFF);
+	cpsw_write_4(sc, CPSW_CPDMA_TX_INTMASK_CLEAR, 0xFFFFFFFF);
+static void
+cpsw_init(struct cpsw_softc *sc)
+	uint32_t reg;
+	/* Disable the interrupt pacing. */
+	reg = cpsw_read_4(sc, CPSW_WR_INT_CONTROL);
+	reg &= ~(CPSW_WR_INT_PACE_EN | CPSW_WR_INT_PRESCALE_MASK);
+	cpsw_write_4(sc, CPSW_WR_INT_CONTROL, reg);
+	/* Clear ALE */
+	cpsw_write_4(sc, CPSW_ALE_CONTROL, CPSW_ALE_CTL_CLEAR_TBL);
+	/* Enable ALE */
+	reg = CPSW_ALE_CTL_ENABLE;
+	if (sc->dualemac)
+		reg |= CPSW_ALE_CTL_VLAN_AWARE;
+	cpsw_write_4(sc, CPSW_ALE_CONTROL, reg);
+	/* Set Host Port Mapping. */
+	cpsw_write_4(sc, CPSW_PORT_P0_CPDMA_TX_PRI_MAP, 0x76543210);
+	cpsw_write_4(sc, CPSW_PORT_P0_CPDMA_RX_CH_MAP, 0);
+	/* Initialize ALE: set host port to forwarding(3). */
+	cpsw_write_4(sc, CPSW_ALE_PORTCTL(0),
+	    ALE_PORTCTL_INGRESS | ALE_PORTCTL_FORWARD);
+	cpsw_write_4(sc, CPSW_SS_PTYPE, 0);
+	/* Enable statistics for ports 0, 1 and 2 */
+	cpsw_write_4(sc, CPSW_SS_STAT_PORT_EN, 7);
+	/* Turn off flow control. */
+	cpsw_write_4(sc, CPSW_SS_FLOW_CONTROL, 0);
+	/* Make IP hdr aligned with 4 */
+	cpsw_write_4(sc, CPSW_CPDMA_RX_BUFFER_OFFSET, 2);
+	/* Initialize RX Buffer Descriptors */
+	cpsw_write_4(sc, CPSW_CPDMA_RX_PENDTHRESH(0), 0);
+	cpsw_write_4(sc, CPSW_CPDMA_RX_FREEBUFFER(0), 0);
+	/* Enable TX & RX DMA */
+	cpsw_write_4(sc, CPSW_CPDMA_TX_CONTROL, 1);
+	cpsw_write_4(sc, CPSW_CPDMA_RX_CONTROL, 1);
+	/* Enable Interrupts for core 0 */
+	cpsw_write_4(sc, CPSW_WR_C_RX_THRESH_EN(0), 0xFF);
+	cpsw_write_4(sc, CPSW_WR_C_RX_EN(0), 0xFF);
+	cpsw_write_4(sc, CPSW_WR_C_TX_EN(0), 0xFF);
+	cpsw_write_4(sc, CPSW_WR_C_MISC_EN(0), 0x1F);
+	/* Enable host Error Interrupt */
+	cpsw_write_4(sc, CPSW_CPDMA_DMA_INTMASK_SET, 3);
+	/* Enable interrupts for RX and TX on Channel 0 */
+	cpsw_write_4(sc, CPSW_CPDMA_RX_INTMASK_SET,
+	    CPSW_CPDMA_RX_INT(0) | CPSW_CPDMA_RX_INT_THRESH(0));
+	cpsw_write_4(sc, CPSW_CPDMA_TX_INTMASK_SET, 1);
+	/* Initialze MDIO - ENABLE, PREAMBLE=0, FAULTENB, CLKDIV=0xFF */
+	/* TODO Calculate MDCLK=CLK/(CLKDIV+1) */
+	cpsw_write_4(sc, MDIOCONTROL, MDIOCTL_ENABLE | MDIOCTL_FAULTENB | 0xff);
+	/* Select MII in GMII_SEL, Internal Delay mode */
+	//ti_scm_reg_write_4(0x650, 0);
+	/* Initialize active queues. */
+	slot = STAILQ_FIRST(&sc->tx.active);
+	if (slot != NULL)
+		cpsw_write_hdp_slot(sc, &sc->tx, slot);
+	slot = STAILQ_FIRST(&sc->rx.active);
+	if (slot != NULL)
+		cpsw_write_hdp_slot(sc, &sc->rx, slot);
+	cpsw_rx_enqueue(sc);
+	cpsw_write_4(sc, CPSW_CPDMA_RX_FREEBUFFER(0), sc->rx.active_queue_len);
+	cpsw_write_4(sc, CPSW_CPDMA_RX_PENDTHRESH(0), CPSW_TXFRAGS);
+	/* Activate network interface. */
+	sc->rx.running = 1;
+	sc->tx.running = 1;
+	sc->watchdog.timer = 0;
+	callout_init(&sc->watchdog.callout, 0);
+	callout_reset(&sc->watchdog.callout, hz, cpsw_tx_watchdog, sc);
+ * Device Probe, Attach, Detach.
+static int
+cpsw_probe(device_t dev)
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "ti,cpsw"))
+		return (ENXIO);
+	device_set_desc(dev, "3-port Switch Ethernet Subsystem");
+	return (BUS_PROBE_DEFAULT);
+static int
+cpsw_intr_attach(struct cpsw_softc *sc)
+	int i;
+	for (i = 0; i < CPSW_INTR_COUNT; i++) {
+		if (bus_setup_intr(sc->dev, sc->irq_res[i],
+		    INTR_TYPE_NET | INTR_MPSAFE, NULL,
+		    cpsw_intr_cb[i].cb, sc, &sc->ih_cookie[i]) != 0) {
+			return (-1);
+	return (0);
+static void
+cpsw_intr_detach(struct cpsw_softc *sc)
+	int i;
+		if (sc->ih_cookie[i]) {
+			bus_teardown_intr(sc->dev, sc->irq_res[i],
+			    sc->ih_cookie[i]);
+static int
+cpsw_get_fdt_data(struct cpsw_softc *sc, int port)
+	char *name;
+	int len, phy, vlan;
+	pcell_t phy_id[3], vlan_id;
+	phandle_t child;
+	unsigned long mdio_child_addr;
+	/* Find any slave with phy_id */
+	phy = -1;
+	vlan = -1;
+	for (child = OF_child(sc->node); child != 0; child = OF_peer(child)) {
+		if (OF_getprop_alloc(child, "name", (void **)&name) < 0)
+			continue;
+		if (sscanf(name, "slave@%lx", &mdio_child_addr) != 1) {
+			OF_prop_free(name);
+			continue;
+		if (mdio_child_addr != slave_mdio_addr[port])
+			continue;
+		len = OF_getproplen(child, "phy_id");
+		if (len / sizeof(pcell_t) == 2) {
+			/* Get phy address from fdt */
+			if (OF_getencprop(child, "phy_id", phy_id, len) > 0)
+				phy = phy_id[1];
+		len = OF_getproplen(child, "dual_emac_res_vlan");
+		if (len / sizeof(pcell_t) == 1) {
+			if (OF_getencprop(child, "dual_emac_res_vlan",
+			    &vlan_id, len) > 0) {
+				vlan = vlan_id;
+		break;
+	if (phy == -1)
+		return (ENXIO);
+	sc->port[port].phy = phy;
+	sc->port[port].vlan = vlan;
+	return (0);
+static int
+cpsw_attach(device_t dev)
+	int error, i;
+	struct cpsw_softc *sc;
+	uint32_t reg;
+	sc = device_get_softc(dev);
+	sc->dev = dev;
+	sc->node = ofw_bus_get_node(dev);
+	getbinuptime(&sc->attach_uptime);
+	if (OF_getencprop(sc->node, "active_slave", &sc->active_slave,
+	    sizeof(sc->active_slave)) <= 0) {
+		sc->active_slave = 0;
+	if (sc->active_slave > 1)
+		sc->active_slave = 1;
+	if (OF_hasprop(sc->node, "dual_emac"))
+		sc->dualemac = 1;
+	for (i = 0; i < CPSW_PORTS; i++) {
+		if (!sc->dualemac && i != sc->active_slave)
+			continue;
+		if (cpsw_get_fdt_data(sc, i) != 0) {
+			device_printf(dev,
+			    "failed to get PHY address from FDT\n");
+			return (ENXIO);
+	/* Initialize mutexes */
+	mtx_init(&sc->tx.lock, device_get_nameunit(dev),
+	    "cpsw TX lock", MTX_DEF);
+	mtx_init(&sc->rx.lock, device_get_nameunit(dev),
+	    "cpsw RX lock", MTX_DEF);
+	/* Allocate IRQ resources */
+	error = bus_alloc_resources(dev, irq_res_spec, sc->irq_res);
+	if (error) {
+		device_printf(dev, "could not allocate IRQ resources\n");
+		cpsw_detach(dev);
+		return (ENXIO);
+	sc->mem_rid = 0;
+	sc->mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY,
+	    &sc->mem_rid, RF_ACTIVE);
+	if (sc->mem_res == NULL) {
+		device_printf(sc->dev, "failed to allocate memory resource\n");
+		cpsw_detach(dev);
+		return (ENXIO);
+	reg = cpsw_read_4(sc, CPSW_SS_IDVER);
+	device_printf(dev, "CPSW SS Version %d.%d (%d)\n", (reg >> 8 & 0x7),
+		reg & 0xFF, (reg >> 11) & 0x1F);
+	cpsw_add_sysctls(sc);
+	/* Allocate a busdma tag and DMA safe memory for mbufs. */
+	error = bus_dma_tag_create(
+		bus_get_dma_tag(sc->dev),	/* parent */
+		1, 0,				/* alignment, boundary */
+		BUS_SPACE_MAXADDR_32BIT,	/* lowaddr */
+		BUS_SPACE_MAXADDR,		/* highaddr */
+		NULL, NULL,			/* filtfunc, filtfuncarg */
+		MCLBYTES, CPSW_TXFRAGS,		/* maxsize, nsegments */
+		MCLBYTES, 0,			/* maxsegsz, flags */
+		NULL, NULL,			/* lockfunc, lockfuncarg */
+		&sc->mbuf_dtag);		/* dmatag */
+	if (error) {
+		device_printf(dev, "bus_dma_tag_create failed\n");
+		cpsw_detach(dev);
+		return (error);
+	/* Allocate a NULL buffer for padding. */
+	sc->nullpad = malloc(ETHER_MIN_LEN, M_DEVBUF, M_WAITOK | M_ZERO);
+	cpsw_init_slots(sc);
+	/* Allocate slots to TX and RX queues. */
+	STAILQ_INIT(&sc->rx.avail);
+	STAILQ_INIT(&sc->rx.active);
+	STAILQ_INIT(&sc->tx.avail);
+	STAILQ_INIT(&sc->tx.active);
+	// For now:  128 slots to TX, rest to RX.
+	// XXX TODO: start with 32/64 and grow dynamically based on demand.
+	if (cpsw_add_slots(sc, &sc->tx, 128) ||
+	    cpsw_add_slots(sc, &sc->rx, -1)) {
+		device_printf(dev, "failed to allocate dmamaps\n");
+		cpsw_detach(dev);
+		return (ENOMEM);
+	device_printf(dev, "Initial queue size TX=%d RX=%d\n",
+	    sc->tx.queue_slots, sc->rx.queue_slots);
+	sc->tx.hdp_offset = CPSW_CPDMA_TX_HDP(0);
+	sc->rx.hdp_offset = CPSW_CPDMA_RX_HDP(0);
+	if (cpsw_intr_attach(sc) == -1) {
+		device_printf(dev, "failed to setup interrupts\n");
+		cpsw_detach(dev);
+		return (ENXIO);
+	for (i = 0; i < CPSW_VLANS; i++)
+		cpsw_vgroups[i].vid = -1;
+#endif
+	/* Reset the controller. */
+	cpsw_reset(sc);
+	cpsw_init(sc);
+			continue;
+		sc->port[i].dev = device_add_child(dev, "cpsw", i);
+		if (sc->port[i].dev == NULL) {
+			cpsw_detach(dev);
+			return (ENXIO);
+	bus_generic_probe(dev);
+	bus_generic_attach(dev);
+	return (0);
+static int
+cpsw_detach(device_t dev)
+	int error, i;
+	bus_generic_detach(dev);
+		if (sc->port[i].dev)
+			device_delete_child(dev, sc->port[i].dev);
+	if (device_is_attached(dev)) {
+		callout_drain(&sc->watchdog.callout);
+	/* Stop and release all interrupts */
+	cpsw_intr_detach(sc);
+	/* Free dmamaps and mbufs */
+	for (i = 0; i < nitems(sc->_slots); ++i)
+		cpsw_free_slot(sc, &sc->_slots[i]);
+	/* Free null padding buffer. */
+	if (sc->nullpad)
+		free(sc->nullpad, M_DEVBUF);
+	/* Free DMA tag */
+	if (sc->mbuf_dtag) {
+		error = bus_dma_tag_destroy(sc->mbuf_dtag);
+		KASSERT(error == 0, ("Unable to destroy DMA tag"));
+	/* Free IO memory handler */
+	if (sc->mem_res != NULL)
+		bus_release_resource(dev, SYS_RES_MEMORY, sc->mem_rid, sc->mem_res);
+	bus_release_resources(dev, irq_res_spec, sc->irq_res);
+	/* Destroy mutexes */
+	mtx_destroy(&sc->rx.lock);
+	mtx_destroy(&sc->tx.lock);
+	/* Detach the switch device, if present. */
+	error = bus_generic_detach(dev);
+	if (error != 0)
+		return (error);
+	return (device_delete_children(dev));
+static phandle_t
+cpsw_get_node(device_t bus, device_t dev)
+	/* Share controller node with port device. */
+	return (ofw_bus_get_node(bus));
+static int
+cpswp_probe(device_t dev)
+	if (device_get_unit(dev) > 1) {
+		device_printf(dev, "Only two ports are supported.\n");
+		return (ENXIO);
+	device_set_desc(dev, "Ethernet Switch Port");
+static int
+cpswp_attach(device_t dev)
+	int error;
+	struct ifnet *ifp;
+	struct cpswp_softc *sc;
+	uint32_t reg;
+	uint8_t mac_addr[ETHER_ADDR_LEN];
+	sc->dev = dev;
+	sc->pdev = device_get_parent(dev);
+	sc->swsc = device_get_softc(sc->pdev);
+	sc->unit = device_get_unit(dev);
+	sc->phy = sc->swsc->port[sc->unit].phy;
+	sc->vlan = sc->swsc->port[sc->unit].vlan;
+	if (sc->swsc->dualemac && sc->vlan == -1)
+		sc->vlan = sc->unit + 1;
+	if (sc->unit == 0) {
+		sc->physel = MDIOUSERPHYSEL0;
+		sc->phyaccess = MDIOUSERACCESS0;
+	} else {
+		sc->physel = MDIOUSERPHYSEL1;
+		sc->phyaccess = MDIOUSERACCESS1;
+	mtx_init(&sc->lock, device_get_nameunit(dev), "cpsw port lock",
+	    MTX_DEF);
+	/* Allocate network interface */
+	ifp = sc->ifp = if_alloc(IFT_ETHER);
+	if (ifp == NULL) {
+		cpswp_detach(dev);
+		return (ENXIO);
+	if_initname(ifp, device_get_name(sc->dev), sc->unit);
+	ifp->if_softc = sc;
+	ifp->if_flags = IFF_SIMPLEX | IFF_MULTICAST | IFF_BROADCAST;
+	ifp->if_capabilities = IFCAP_VLAN_MTU | IFCAP_HWCSUM; //FIXME VLAN?
+	ifp->if_capenable = ifp->if_capabilities;
+	ifp->if_init = cpswp_init;
+	ifp->if_start = cpswp_start;
+	ifp->if_ioctl = cpswp_ioctl;
+	ifp->if_snd.ifq_drv_maxlen = sc->swsc->tx.queue_slots;
+	IFQ_SET_MAXLEN(&ifp->if_snd, ifp->if_snd.ifq_drv_maxlen);
+	IFQ_SET_READY(&ifp->if_snd);
+	/* Get high part of MAC address from control module (mac_id[0|1]_hi) */
+	ti_scm_reg_read_4(SCM_MAC_ID0_HI + sc->unit * 8, &reg);
+	mac_addr[0] = reg & 0xFF;
+	mac_addr[1] = (reg >>  8) & 0xFF;
+	mac_addr[2] = (reg >> 16) & 0xFF;
+	mac_addr[3] = (reg >> 24) & 0xFF;
+	/* Get low part of MAC address from control module (mac_id[0|1]_lo) */
+	ti_scm_reg_read_4(SCM_MAC_ID0_LO + sc->unit * 8, &reg);
+	mac_addr[4] = reg & 0xFF;
+	mac_addr[5] = (reg >>  8) & 0xFF;
+	error = mii_attach(dev, &sc->miibus, ifp, cpswp_ifmedia_upd,
+	    cpswp_ifmedia_sts, BMSR_DEFCAPMASK, sc->phy, MII_OFFSET_ANY, 0);
+	if (error) {
+		device_printf(dev, "attaching PHYs failed\n");
+		return (error);
+	sc->mii = device_get_softc(sc->miibus);
+	/* Select PHY and enable interrupts */
+	cpsw_write_4(sc->swsc, sc->physel,
+	    MDIO_PHYSEL_LINKINTENB | (sc->phy & 0x1F));
+	ether_ifattach(sc->ifp, mac_addr);
+	callout_init(&sc->mii_callout, 0);
+	return (0);
+static int
+cpswp_detach(device_t dev)
+	CPSW_DEBUGF(sc->swsc, (""));
+		ether_ifdetach(sc->ifp);
+		CPSW_PORT_LOCK(sc);
+		cpswp_stop_locked(sc);
+		CPSW_PORT_UNLOCK(sc);
+		callout_drain(&sc->mii_callout);
+	if_free(sc->ifp);
+	mtx_destroy(&sc->lock);
+	return (0);
+ * Init/Shutdown.
+static int
+cpsw_ports_down(struct cpsw_softc *sc)
+	struct cpswp_softc *psc;
+	struct ifnet *ifp1, *ifp2;
+	if (!sc->dualemac)
+		return (1);
+	psc = device_get_softc(sc->port[0].dev);
+	ifp1 = psc->ifp;
+	psc = device_get_softc(sc->port[1].dev);
+	ifp2 = psc->ifp;
+	if ((ifp1->if_flags & IFF_UP) == 0 && (ifp2->if_flags & IFF_UP) == 0)
+		return (1);
+	return (0);
+static void
+cpswp_init(void *arg)
+	struct cpswp_softc *sc = arg;
+	cpswp_init_locked(arg);
+static void
+cpswp_init_locked(void *arg)
+	int i;
+#endif
+	uint32_t reg;
+	CPSW_PORT_LOCK_ASSERT(sc);
+	ifp = sc->ifp;
+	if ((ifp->if_drv_flags & IFF_DRV_RUNNING) != 0)
+		return;
+	getbinuptime(&sc->init_uptime);
+	if (!sc->swsc->rx.running && !sc->swsc->tx.running) {
+		cpsw_reset(sc->swsc);
+		cpsw_init(sc->swsc);
+	/* Set Slave Mapping. */
+	cpsw_write_4(sc->swsc, CPSW_SL_RX_PRI_MAP(sc->unit), 0x76543210);
+	cpsw_write_4(sc->swsc, CPSW_PORT_P_TX_PRI_MAP(sc->unit + 1),
+	    0x33221100);
+	cpsw_write_4(sc->swsc, CPSW_SL_RX_MAXLEN(sc->unit), 0x5f2);
+	/* Enable MAC RX/TX modules. */
+	/* TODO: Docs claim that IFCTL_B and IFCTL_A do the same thing? */
+	/* Huh?  Docs call bit 0 "Loopback" some places, "FullDuplex" others. */
+	reg = cpsw_read_4(sc->swsc, CPSW_SL_MACCONTROL(sc->unit));
+	reg |= CPSW_SL_MACTL_GMII_ENABLE;
+	cpsw_write_4(sc->swsc, CPSW_SL_MACCONTROL(sc->unit), reg);
+	/* Initialize ALE: set port to forwarding, initialize addrs */
+	cpsw_write_4(sc->swsc, CPSW_ALE_PORTCTL(sc->unit + 1),
+	cpswp_ale_update_addresses(sc, 1);
+	if (sc->swsc->dualemac) {
+		/* Set Port VID. */
+		cpsw_write_4(sc->swsc, CPSW_PORT_P_VLAN(sc->unit + 1),
+		    sc->vlan & 0xfff);
+		cpsw_ale_update_vlan_table(sc->swsc, sc->vlan,
+		    (1 << (sc->unit + 1)) | (1 << 0), /* Member list */
+		    (1 << (sc->unit + 1)) | (1 << 0), /* Untagged egress */
+		    (1 << (sc->unit + 1)) | (1 << 0), 0); /* mcast reg flood */
+		for (i = 0; i < CPSW_VLANS; i++) {
+			if (cpsw_vgroups[i].vid != -1)
+				continue;
+			cpsw_vgroups[i].vid = sc->vlan;
+			break;
+#endif
+	mii_mediachg(sc->mii);
+	callout_reset(&sc->mii_callout, hz, cpswp_tick, sc);
+	ifp->if_drv_flags |= IFF_DRV_RUNNING;
+	ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
+static int
+cpsw_shutdown(device_t dev)
+	int i;
+	CPSW_DEBUGF(sc, (""));
+			continue;
+		psc = device_get_softc(sc->port[i].dev);
+		CPSW_PORT_LOCK(psc);
+		cpswp_stop_locked(psc);
+		CPSW_PORT_UNLOCK(psc);
+	return (0);
+static void
+cpsw_rx_teardown(struct cpsw_softc *sc)
+	int i = 0;
+	CPSW_RX_LOCK(sc);
+	CPSW_DEBUGF(sc, ("starting RX teardown"));
+	sc->rx.teardown = 1;
+	cpsw_write_4(sc, CPSW_CPDMA_RX_TEARDOWN, 0);
+	CPSW_RX_UNLOCK(sc);
+	while (sc->rx.running) {
+		if (++i > 10) {
+			    "Unable to cleanly shutdown receiver\n");
+			return;
+		DELAY(200);
+	if (!sc->rx.running)
+		CPSW_DEBUGF(sc, ("finished RX teardown (%d retries)", i));
+static void
+cpsw_tx_teardown(struct cpsw_softc *sc)
+	int i = 0;
+	CPSW_TX_LOCK(sc);
+	CPSW_DEBUGF(sc, ("starting TX teardown"));
+	/* Start the TX queue teardown if queue is not empty. */
+	if (STAILQ_FIRST(&sc->tx.active) != NULL)
+		cpsw_write_4(sc, CPSW_CPDMA_TX_TEARDOWN, 0);
+	else
+		sc->tx.teardown = 1;
+	cpsw_tx_dequeue(sc);
+	while (sc->tx.running && ++i < 10) {
+		DELAY(200);
+	if (sc->tx.running) {
+		    "Unable to cleanly shutdown transmitter\n");
+	CPSW_DEBUGF(sc,
+	    ("finished TX teardown (%d retries, %d idle buffers)", i,
+	     sc->tx.active_queue_len));
+	CPSW_TX_UNLOCK(sc);
+static void
+cpswp_stop_locked(struct cpswp_softc *sc)
+	uint32_t reg;
+	ifp = sc->ifp;
+	if ((ifp->if_drv_flags & IFF_DRV_RUNNING) == 0)
+		return;
+	/* Disable interface */
+	ifp->if_drv_flags &= ~IFF_DRV_RUNNING;
+	ifp->if_drv_flags |= IFF_DRV_OACTIVE;
+	/* Stop ticker */
+	callout_stop(&sc->mii_callout);
+	/* Tear down the RX/TX queues. */
+	if (cpsw_ports_down(sc->swsc)) {
+		cpsw_rx_teardown(sc->swsc);
+		cpsw_tx_teardown(sc->swsc);
+	/* Stop MAC RX/TX modules. */
+	reg &= ~CPSW_SL_MACTL_GMII_ENABLE;
+		/* Capture stats before we reset controller. */
+		cpsw_stats_collect(sc->swsc);
+ *  Suspend/Resume.
+static int
+cpsw_suspend(device_t dev)
+	int i;
+			continue;
+	return (0);
+static int
+cpsw_resume(device_t dev)
+	CPSW_DEBUGF(sc, ("UNIMPLEMENTED"));
+	return (0);
+ *  IOCTL
+static void
+cpsw_set_promisc(struct cpswp_softc *sc, int set)
+	uint32_t reg;
+	 * Enabling promiscuous mode requires ALE_BYPASS to be enabled.
+	 * That disables the ALE forwarding logic and causes every
+	 * packet to be sent only to the host port.  In bypass mode,
+	 * the ALE processes host port transmit packets the same as in
+	 * normal mode.
+	reg = cpsw_read_4(sc->swsc, CPSW_ALE_CONTROL);
+	reg &= ~CPSW_ALE_CTL_BYPASS;
+	if (set)
+		reg |= CPSW_ALE_CTL_BYPASS;
+	cpsw_write_4(sc->swsc, CPSW_ALE_CONTROL, reg);
+static void
+cpsw_set_allmulti(struct cpswp_softc *sc, int set)
+	if (set) {
+		printf("All-multicast mode unimplemented\n");
+static int
+cpswp_ioctl(struct ifnet *ifp, u_long command, caddr_t data)
+	struct ifreq *ifr;
+	int error;
+	uint32_t changed;
+	error = 0;
+	sc = ifp->if_softc;
+	ifr = (struct ifreq *)data;
+	switch (command) {
+	case SIOCSIFCAP:
+		changed = ifp->if_capenable ^ ifr->ifr_reqcap;
+		if (changed & IFCAP_HWCSUM) {
+			if ((ifr->ifr_reqcap & changed) & IFCAP_HWCSUM)
+				ifp->if_capenable |= IFCAP_HWCSUM;
+			else
+				ifp->if_capenable &= ~IFCAP_HWCSUM;
+		error = 0;
+		break;
+	case SIOCSIFFLAGS:
+		if (ifp->if_flags & IFF_UP) {
+			if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+				changed = ifp->if_flags ^ sc->if_flags;
+				    ("SIOCSIFFLAGS: UP & RUNNING (changed=0x%x)",
+				    changed));
+				if (changed & IFF_PROMISC)
+					cpsw_set_promisc(sc,
+					    ifp->if_flags & IFF_PROMISC);
+				if (changed & IFF_ALLMULTI)
+					cpsw_set_allmulti(sc,
+					    ifp->if_flags & IFF_ALLMULTI);
+			} else {
+				    ("SIOCSIFFLAGS: starting up"));
+				cpswp_init_locked(sc);
+		} else if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+			CPSW_DEBUGF(sc->swsc, ("SIOCSIFFLAGS: shutting down"));
+		sc->if_flags = ifp->if_flags;
+		break;
+	case SIOCADDMULTI:
+		cpswp_ale_update_addresses(sc, 0);
+		break;
+	case SIOCDELMULTI:
+		/* Ugh.  DELMULTI doesn't provide the specific address
+		   being removed, so the best we can do is remove
+		   everything and rebuild it all. */
+		break;
+	case SIOCGIFMEDIA:
+	case SIOCSIFMEDIA:
+		error = ifmedia_ioctl(ifp, ifr, &sc->mii->mii_media, command);
+		break;
+	default:
+		error = ether_ioctl(ifp, command, data);
+	return (error);
+ * MIIBUS
+static int
+cpswp_miibus_ready(struct cpsw_softc *sc, uint32_t reg)
+	uint32_t r, retries = CPSW_MIIBUS_RETRIES;
+	while (--retries) {
+		r = cpsw_read_4(sc, reg);
+		if ((r & MDIO_PHYACCESS_GO) == 0)
+			return (1);
+		DELAY(CPSW_MIIBUS_DELAY);
+	return (0);
+static int
+cpswp_miibus_readreg(device_t dev, int phy, int reg)
+	uint32_t cmd, r;
+	if (!cpswp_miibus_ready(sc->swsc, sc->phyaccess)) {
+		device_printf(dev, "MDIO not ready to read\n");
+		return (0);
+	/* Set GO, reg, phy */
+	cmd = MDIO_PHYACCESS_GO | (reg & 0x1F) << 21 | (phy & 0x1F) << 16;
+	cpsw_write_4(sc->swsc, sc->phyaccess, cmd);
+		device_printf(dev, "MDIO timed out during read\n");
+		return (0);
+	r = cpsw_read_4(sc->swsc, sc->phyaccess);
+	if ((r & MDIO_PHYACCESS_ACK) == 0) {
+		device_printf(dev, "Failed to read from PHY.\n");
+		r = 0;
+	return (r & 0xFFFF);
+static int
+cpswp_miibus_writereg(device_t dev, int phy, int reg, int value)
+	uint32_t cmd;
+		device_printf(dev, "MDIO not ready to write\n");
+		return (0);
+	/* Set GO, WRITE, reg, phy, and value */
+	cmd = MDIO_PHYACCESS_GO | MDIO_PHYACCESS_WRITE |
+	    (reg & 0x1F) << 21 | (phy & 0x1F) << 16 | (value & 0xFFFF);
+		device_printf(dev, "MDIO timed out during write\n");
+		return (0);
+	return (0);
+static void
+cpswp_miibus_statchg(device_t dev)
+	uint32_t mac_control, reg;
+	reg = CPSW_SL_MACCONTROL(sc->unit);
+	mac_control = cpsw_read_4(sc->swsc, reg);
+	mac_control &= ~(CPSW_SL_MACTL_GIG | CPSW_SL_MACTL_IFCTL_A |
+	    CPSW_SL_MACTL_IFCTL_B | CPSW_SL_MACTL_FULLDUPLEX);
+	switch(IFM_SUBTYPE(sc->mii->mii_media_active)) {
+	case IFM_1000_SX:
+	case IFM_1000_LX:
+	case IFM_1000_CX:
+	case IFM_1000_T:
+		mac_control |= CPSW_SL_MACTL_GIG;
+		break;
+	case IFM_100_TX:
+		mac_control |= CPSW_SL_MACTL_IFCTL_A;
+		break;
+	if (sc->mii->mii_media_active & IFM_FDX)
+		mac_control |= CPSW_SL_MACTL_FULLDUPLEX;
+	cpsw_write_4(sc->swsc, reg, mac_control);
+ * Transmit/Receive Packets.
+static void
+cpsw_intr_rx(void *arg)
+	struct mbuf *received, *next;
+	sc = (struct cpsw_softc *)arg;
+	CPSW_RX_LOCK(sc);
+	if (sc->rx.teardown) {
+		sc->rx.running = 0;
+		sc->rx.teardown = 0;
+		cpsw_write_cp(sc, &sc->rx, 0xfffffffc);
+	received = cpsw_rx_dequeue(sc);
+	cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 1);
+	while (received != NULL) {
+		next = received->m_nextpkt;
+		received->m_nextpkt = NULL;
+		ifp = received->m_pkthdr.rcvif;
+		(*ifp->if_input)(ifp, received);
+		if_inc_counter(ifp, IFCOUNTER_IPACKETS, 1);
+		received = next;
+cpsw_rx_dequeue(struct cpsw_softc *sc)
+	int nsegs, port, removed;
+	struct cpsw_slot *last, *slot;
+	struct mbuf *m, *m0, *mb_head, *mb_tail;
+	uint16_t m0_flags;
+	nsegs = 0;
+	m0 = NULL;
+	last = NULL;
+	mb_head = NULL;
+	mb_tail = NULL;
+	removed = 0;
+	/* Pull completed packets off hardware RX queue. */
+	while ((slot = STAILQ_FIRST(&sc->rx.active)) != NULL) {
+		 * Stop on packets still in use by hardware, but do not stop
+		 * on packets with the teardown complete flag, they will be
+		 * discarded later.
+		if ((bd.flags & (CPDMA_BD_OWNER | CPDMA_BD_TDOWNCMPLT)) ==
+		    CPDMA_BD_OWNER)
+			break;
+		last = slot;
+		++removed;
+		STAILQ_REMOVE_HEAD(&sc->rx.active, next);
+		STAILQ_INSERT_TAIL(&sc->rx.avail, slot, next);
+		bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_POSTREAD);
+		m = slot->mbuf;
+		if (bd.flags & CPDMA_BD_TDOWNCMPLT) {
+			CPSW_DEBUGF(sc, ("RX teardown is complete"));
+			m_freem(m);
+			break;
+		port = (bd.flags & CPDMA_BD_PORT_MASK) - 1;
+		KASSERT(port >= 0 && port <= 1,
+		    ("patcket received with invalid port: %d", port));
+		psc = device_get_softc(sc->port[port].dev);
+		/* Set up mbuf */
+		m->m_data += bd.bufoff;
+		m->m_len = bd.buflen;
+		if (bd.flags & CPDMA_BD_SOP) {
+			m->m_pkthdr.len = bd.pktlen;
+			m->m_pkthdr.rcvif = psc->ifp;
+			m->m_flags |= M_PKTHDR;
+			m0_flags = bd.flags;
+			m0 = m;
+		nsegs++;
+		m->m_next = NULL;
+		m->m_nextpkt = NULL;
+		if (bd.flags & CPDMA_BD_EOP && m0 != NULL) {
+			if (m0_flags & CPDMA_BD_PASS_CRC)
+				m_adj(m0, -ETHER_CRC_LEN);
+			m0_flags = 0;
+			m0 = NULL;
+			if (nsegs > sc->rx.longest_chain)
+				sc->rx.longest_chain = nsegs;
+			nsegs = 0;
+		if ((psc->ifp->if_capenable & IFCAP_RXCSUM) != 0) {
+			/* check for valid CRC by looking into pkt_err[5:4] */
+			if ((bd.flags &
+			    (CPDMA_BD_SOP | CPDMA_BD_PKT_ERR_MASK)) ==
+			    CPDMA_BD_SOP) {
+				m->m_pkthdr.csum_flags |= CSUM_IP_CHECKED;
+				m->m_pkthdr.csum_flags |= CSUM_IP_VALID;
+				m->m_pkthdr.csum_data = 0xffff;
+		if (STAILQ_FIRST(&sc->rx.active) != NULL &&
+		    (bd.flags & (CPDMA_BD_EOP | CPDMA_BD_EOQ)) ==
+		    (CPDMA_BD_EOP | CPDMA_BD_EOQ)) {
+			    STAILQ_FIRST(&sc->rx.active));
+			sc->rx.queue_restart++;
+		/* Add mbuf to packet list to be returned. */
+		if (mb_tail != NULL && (bd.flags & CPDMA_BD_SOP)) {
+			mb_tail->m_nextpkt = m;
+		} else if (mb_tail != NULL) {
+			mb_tail->m_next = m;
+		} else if (mb_tail == NULL && (bd.flags & CPDMA_BD_SOP) == 0) {
+			if (bootverbose)
+				printf(
+				    "%s: %s: discanding fragment packet w/o header\n",
+				    __func__, psc->ifp->if_xname);
+			m_freem(m);
+			continue;
+		} else {
+			mb_head = m;
+		mb_tail = m;
+	if (removed != 0) {
+		cpsw_write_cp_slot(sc, &sc->rx, last);
+		sc->rx.queue_removes += removed;
+		sc->rx.avail_queue_len += removed;
+		sc->rx.active_queue_len -= removed;
+		if (sc->rx.avail_queue_len > sc->rx.max_avail_queue_len)
+			sc->rx.max_avail_queue_len = sc->rx.avail_queue_len;
+		CPSW_DEBUGF(sc, ("Removed %d received packet(s) from RX queue", removed));
+	return (mb_head);
+static void
+cpsw_rx_enqueue(struct cpsw_softc *sc)
+	bus_dma_segment_t seg[1];
+	struct cpsw_slot *first_new_slot, *last_old_slot, *next, *slot;
+	int error, nsegs, added = 0;
+	/* Register new mbufs with hardware. */
+	first_new_slot = NULL;
+	last_old_slot = STAILQ_LAST(&sc->rx.active, cpsw_slot, next);
+	while ((slot = STAILQ_FIRST(&sc->rx.avail)) != NULL) {
+		if (first_new_slot == NULL)
+			first_new_slot = slot;
+		if (slot->mbuf == NULL) {
+			slot->mbuf = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
+				    "Unable to fill RX queue\n");
+				break;
+			slot->mbuf->m_len =
+			    slot->mbuf->m_pkthdr.len =
+			    slot->mbuf->m_ext.ext_size;
+		error = bus_dmamap_load_mbuf_sg(sc->mbuf_dtag, slot->dmamap,
+		    slot->mbuf, seg, &nsegs, BUS_DMA_NOWAIT);
+		KASSERT(nsegs == 1, ("More than one segment (nsegs=%d)", nsegs));
+		KASSERT(error == 0, ("DMA error (error=%d)", error));
+		if (error != 0 || nsegs != 1) {
+			    "%s: Can't prep RX buf for DMA (nsegs=%d, error=%d)\n",
+			    __func__, nsegs, error);
+			break;
+		bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_PREREAD);
+		/* Create and submit new rx descriptor. */
+		if ((next = STAILQ_NEXT(slot, next)) != NULL)
+			bd.next = cpsw_cpdma_bd_paddr(sc, next);
+		else
+			bd.next = 0;
+		bd.bufptr = seg->ds_addr;
+		bd.bufoff = 0;
+		bd.buflen = MCLBYTES - 1;
+		bd.pktlen = bd.buflen;
+		bd.flags = CPDMA_BD_OWNER;
+		cpsw_cpdma_write_bd(sc, slot, &bd);
+		++added;
+		STAILQ_REMOVE_HEAD(&sc->rx.avail, next);
+		STAILQ_INSERT_TAIL(&sc->rx.active, slot, next);
+	if (added == 0 || first_new_slot == NULL)
+		return;
+	CPSW_DEBUGF(sc, ("Adding %d buffers to RX queue", added));
+	/* Link new entries to hardware RX queue. */
+	if (last_old_slot == NULL) {
+		/* Start a fresh queue. */
+		cpsw_write_hdp_slot(sc, &sc->rx, first_new_slot);
+	} else {
+		/* Add buffers to end of current queue. */
+		cpsw_cpdma_write_bd_next(sc, last_old_slot, first_new_slot);
+	sc->rx.queue_adds += added;
+	sc->rx.avail_queue_len -= added;
+	sc->rx.active_queue_len += added;
+	cpsw_write_4(sc, CPSW_CPDMA_RX_FREEBUFFER(0), added);
+	if (sc->rx.active_queue_len > sc->rx.max_active_queue_len)
+		sc->rx.max_active_queue_len = sc->rx.active_queue_len;
+static void
+cpswp_start(struct ifnet *ifp)
+	if ((ifp->if_drv_flags & IFF_DRV_RUNNING) == 0 ||
+	    sc->swsc->tx.running == 0) {
+		return;
+	CPSW_TX_LOCK(sc->swsc);
+	cpswp_tx_enqueue(sc);
+	cpsw_tx_dequeue(sc->swsc);
+	CPSW_TX_UNLOCK(sc->swsc);
+static void
+cpsw_intr_tx(void *arg)
+	CPSW_TX_LOCK(sc);
+	if (cpsw_read_4(sc, CPSW_CPDMA_TX_CP(0)) == 0xfffffffc)
+		cpsw_write_cp(sc, &sc->tx, 0xfffffffc);
+	cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 2);
+static void
+cpswp_tx_enqueue(struct cpswp_softc *sc)
+	bus_dma_segment_t segs[CPSW_TXFRAGS];
+	struct cpsw_slot *first_new_slot, *last, *last_old_slot, *next, *slot;
+	struct mbuf *m0;
+	int error, nsegs, seg, added = 0, padlen;
+	/* Pull pending packets from IF queue and prep them for DMA. */
+	last = NULL;
+	last_old_slot = STAILQ_LAST(&sc->swsc->tx.active, cpsw_slot, next);
+	while ((slot = STAILQ_FIRST(&sc->swsc->tx.avail)) != NULL) {
+		IF_DEQUEUE(&sc->ifp->if_snd, m0);
+		if (m0 == NULL)
+			break;
+		slot->mbuf = m0;
+		padlen = ETHER_MIN_LEN - ETHER_CRC_LEN - m0->m_pkthdr.len;
+		if (padlen < 0)
+			padlen = 0;
+		else if (padlen > 0)
+			m_append(slot->mbuf, padlen, sc->swsc->nullpad);
+		/* Create mapping in DMA memory */
+		error = bus_dmamap_load_mbuf_sg(sc->swsc->mbuf_dtag,
+		    slot->dmamap, slot->mbuf, segs, &nsegs, BUS_DMA_NOWAIT);
+		/* If the packet is too fragmented, try to simplify. */
+		if (error == EFBIG ||
+		    (error == 0 && nsegs > sc->swsc->tx.avail_queue_len)) {
+			bus_dmamap_unload(sc->swsc->mbuf_dtag, slot->dmamap);
+			m0 = m_defrag(slot->mbuf, M_NOWAIT);
+			if (m0 == NULL) {
+				    "Can't defragment packet; dropping\n");
+			} else {
+				    ("Requeueing defragmented packet"));
+				IF_PREPEND(&sc->ifp->if_snd, m0);
+			continue;
+		if (error != 0) {
+			    "%s: Can't setup DMA (error=%d), dropping packet\n",
+			    __func__, error);
+			break;
+		bus_dmamap_sync(sc->swsc->mbuf_dtag, slot->dmamap,
+				BUS_DMASYNC_PREWRITE);
+		    ("Queueing TX packet: %d segments + %d pad bytes",
+		    nsegs, padlen));
+		/* Link from the previous descriptor. */
+		if (last != NULL)
+			cpsw_cpdma_write_bd_next(sc->swsc, last, slot);
+		slot->ifp = sc->ifp;
+		/* If there is only one segment, the for() loop
+		 * gets skipped and the single buffer gets set up
+		 * as both SOP and EOP. */
+		if (nsegs > 1) {
+			next = STAILQ_NEXT(slot, next);
+			bd.next = cpsw_cpdma_bd_paddr(sc->swsc, next);
+		} else
+			bd.next = 0;
+		/* Start by setting up the first buffer. */
+		bd.bufptr = segs[0].ds_addr;
+		bd.bufoff = 0;
+		bd.buflen = segs[0].ds_len;
+		bd.pktlen = m_length(slot->mbuf, NULL);
+		bd.flags =  CPDMA_BD_SOP | CPDMA_BD_OWNER;
+			bd.flags |= CPDMA_BD_TO_PORT;
+			bd.flags |= ((sc->unit + 1) & CPDMA_BD_PORT_MASK);
+		for (seg = 1; seg < nsegs; ++seg) {
+			/* Save the previous buffer (which isn't EOP) */
+			cpsw_cpdma_write_bd(sc->swsc, slot, &bd);
+			STAILQ_REMOVE_HEAD(&sc->swsc->tx.avail, next);
+			STAILQ_INSERT_TAIL(&sc->swsc->tx.active, slot, next);
+			slot = STAILQ_FIRST(&sc->swsc->tx.avail);
+			/* Setup next buffer (which isn't SOP) */
+			if (nsegs > seg + 1) {
+			} else
+				bd.next = 0;
+			bd.bufptr = segs[seg].ds_addr;
+			bd.bufoff = 0;
+			bd.buflen = segs[seg].ds_len;
+			bd.pktlen = 0;
+		/* Save the final buffer. */
+		bd.flags |= CPDMA_BD_EOP;
+		last = slot;
+		added += nsegs;
+		if (nsegs > sc->swsc->tx.longest_chain)
+			sc->swsc->tx.longest_chain = nsegs;
+		BPF_MTAP(sc->ifp, m0);
+		return;
+	/* Attach the list of new buffers to the hardware TX queue. */
+	if (last_old_slot != NULL &&
+	    (cpsw_cpdma_read_bd_flags(sc->swsc, last_old_slot) &
+	     CPDMA_BD_EOQ) == 0) {
+		cpsw_cpdma_write_bd_next(sc->swsc, last_old_slot,
+		    first_new_slot);
+	} else {
+		cpsw_write_hdp_slot(sc->swsc, &sc->swsc->tx, first_new_slot);
+	sc->swsc->tx.queue_adds += added;
+	sc->swsc->tx.avail_queue_len -= added;
+	sc->swsc->tx.active_queue_len += added;
+	if (sc->swsc->tx.active_queue_len > sc->swsc->tx.max_active_queue_len) {
+		sc->swsc->tx.max_active_queue_len = sc->swsc->tx.active_queue_len;
+	CPSW_DEBUGF(sc->swsc, ("Queued %d TX packet(s)", added));
+static int
+cpsw_tx_dequeue(struct cpsw_softc *sc)
+	struct cpsw_slot *slot, *last_removed_slot = NULL;
+	uint32_t flags, removed = 0;
+	/* Pull completed buffers off the hardware TX queue. */
+	while (slot != NULL) {
+		flags = cpsw_cpdma_read_bd_flags(sc, slot);
+		/* TearDown complete is only marked on the SOP for the packet. */
+		if ((flags & (CPDMA_BD_SOP | CPDMA_BD_TDOWNCMPLT)) ==
+		    (CPDMA_BD_SOP | CPDMA_BD_TDOWNCMPLT)) {
+		if ((flags & (CPDMA_BD_SOP | CPDMA_BD_OWNER)) ==
+		    (CPDMA_BD_SOP | CPDMA_BD_OWNER) && sc->tx.teardown == 0)
+			break; /* Hardware is still using this packet. */
+		bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_POSTWRITE);
+		if (slot->ifp) {
+			if (sc->tx.teardown == 0)
+				if_inc_counter(slot->ifp, IFCOUNTER_OPACKETS, 1);
+			else
+				if_inc_counter(slot->ifp, IFCOUNTER_OQDROPS, 1);
+		/* Dequeue any additional buffers used by this packet. */
+		while (slot != NULL && slot->mbuf == NULL) {
+			STAILQ_REMOVE_HEAD(&sc->tx.active, next);
+			STAILQ_INSERT_TAIL(&sc->tx.avail, slot, next);
+			++removed;
+			last_removed_slot = slot;
+		cpsw_write_cp_slot(sc, &sc->tx, last_removed_slot);
+		/* Restart the TX queue if necessary. */
+		cpsw_cpdma_read_bd(sc, last_removed_slot, &bd);
+		if (slot != NULL && bd.next != 0 && (bd.flags &
+		    (CPDMA_BD_EOP | CPDMA_BD_OWNER | CPDMA_BD_EOQ)) ==
+			sc->tx.queue_restart++;
+			break;
+		sc->tx.queue_removes += removed;
+		sc->tx.active_queue_len -= removed;
+		sc->tx.avail_queue_len += removed;
+		if (sc->tx.avail_queue_len > sc->tx.max_avail_queue_len)
+			sc->tx.max_avail_queue_len = sc->tx.avail_queue_len;
+		CPSW_DEBUGF(sc, ("TX removed %d completed packet(s)", removed));
+	if (sc->tx.teardown && STAILQ_EMPTY(&sc->tx.active)) {
+		CPSW_DEBUGF(sc, ("TX teardown is complete"));
+		sc->tx.teardown = 0;
+		sc->tx.running = 0;
+	return (removed);
+ * Miscellaneous interrupts.
+static void
+cpsw_intr_rx_thresh(void *arg)
+	CPSW_RX_LOCK(sc);
+	cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 0);
+		received = next;
+static void
+cpsw_intr_misc_host_error(struct cpsw_softc *sc)
+	uint32_t intstat;
+	uint32_t dmastat;
+	int txerr, rxerr, txchan, rxchan;
+	printf("\n\n");
+	    "HOST ERROR:  PROGRAMMING ERROR DETECTED BY HARDWARE\n");
+	printf("\n\n");
+	intstat = cpsw_read_4(sc, CPSW_CPDMA_DMA_INTSTAT_MASKED);
+	device_printf(sc->dev, "CPSW_CPDMA_DMA_INTSTAT_MASKED=0x%x\n", intstat);
+	dmastat = cpsw_read_4(sc, CPSW_CPDMA_DMASTATUS);
+	device_printf(sc->dev, "CPSW_CPDMA_DMASTATUS=0x%x\n", dmastat);
+	txerr = (dmastat >> 20) & 15;
+	txchan = (dmastat >> 16) & 7;
+	rxerr = (dmastat >> 12) & 15;
+	rxchan = (dmastat >> 8) & 7;
+	switch (txerr) {
+	case 0: break;
+	case 1:	printf("SOP error on TX channel %d\n", txchan);
+		break;
+	case 2:	printf("Ownership bit not set on SOP buffer on TX channel %d\n", txchan);
+		break;
+	case 3:	printf("Zero Next Buffer but not EOP on TX channel %d\n", txchan);
+		break;
+	case 4:	printf("Zero Buffer Pointer on TX channel %d\n", txchan);
+		break;
+	case 5:	printf("Zero Buffer Length on TX channel %d\n", txchan);
+		break;
+	case 6:	printf("Packet length error on TX channel %d\n", txchan);
+		break;
+	default: printf("Unknown error on TX channel %d\n", txchan);
+		break;
+	if (txerr != 0) {
+		printf("CPSW_CPDMA_TX%d_HDP=0x%x\n",
+		    txchan, cpsw_read_4(sc, CPSW_CPDMA_TX_HDP(txchan)));
+		printf("CPSW_CPDMA_TX%d_CP=0x%x\n",
+		    txchan, cpsw_read_4(sc, CPSW_CPDMA_TX_CP(txchan)));
+		cpsw_dump_queue(sc, &sc->tx.active);
+	switch (rxerr) {
+	case 0: break;
+	case 2:	printf("Ownership bit not set on RX channel %d\n", rxchan);
+		break;
+	case 4:	printf("Zero Buffer Pointer on RX channel %d\n", rxchan);
+		break;
+	case 5:	printf("Zero Buffer Length on RX channel %d\n", rxchan);
+		break;
+	case 6:	printf("Buffer offset too big on RX channel %d\n", rxchan);
+		break;
+	default: printf("Unknown RX error on RX channel %d\n", rxchan);
+		break;
+	if (rxerr != 0) {
+		printf("CPSW_CPDMA_RX%d_HDP=0x%x\n",
+		    rxchan, cpsw_read_4(sc,CPSW_CPDMA_RX_HDP(rxchan)));
+		printf("CPSW_CPDMA_RX%d_CP=0x%x\n",
+		    rxchan, cpsw_read_4(sc, CPSW_CPDMA_RX_CP(rxchan)));
+		cpsw_dump_queue(sc, &sc->rx.active);
+	printf("\nALE Table\n");
+	cpsw_ale_dump_table(sc);
+	// XXX do something useful here??
+	panic("CPSW HOST ERROR INTERRUPT");
+	// Suppress this interrupt in the future.
+	cpsw_write_4(sc, CPSW_CPDMA_DMA_INTMASK_CLEAR, intstat);
+	printf("XXX HOST ERROR INTERRUPT SUPPRESSED\n");
+	// The watchdog will probably reset the controller
+	// in a little while.  It will probably fail again.
+static void
+cpsw_intr_misc(void *arg)
+	struct cpsw_softc *sc = arg;
+	uint32_t stat = cpsw_read_4(sc, CPSW_WR_C_MISC_STAT(0));
+	if (stat & CPSW_WR_C_MISC_EVNT_PEND)
+		CPSW_DEBUGF(sc, ("Time sync event interrupt unimplemented"));
+	if (stat & CPSW_WR_C_MISC_STAT_PEND)
+		cpsw_stats_collect(sc);
+	if (stat & CPSW_WR_C_MISC_HOST_PEND)
+		cpsw_intr_misc_host_error(sc);
+	if (stat & CPSW_WR_C_MISC_MDIOLINK) {
+		cpsw_write_4(sc, MDIOLINKINTMASKED,
+		    cpsw_read_4(sc, MDIOLINKINTMASKED));
+	if (stat & CPSW_WR_C_MISC_MDIOUSER) {
+		CPSW_DEBUGF(sc,
+		    ("MDIO operation completed interrupt unimplemented"));
+	cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 3);
+ * Periodic Checks and Watchdog.
+static void
+cpswp_tick(void *msc)
+	struct cpswp_softc *sc = msc;
+	/* Check for media type change */
+	mii_tick(sc->mii);
+	if (sc->media_status != sc->mii->mii_media.ifm_media) {
+		printf("%s: media type changed (ifm_media=%x)\n", __func__,
+			sc->mii->mii_media.ifm_media);
+		cpswp_ifmedia_upd(sc->ifp);
+	/* Schedule another timeout one second from now */
+static void
+cpswp_ifmedia_sts(struct ifnet *ifp, struct ifmediareq *ifmr)
+	struct mii_data *mii;
+	mii = sc->mii;
+	mii_pollstat(mii);
+	ifmr->ifm_active = mii->mii_media_active;
+	ifmr->ifm_status = mii->mii_media_status;
+static int
+cpswp_ifmedia_upd(struct ifnet *ifp)
+	sc->media_status = sc->mii->mii_media.ifm_media;
+	return (0);
+static void
+cpsw_tx_watchdog_full_reset(struct cpsw_softc *sc)
+	int i;
+	cpsw_debugf_head("CPSW watchdog");
+	device_printf(sc->dev, "watchdog timeout\n");
+	printf("CPSW_CPDMA_TX%d_HDP=0x%x\n", 0,
+	    cpsw_read_4(sc, CPSW_CPDMA_TX_HDP(0)));
+	printf("CPSW_CPDMA_TX%d_CP=0x%x\n", 0,
+	    cpsw_read_4(sc, CPSW_CPDMA_TX_CP(0)));
+			continue;
+static void
+cpsw_tx_watchdog(void *msc)
+	sc = msc;
+	CPSW_TX_LOCK(sc);
+	if (sc->tx.active_queue_len == 0 || !sc->tx.running) {
+		sc->watchdog.timer = 0; /* Nothing to do. */
+	} else if (sc->tx.queue_removes > sc->tx.queue_removes_at_last_tick) {
+		sc->watchdog.timer = 0;  /* Stuff done while we weren't looking. */
+	} else if (cpsw_tx_dequeue(sc) > 0) {
+		sc->watchdog.timer = 0;  /* We just did something. */
+	} else {
+		/* There was something to do but it didn't get done. */
+		++sc->watchdog.timer;
+		if (sc->watchdog.timer > 5) {
+			++sc->watchdog.resets;
+			cpsw_tx_watchdog_full_reset(sc);
+	sc->tx.queue_removes_at_last_tick = sc->tx.queue_removes;
+ * ALE support routines.
+static void
+cpsw_ale_read_entry(struct cpsw_softc *sc, uint16_t idx, uint32_t *ale_entry)
+	cpsw_write_4(sc, CPSW_ALE_TBLCTL, idx & 1023);
+	ale_entry[0] = cpsw_read_4(sc, CPSW_ALE_TBLW0);
+	ale_entry[1] = cpsw_read_4(sc, CPSW_ALE_TBLW1);
+	ale_entry[2] = cpsw_read_4(sc, CPSW_ALE_TBLW2);
+static void
+cpsw_ale_write_entry(struct cpsw_softc *sc, uint16_t idx, uint32_t *ale_entry)
+	cpsw_write_4(sc, CPSW_ALE_TBLW0, ale_entry[0]);
+	cpsw_write_4(sc, CPSW_ALE_TBLW1, ale_entry[1]);
+	cpsw_write_4(sc, CPSW_ALE_TBLW2, ale_entry[2]);
+	cpsw_write_4(sc, CPSW_ALE_TBLCTL, 1 << 31 | (idx & 1023));
+static void
+cpsw_ale_remove_all_mc_entries(struct cpsw_softc *sc)
+	int i;
+	uint32_t ale_entry[3];
+	/* First four entries are link address and broadcast. */
+	for (i = 10; i < CPSW_MAX_ALE_ENTRIES; i++) {
+		cpsw_ale_read_entry(sc, i, ale_entry);
+		if ((ALE_TYPE(ale_entry) == ALE_TYPE_ADDR ||
+		    ALE_TYPE(ale_entry) == ALE_TYPE_VLAN_ADDR) &&
+		    ALE_MCAST(ale_entry)  == 1) { /* MCast link addr */
+			ale_entry[0] = ale_entry[1] = ale_entry[2] = 0;
+			cpsw_ale_write_entry(sc, i, ale_entry);
+static int
+cpsw_ale_mc_entry_set(struct cpsw_softc *sc, uint8_t portmap, int vlan,
+	uint8_t *mac)
+	int free_index = -1, matching_index = -1, i;
+	uint32_t ale_entry[3], ale_type;
+	/* Find a matching entry or a free entry. */
+		/* Entry Type[61:60] is 0 for free entry */
+		if (free_index < 0 && ALE_TYPE(ale_entry) == 0)
+			free_index = i;
+		if ((((ale_entry[1] >> 8) & 0xFF) == mac[0]) &&
+		    (((ale_entry[1] >> 0) & 0xFF) == mac[1]) &&
+		    (((ale_entry[0] >>24) & 0xFF) == mac[2]) &&
+		    (((ale_entry[0] >>16) & 0xFF) == mac[3]) &&
+		    (((ale_entry[0] >> 8) & 0xFF) == mac[4]) &&
+		    (((ale_entry[0] >> 0) & 0xFF) == mac[5])) {
+			matching_index = i;
+			break;
+	if (matching_index < 0) {
+		if (free_index < 0)
+			return (ENOMEM);
+		i = free_index;
+	if (vlan != -1)
+		ale_type = ALE_TYPE_VLAN_ADDR << 28 | vlan << 16;
+	else
+		ale_type = ALE_TYPE_ADDR << 28;
+	/* Set MAC address */
+	ale_entry[0] = mac[2] << 24 | mac[3] << 16 | mac[4] << 8 | mac[5];
+	ale_entry[1] = mac[0] << 8 | mac[1];
+	/* Entry type[61:60] and Mcast fwd state[63:62] is fw(3). */
+	ale_entry[1] |= ALE_MCAST_FWD | ale_type;
+	/* Set portmask [68:66] */
+	ale_entry[2] = (portmap & 7) << 2;
+	return 0;
+static void
+cpsw_ale_dump_table(struct cpsw_softc *sc) {
+	int i;
+	for (i = 0; i < CPSW_MAX_ALE_ENTRIES; i++) {
+		switch (ALE_TYPE(ale_entry)) {
+		case ALE_TYPE_VLAN:
+			printf("ALE[%4u] %08x %08x %08x ", i, ale_entry[2],
+				ale_entry[1], ale_entry[0]);
+			printf("type: %u ", ALE_TYPE(ale_entry));
+			printf("vlan: %u ", ALE_VLAN(ale_entry));
+			printf("untag: %u ", ALE_VLAN_UNTAG(ale_entry));
+			printf("reg flood: %u ", ALE_VLAN_REGFLOOD(ale_entry));
+			printf("unreg flood: %u ", ALE_VLAN_UNREGFLOOD(ale_entry));
+			printf("members: %u ", ALE_VLAN_MEMBERS(ale_entry));
+			printf("\n");
+			break;
+		case ALE_TYPE_ADDR:
+		case ALE_TYPE_VLAN_ADDR:
+			printf("mac: %02x:%02x:%02x:%02x:%02x:%02x ",
+				(ale_entry[1] >> 8) & 0xFF,
+				(ale_entry[1] >> 0) & 0xFF,
+				(ale_entry[0] >>24) & 0xFF,
+				(ale_entry[0] >>16) & 0xFF,
+				(ale_entry[0] >> 8) & 0xFF,
+				(ale_entry[0] >> 0) & 0xFF);
+			printf(ALE_MCAST(ale_entry) ? "mcast " : "ucast ");
+			if (ALE_TYPE(ale_entry) == ALE_TYPE_VLAN_ADDR)
+			printf("port: %u ", ALE_PORTS(ale_entry));
+			printf("\n");
+			break;
+	printf("\n");
+static int
+cpswp_ale_update_addresses(struct cpswp_softc *sc, int purge)
+	uint8_t *mac;
+	uint32_t ale_entry[3], ale_type, portmask;
+	struct ifmultiaddr *ifma;
+		ale_type = ALE_TYPE_VLAN_ADDR << 28 | sc->vlan << 16;
+		portmask = 1 << (sc->unit + 1) | 1 << 0;
+	} else {
+		portmask = 7;
+	 * Route incoming packets for our MAC address to Port 0 (host).
+	 * For simplicity, keep this entry at table index 0 for port 1 and
+	 * at index 2 for port 2 in the ALE.
+        if_addr_rlock(sc->ifp);
+	mac = LLADDR((struct sockaddr_dl *)sc->ifp->if_addr->ifa_addr);
+	ale_entry[1] = ale_type | mac[0] << 8 | mac[1]; /* addr entry + mac */
+	ale_entry[2] = 0; /* port = 0 */
+	cpsw_ale_write_entry(sc->swsc, 0 + 2 * sc->unit, ale_entry);
+	/* Set outgoing MAC Address for slave port. */
+	cpsw_write_4(sc->swsc, CPSW_PORT_P_SA_HI(sc->unit + 1),
+	    mac[3] << 24 | mac[2] << 16 | mac[1] << 8 | mac[0]);
+	cpsw_write_4(sc->swsc, CPSW_PORT_P_SA_LO(sc->unit + 1),
+	    mac[5] << 8 | mac[4]);
+        if_addr_runlock(sc->ifp);
+	/* Keep the broadcast address at table entry 1 (or 3). */
+	ale_entry[0] = 0xffffffff; /* Lower 32 bits of MAC */
+	/* ALE_MCAST_FWD, Addr type, upper 16 bits of Mac */
+	ale_entry[1] = ALE_MCAST_FWD | ale_type | 0xffff;
+	ale_entry[2] = portmask << 2;
+	cpsw_ale_write_entry(sc->swsc, 1 + 2 * sc->unit, ale_entry);
+	/* SIOCDELMULTI doesn't specify the particular address
+	   being removed, so we have to remove all and rebuild. */
+	if (purge)
+		cpsw_ale_remove_all_mc_entries(sc->swsc);
+        /* Set other multicast addrs desired. */
+        if_maddr_rlock(sc->ifp);
+        CK_STAILQ_FOREACH(ifma, &sc->ifp->if_multiaddrs, ifma_link) {
+                if (ifma->ifma_addr->sa_family != AF_LINK)
+                        continue;
+		cpsw_ale_mc_entry_set(sc->swsc, portmask, sc->vlan,
+		    LLADDR((struct sockaddr_dl *)ifma->ifma_addr));
+        if_maddr_runlock(sc->ifp);
+	return (0);
+static int
+cpsw_ale_update_vlan_table(struct cpsw_softc *sc, int vlan, int ports,
+	int untag, int mcregflood, int mcunregflood)
+	int free_index, i, matching_index;
+	free_index = matching_index = -1;
+	for (i = 5; i < CPSW_MAX_ALE_ENTRIES; i++) {
+			free_index = i;
+		if (ALE_VLAN(ale_entry) == vlan) {
+			break;
+			return (-1);
+		i = free_index;
+	ale_entry[0] = (untag & 7) << 24 | (mcregflood & 7) << 16 |
+	    (mcunregflood & 7) << 8 | (ports & 7);
+	ale_entry[1] = ALE_TYPE_VLAN << 28 | vlan << 16;
+	ale_entry[2] = 0;
+	return (0);
+ * Statistics and Sysctls.
+#if 0
+static void
+cpsw_stats_dump(struct cpsw_softc *sc)
+	int i;
+	uint32_t r;
+	for (i = 0; i < CPSW_SYSCTL_COUNT; ++i) {
+		r = cpsw_read_4(sc, CPSW_STATS_OFFSET +
+		    cpsw_stat_sysctls[i].reg);
+		CPSW_DEBUGF(sc, ("%s: %ju + %u = %ju", cpsw_stat_sysctls[i].oid,
+		    (intmax_t)sc->shadow_stats[i], r,
+		    (intmax_t)sc->shadow_stats[i] + r));
+#endif
+static void
+cpsw_stats_collect(struct cpsw_softc *sc)
+	int i;
+	uint32_t r;
+	CPSW_DEBUGF(sc, ("Controller shadow statistics updated."));
+		sc->shadow_stats[i] += r;
+		cpsw_write_4(sc, CPSW_STATS_OFFSET + cpsw_stat_sysctls[i].reg,
+		    r);
+static int
+cpsw_stats_sysctl(SYSCTL_HANDLER_ARGS)
+	struct cpsw_stat *stat;
+	uint64_t result;
+	sc = (struct cpsw_softc *)arg1;
+	stat = &cpsw_stat_sysctls[oidp->oid_number];
+	result = sc->shadow_stats[oidp->oid_number];
+	result += cpsw_read_4(sc, CPSW_STATS_OFFSET + stat->reg);
+	return (sysctl_handle_64(oidp, &result, 0, req));
+static int
+cpsw_stat_attached(SYSCTL_HANDLER_ARGS)
+	struct bintime t;
+	unsigned result;
+	getbinuptime(&t);
+	bintime_sub(&t, &sc->attach_uptime);
+	result = t.sec;
+	return (sysctl_handle_int(oidp, &result, 0, req));
+static int
+cpsw_intr_coalesce(SYSCTL_HANDLER_ARGS)
+	int error;
+	uint32_t ctrl, intr_per_ms;
+	error = sysctl_handle_int(oidp, &sc->coal_us, 0, req);
+	if (error != 0 || req->newptr == NULL)
+		return (error);
+	ctrl = cpsw_read_4(sc, CPSW_WR_INT_CONTROL);
+	ctrl &= ~(CPSW_WR_INT_PACE_EN | CPSW_WR_INT_PRESCALE_MASK);
+	if (sc->coal_us == 0) {
+		/* Disable the interrupt pace hardware. */
+		cpsw_write_4(sc, CPSW_WR_INT_CONTROL, ctrl);
+		cpsw_write_4(sc, CPSW_WR_C_RX_IMAX(0), 0);
+		cpsw_write_4(sc, CPSW_WR_C_TX_IMAX(0), 0);
+		return (0);
+	if (sc->coal_us > CPSW_WR_C_IMAX_US_MAX)
+		sc->coal_us = CPSW_WR_C_IMAX_US_MAX;
+	if (sc->coal_us < CPSW_WR_C_IMAX_US_MIN)
+		sc->coal_us = CPSW_WR_C_IMAX_US_MIN;
+	intr_per_ms = 1000 / sc->coal_us;
+	/* Just to make sure... */
+	if (intr_per_ms > CPSW_WR_C_IMAX_MAX)
+		intr_per_ms = CPSW_WR_C_IMAX_MAX;
+	if (intr_per_ms < CPSW_WR_C_IMAX_MIN)
+		intr_per_ms = CPSW_WR_C_IMAX_MIN;
+	/* Set the prescale to produce 4us pulses from the 125 Mhz clock. */
+	ctrl |= (125 * 4) & CPSW_WR_INT_PRESCALE_MASK;
+	/* Enable the interrupt pace hardware. */
+	cpsw_write_4(sc, CPSW_WR_C_RX_IMAX(0), intr_per_ms);
+	cpsw_write_4(sc, CPSW_WR_C_TX_IMAX(0), intr_per_ms);
+	ctrl |= CPSW_WR_INT_C0_RX_PULSE | CPSW_WR_INT_C0_TX_PULSE;
+	return (0);
+static int
+cpsw_stat_uptime(SYSCTL_HANDLER_ARGS)
+	struct cpsw_softc *swsc;
+	struct bintime t;
+	unsigned result;
+	swsc = arg1;
+	sc = device_get_softc(swsc->port[arg2].dev);
+	if (sc->ifp->if_drv_flags & IFF_DRV_RUNNING) {
+		getbinuptime(&t);
+		bintime_sub(&t, &sc->init_uptime);
+		result = t.sec;
+	} else
+		result = 0;
+static void
+cpsw_add_queue_sysctls(struct sysctl_ctx_list *ctx, struct sysctl_oid *node,
+	struct cpsw_queue *queue)
+	struct sysctl_oid_list *parent;
+	parent = SYSCTL_CHILDREN(node);
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "totalBuffers",
+	    CTLFLAG_RD, &queue->queue_slots, 0,
+	    "Total buffers currently assigned to this queue");
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "activeBuffers",
+	    CTLFLAG_RD, &queue->active_queue_len, 0,
+	    "Buffers currently registered with hardware controller");
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "maxActiveBuffers",
+	    CTLFLAG_RD, &queue->max_active_queue_len, 0,
+	    "Max value of activeBuffers since last driver reset");
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "availBuffers",
+	    CTLFLAG_RD, &queue->avail_queue_len, 0,
+	    "Buffers allocated to this queue but not currently "
+	    "registered with hardware controller");
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "maxAvailBuffers",
+	    CTLFLAG_RD, &queue->max_avail_queue_len, 0,
+	    "Max value of availBuffers since last driver reset");
+	SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "totalEnqueued",
+	    CTLFLAG_RD, &queue->queue_adds, 0,
+	    "Total buffers added to queue");
+	SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "totalDequeued",
+	    CTLFLAG_RD, &queue->queue_removes, 0,
+	    "Total buffers removed from queue");
+	SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "queueRestart",
+	    CTLFLAG_RD, &queue->queue_restart, 0,
+	    "Total times the queue has been restarted");
+	SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "longestChain",
+	    CTLFLAG_RD, &queue->longest_chain, 0,
+	    "Max buffers used for a single packet");
+static void
+cpsw_add_watchdog_sysctls(struct sysctl_ctx_list *ctx, struct sysctl_oid *node,
+	struct cpsw_softc *sc)
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "resets",
+	    CTLFLAG_RD, &sc->watchdog.resets, 0,
+	    "Total number of watchdog resets");
+static void
+cpsw_add_sysctls(struct cpsw_softc *sc)
+	struct sysctl_ctx_list *ctx;
+	struct sysctl_oid *stats_node, *queue_node, *node;
+	struct sysctl_oid_list *parent, *stats_parent, *queue_parent;
+	struct sysctl_oid_list *ports_parent, *port_parent;
+	char port[16];
+	int i;
+	ctx = device_get_sysctl_ctx(sc->dev);
+	parent = SYSCTL_CHILDREN(device_get_sysctl_tree(sc->dev));
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "debug",
+	    CTLFLAG_RW, &sc->debug, 0, "Enable switch debug messages");
+	SYSCTL_ADD_PROC(ctx, parent, OID_AUTO, "attachedSecs",
+	    CTLTYPE_UINT | CTLFLAG_RD, sc, 0, cpsw_stat_attached, "IU",
+	    "Time since driver attach");
+	SYSCTL_ADD_PROC(ctx, parent, OID_AUTO, "intr_coalesce_us",
+	    CTLTYPE_UINT | CTLFLAG_RW, sc, 0, cpsw_intr_coalesce, "IU",
+	    "minimum time between interrupts");
+	node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "ports",
+	    CTLFLAG_RD, NULL, "CPSW Ports Statistics");
+	ports_parent = SYSCTL_CHILDREN(node);
+			continue;
+		port[0] = '0' + i;
+		port[1] = '\0';
+		node = SYSCTL_ADD_NODE(ctx, ports_parent, OID_AUTO,
+		    port, CTLFLAG_RD, NULL, "CPSW Port Statistics");
+		port_parent = SYSCTL_CHILDREN(node);
+		SYSCTL_ADD_PROC(ctx, port_parent, OID_AUTO, "uptime",
+		    CTLTYPE_UINT | CTLFLAG_RD, sc, i,
+		    cpsw_stat_uptime, "IU", "Seconds since driver init");
+	stats_node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "stats",
+				     CTLFLAG_RD, NULL, "CPSW Statistics");
+	stats_parent = SYSCTL_CHILDREN(stats_node);
+		SYSCTL_ADD_PROC(ctx, stats_parent, i,
+				cpsw_stat_sysctls[i].oid,
+				CTLTYPE_U64 | CTLFLAG_RD, sc, 0,
+				cpsw_stats_sysctl, "IU",
+				cpsw_stat_sysctls[i].oid);
+	queue_node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "queue",
+	    CTLFLAG_RD, NULL, "CPSW Queue Statistics");
+	queue_parent = SYSCTL_CHILDREN(queue_node);
+	node = SYSCTL_ADD_NODE(ctx, queue_parent, OID_AUTO, "tx",
+	    CTLFLAG_RD, NULL, "TX Queue Statistics");
+	cpsw_add_queue_sysctls(ctx, node, &sc->tx);
+	node = SYSCTL_ADD_NODE(ctx, queue_parent, OID_AUTO, "rx",
+	    CTLFLAG_RD, NULL, "RX Queue Statistics");
+	cpsw_add_queue_sysctls(ctx, node, &sc->rx);
+	node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "watchdog",
+	    CTLFLAG_RD, NULL, "Watchdog Statistics");
+	cpsw_add_watchdog_sysctls(ctx, node, sc);
+#ifdef CPSW_ETHERSWITCH
+static etherswitch_info_t etherswitch_info = {
+	.es_nports =		CPSW_PORTS + 1,
+	.es_nvlangroups =	CPSW_VLANS,
+	.es_name =		"TI Common Platform Ethernet Switch (CPSW)",
+	.es_vlan_caps =		ETHERSWITCH_VLAN_DOT1Q,
+static etherswitch_info_t *
+cpsw_getinfo(device_t dev)
+	return (&etherswitch_info);
+static int
+cpsw_getport(device_t dev, etherswitch_port_t *p)
+	int err;
+	struct ifmediareq *ifmr;
+	uint32_t reg;
+	if (p->es_port < 0 || p->es_port > CPSW_PORTS)
+		return (ENXIO);
+	err = 0;
+	if (p->es_port == CPSW_CPU_PORT) {
+		p->es_flags |= ETHERSWITCH_PORT_CPU;
+ 		ifmr = &p->es_ifmr;
+		ifmr->ifm_current = ifmr->ifm_active =
+		    IFM_ETHER | IFM_1000_T | IFM_FDX;
+		ifmr->ifm_mask = 0;
+		ifmr->ifm_status = IFM_ACTIVE | IFM_AVALID;
+		ifmr->ifm_count = 0;
+	} else {
+		psc = device_get_softc(sc->port[p->es_port - 1].dev);
+		err = ifmedia_ioctl(psc->ifp, &p->es_ifr,
+		    &psc->mii->mii_media, SIOCGIFMEDIA);
+	reg = cpsw_read_4(sc, CPSW_PORT_P_VLAN(p->es_port));
+	p->es_pvid = reg & ETHERSWITCH_VID_MASK;
+	reg = cpsw_read_4(sc, CPSW_ALE_PORTCTL(p->es_port));
+	if (reg & ALE_PORTCTL_DROP_UNTAGGED)
+		p->es_flags |= ETHERSWITCH_PORT_DROPUNTAGGED;
+	if (reg & ALE_PORTCTL_INGRESS)
+		p->es_flags |= ETHERSWITCH_PORT_INGRESS;
+	return (err);
+static int
+cpsw_setport(device_t dev, etherswitch_port_t *p)
+	struct ifmedia *ifm;
+	uint32_t reg;
+		return (ENXIO);
+	if (p->es_pvid != 0) {
+		cpsw_write_4(sc, CPSW_PORT_P_VLAN(p->es_port),
+		    p->es_pvid & ETHERSWITCH_VID_MASK);
+	if (p->es_flags & ETHERSWITCH_PORT_DROPUNTAGGED)
+		reg |= ALE_PORTCTL_DROP_UNTAGGED;
+	else
+		reg &= ~ALE_PORTCTL_DROP_UNTAGGED;
+	if (p->es_flags & ETHERSWITCH_PORT_INGRESS)
+		reg |= ALE_PORTCTL_INGRESS;
+	else
+		reg &= ~ALE_PORTCTL_INGRESS;
+	cpsw_write_4(sc, CPSW_ALE_PORTCTL(p->es_port), reg);
+	/* CPU port does not allow media settings. */
+		return (0);
+	ifm = &psc->mii->mii_media;
+	return (ifmedia_ioctl(psc->ifp, &p->es_ifr, ifm, SIOCSIFMEDIA));
+static int
+cpsw_getconf(device_t dev, etherswitch_conf_t *conf)
+	/* Return the VLAN mode. */
+	conf->cmd = ETHERSWITCH_CONF_VLAN_MODE;
+	conf->vlan_mode = ETHERSWITCH_VLAN_DOT1Q;
+	return (0);
+static int
+cpsw_getvgroup(device_t dev, etherswitch_vlangroup_t *vg)
+	int i, vid;
+	if (vg->es_vlangroup >= CPSW_VLANS)
+		return (EINVAL);
+	vg->es_vid = 0;
+	vid = cpsw_vgroups[vg->es_vlangroup].vid;
+	if (vid == -1)
+		return (0);
+		if (ALE_TYPE(ale_entry) != ALE_TYPE_VLAN)
+			continue;
+		if (vid != ALE_VLAN(ale_entry))
+			continue;
+		vg->es_fid = 0;
+		vg->es_vid = ALE_VLAN(ale_entry) | ETHERSWITCH_VID_VALID;
+		vg->es_member_ports = ALE_VLAN_MEMBERS(ale_entry);
+		vg->es_untagged_ports = ALE_VLAN_UNTAG(ale_entry);
+	return (0);
+static void
+cpsw_remove_vlan(struct cpsw_softc *sc, int vlan)
+	int i;
+			continue;
+		if (vlan != ALE_VLAN(ale_entry))
+			continue;
+		break;
+static int
+cpsw_setvgroup(device_t dev, etherswitch_vlangroup_t *vg)
+	int i;
+		/* Is this Vlan ID in use by another vlangroup ? */
+		if (vg->es_vlangroup != i && cpsw_vgroups[i].vid == vg->es_vid)
+			return (EINVAL);
+	if (vg->es_vid == 0) {
+		if (cpsw_vgroups[vg->es_vlangroup].vid == -1)
+			return (0);
+		cpsw_remove_vlan(sc, cpsw_vgroups[vg->es_vlangroup].vid);
+		cpsw_vgroups[vg->es_vlangroup].vid = -1;
+		vg->es_untagged_ports = 0;
+		vg->es_member_ports = 0;
+		vg->es_vid = 0;
+		return (0);
+	vg->es_vid &= ETHERSWITCH_VID_MASK;
+	vg->es_member_ports &= CPSW_PORTS_MASK;
+	vg->es_untagged_ports &= CPSW_PORTS_MASK;
+	if (cpsw_vgroups[vg->es_vlangroup].vid != -1 &&
+	    cpsw_vgroups[vg->es_vlangroup].vid != vg->es_vid)
+		return (EINVAL);
+	cpsw_vgroups[vg->es_vlangroup].vid = vg->es_vid;
+	cpsw_ale_update_vlan_table(sc, vg->es_vid, vg->es_member_ports,
+	    vg->es_untagged_ports, vg->es_member_ports, 0);
+	return (0);
+static int
+cpsw_readreg(device_t dev, int addr)
+	/* Not supported. */
+	return (0);
+static int
+cpsw_writereg(device_t dev, int addr, int value)
+	return (0);
+static int
+cpsw_readphy(device_t dev, int phy, int reg)
+	return (0);
+static int
+cpsw_writephy(device_t dev, int phy, int reg, int data)
+	return (0);
+#endif
diff --git a/freebsd/sys/arm/ti/cpsw/if_cpswreg.h b/freebsd/sys/arm/ti/cpsw/if_cpswreg.h
new file mode 100644
index 00000000..9f73df19
--- /dev/null
+++ b/freebsd/sys/arm/ti/cpsw/if_cpswreg.h
@@ -0,0 +1,210 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2012 Damjan Marion <dmarion at Freebsd.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	_IF_CPSWREG_H
+#define	_IF_CPSWREG_H
+#define	CPSW_SS_OFFSET			0x0000
+#define	CPSW_SS_IDVER			(CPSW_SS_OFFSET + 0x00)
+#define	CPSW_SS_SOFT_RESET		(CPSW_SS_OFFSET + 0x08)
+#define	CPSW_SS_STAT_PORT_EN		(CPSW_SS_OFFSET + 0x0C)
+#define	CPSW_SS_PTYPE			(CPSW_SS_OFFSET + 0x10)
+#define	CPSW_SS_FLOW_CONTROL		(CPSW_SS_OFFSET + 0x24)
+#define	CPSW_PORT_OFFSET		0x0100
+#define	CPSW_PORT_P_MAX_BLKS(p)		(CPSW_PORT_OFFSET + 0x08 + ((p) * 0x100))
+#define	CPSW_PORT_P_BLK_CNT(p)		(CPSW_PORT_OFFSET + 0x0C + ((p) * 0x100))
+#define	CPSW_PORT_P_VLAN(p)		(CPSW_PORT_OFFSET + 0x14 + ((p) * 0x100))
+#define	CPSW_PORT_P_TX_PRI_MAP(p)	(CPSW_PORT_OFFSET + 0x118 + ((p-1) * 0x100))
+#define	CPSW_PORT_P0_CPDMA_TX_PRI_MAP	(CPSW_PORT_OFFSET + 0x01C)
+#define	CPSW_PORT_P0_CPDMA_RX_CH_MAP	(CPSW_PORT_OFFSET + 0x020)
+#define	CPSW_PORT_P_SA_LO(p)		(CPSW_PORT_OFFSET + 0x120 + ((p-1) * 0x100))
+#define	CPSW_PORT_P_SA_HI(p)		(CPSW_PORT_OFFSET + 0x124 + ((p-1) * 0x100))
+#define	CPSW_CPDMA_OFFSET		0x0800
+#define	CPSW_CPDMA_TX_CONTROL		(CPSW_CPDMA_OFFSET + 0x04)
+#define	CPSW_CPDMA_TX_TEARDOWN		(CPSW_CPDMA_OFFSET + 0x08)
+#define	CPSW_CPDMA_RX_CONTROL		(CPSW_CPDMA_OFFSET + 0x14)
+#define	CPSW_CPDMA_RX_TEARDOWN		(CPSW_CPDMA_OFFSET + 0x18)
+#define	CPSW_CPDMA_SOFT_RESET		(CPSW_CPDMA_OFFSET + 0x1c)
+#define	CPSW_CPDMA_DMACONTROL		(CPSW_CPDMA_OFFSET + 0x20)
+#define	CPSW_CPDMA_DMASTATUS		(CPSW_CPDMA_OFFSET + 0x24)
+#define	CPSW_CPDMA_RX_BUFFER_OFFSET	(CPSW_CPDMA_OFFSET + 0x28)
+#define	CPSW_CPDMA_TX_INTSTAT_RAW	(CPSW_CPDMA_OFFSET + 0x80)
+#define	CPSW_CPDMA_TX_INTSTAT_MASKED	(CPSW_CPDMA_OFFSET + 0x84)
+#define	CPSW_CPDMA_TX_INTMASK_SET	(CPSW_CPDMA_OFFSET + 0x88)
+#define	CPSW_CPDMA_TX_INTMASK_CLEAR	(CPSW_CPDMA_OFFSET + 0x8C)
+#define	CPSW_CPDMA_CPDMA_EOI_VECTOR	(CPSW_CPDMA_OFFSET + 0x94)
+#define	CPSW_CPDMA_RX_INTSTAT_RAW	(CPSW_CPDMA_OFFSET + 0xA0)
+#define	CPSW_CPDMA_RX_INTSTAT_MASKED	(CPSW_CPDMA_OFFSET + 0xA4)
+#define	CPSW_CPDMA_RX_INTMASK_SET	(CPSW_CPDMA_OFFSET + 0xA8)
+#define	CPSW_CPDMA_RX_INTMASK_CLEAR	(CPSW_CPDMA_OFFSET + 0xAc)
+#define	 CPSW_CPDMA_RX_INT_THRESH(_ch)	(1 << (8 + ((_ch) & 7)))
+#define	 CPSW_CPDMA_RX_INT(_ch)		(1 << (0 + ((_ch) & 7)))
+#define	CPSW_CPDMA_DMA_INTSTAT_RAW	(CPSW_CPDMA_OFFSET + 0xB0)
+#define	CPSW_CPDMA_DMA_INTSTAT_MASKED	(CPSW_CPDMA_OFFSET + 0xB4)
+#define	CPSW_CPDMA_DMA_INTMASK_SET	(CPSW_CPDMA_OFFSET + 0xB8)
+#define	CPSW_CPDMA_DMA_INTMASK_CLEAR	(CPSW_CPDMA_OFFSET + 0xBC)
+#define	CPSW_CPDMA_RX_PENDTHRESH(p)	(CPSW_CPDMA_OFFSET + 0x0c0 + ((p) * 0x04))
+#define	CPSW_CPDMA_RX_FREEBUFFER(p)	(CPSW_CPDMA_OFFSET + 0x0e0 + ((p) * 0x04))
+#define	CPSW_STATS_OFFSET		0x0900
+#define	CPSW_STATERAM_OFFSET		0x0A00
+#define	CPSW_CPDMA_TX_HDP(p)		(CPSW_STATERAM_OFFSET + 0x00 + ((p) * 0x04))
+#define	CPSW_CPDMA_RX_HDP(p)		(CPSW_STATERAM_OFFSET + 0x20 + ((p) * 0x04))
+#define	CPSW_CPDMA_TX_CP(p)		(CPSW_STATERAM_OFFSET + 0x40 + ((p) * 0x04))
+#define	CPSW_CPDMA_RX_CP(p)		(CPSW_STATERAM_OFFSET + 0x60 + ((p) * 0x04))
+#define	CPSW_CPTS_OFFSET		0x0C00
+#define	CPSW_ALE_OFFSET			0x0D00
+#define	CPSW_ALE_CONTROL		(CPSW_ALE_OFFSET + 0x08)
+#define	 CPSW_ALE_CTL_ENABLE		(1U << 31)
+#define	 CPSW_ALE_CTL_CLEAR_TBL		(1 << 30)
+#define	 CPSW_ALE_CTL_BYPASS		(1 << 4)
+#define	 CPSW_ALE_CTL_VLAN_AWARE	(1 << 2)
+#define	CPSW_ALE_TBLCTL			(CPSW_ALE_OFFSET + 0x20)
+#define	CPSW_ALE_TBLW2			(CPSW_ALE_OFFSET + 0x34)
+#define	CPSW_ALE_TBLW1			(CPSW_ALE_OFFSET + 0x38)
+#define	CPSW_ALE_TBLW0			(CPSW_ALE_OFFSET + 0x3C)
+#define	 ALE_MCAST(_a)			((_a[1] >> 8) & 1)
+#define	 ALE_MCAST_FWD			(3 << 30)
+#define	 ALE_PORTS(_a)			((_a[2] >> 2) & 7)
+#define	 ALE_TYPE(_a)			((_a[1] >> 28) & 3)
+#define	 ALE_TYPE_ADDR			1
+#define	 ALE_TYPE_VLAN			2
+#define	 ALE_TYPE_VLAN_ADDR		3
+#define	 ALE_VLAN(_a)			((_a[1] >> 16) & 0xfff)
+#define	 ALE_VLAN_UNREGFLOOD(_a)	((_a[0] >> 8) & 7)
+#define	 ALE_VLAN_REGFLOOD(_a)		((_a[0] >> 16) & 7)
+#define	 ALE_VLAN_UNTAG(_a)		((_a[0] >> 24) & 7)
+#define	 ALE_VLAN_MEMBERS(_a)		(_a[0] & 7)
+#define	CPSW_ALE_PORTCTL(p)		(CPSW_ALE_OFFSET + 0x40 + ((p) * 0x04))
+#define	 ALE_PORTCTL_NO_SA_UPDATE	(1 << 5)
+#define	 ALE_PORTCTL_NO_LEARN		(1 << 4)
+#define	 ALE_PORTCTL_INGRESS		(1 << 3)
+#define	 ALE_PORTCTL_DROP_UNTAGGED	(1 << 2)
+#define	 ALE_PORTCTL_FORWARD		3
+#define	 ALE_PORTCTL_LEARN		2
+#define	 ALE_PORTCTL_BLOCKED		1
+#define	 ALE_PORTCTL_DISABLED		0
+/* SL1 is at 0x0D80, SL2 is at 0x0DC0 */
+#define	CPSW_SL_OFFSET			0x0D80
+#define	CPSW_SL_MACCONTROL(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x04)
+#define	 CPSW_SL_MACTL_IFCTL_B		(1 << 16)
+#define	 CPSW_SL_MACTL_IFCTL_A		(1 << 15)
+#define	 CPSW_SL_MACTL_GIG		(1 << 7)
+#define	 CPSW_SL_MACTL_GMII_ENABLE	(1 << 5)
+#define	 CPSW_SL_MACTL_FULLDUPLEX	(1 << 0)
+#define	CPSW_SL_MACSTATUS(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x08)
+#define	CPSW_SL_SOFT_RESET(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x0C)
+#define	CPSW_SL_RX_MAXLEN(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x10)
+#define	CPSW_SL_RX_PAUSE(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x18)
+#define	CPSW_SL_TX_PAUSE(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x1C)
+#define	CPSW_SL_RX_PRI_MAP(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x24)
+#define	MDIO_OFFSET			0x1000
+#define	MDIOCONTROL			(MDIO_OFFSET + 0x04)
+#define	 MDIOCTL_ENABLE			(1 << 30)
+#define	 MDIOCTL_FAULTENB		(1 << 18)
+#define	MDIOLINKINTRAW			(MDIO_OFFSET + 0x10)
+#define	MDIOLINKINTMASKED		(MDIO_OFFSET + 0x14)
+#define	MDIOUSERACCESS0			(MDIO_OFFSET + 0x80)
+#define	MDIOUSERPHYSEL0			(MDIO_OFFSET + 0x84)
+#define	MDIOUSERACCESS1			(MDIO_OFFSET + 0x88)
+#define	MDIOUSERPHYSEL1			(MDIO_OFFSET + 0x8C)
+#define	 MDIO_PHYSEL_LINKINTENB		(1 << 6)
+#define	 MDIO_PHYACCESS_GO		(1U << 31)
+#define	 MDIO_PHYACCESS_WRITE		(1 << 30)
+#define	 MDIO_PHYACCESS_ACK		(1 << 29)
+#define	CPSW_WR_OFFSET			0x1200
+#define	CPSW_WR_SOFT_RESET		(CPSW_WR_OFFSET + 0x04)
+#define	CPSW_WR_CONTROL			(CPSW_WR_OFFSET + 0x08)
+#define	CPSW_WR_INT_CONTROL		(CPSW_WR_OFFSET + 0x0c)
+#define	 CPSW_WR_INT_C0_RX_PULSE	(1 << 16)
+#define	 CPSW_WR_INT_C0_TX_PULSE	(1 << 17)
+#define	 CPSW_WR_INT_C1_RX_PULSE	(1 << 18)
+#define	 CPSW_WR_INT_C1_TX_PULSE	(1 << 19)
+#define	 CPSW_WR_INT_C2_RX_PULSE	(1 << 20)
+#define	 CPSW_WR_INT_C2_TX_PULSE	(1 << 21)
+#define	 CPSW_WR_INT_PACE_EN						\
+	(CPSW_WR_INT_C0_RX_PULSE | CPSW_WR_INT_C0_TX_PULSE |		\
+	 CPSW_WR_INT_C1_RX_PULSE | CPSW_WR_INT_C1_TX_PULSE |		\
+	 CPSW_WR_INT_C2_RX_PULSE | CPSW_WR_INT_C2_TX_PULSE)
+#define	 CPSW_WR_INT_PRESCALE_MASK	0xfff
+#define	CPSW_WR_C_RX_THRESH_EN(p)	(CPSW_WR_OFFSET + (0x10 * (p)) + 0x10)
+#define	CPSW_WR_C_RX_EN(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x14)
+#define	CPSW_WR_C_TX_EN(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x18)
+#define	CPSW_WR_C_MISC_EN(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x1C)
+#define	CPSW_WR_C_RX_THRESH_STAT(p)	(CPSW_WR_OFFSET + (0x10 * (p)) + 0x40)
+#define	CPSW_WR_C_RX_STAT(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x44)
+#define	CPSW_WR_C_TX_STAT(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x48)
+#define	CPSW_WR_C_MISC_STAT(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x4C)
+#define	 CPSW_WR_C_MISC_EVNT_PEND	(1 << 4)
+#define	 CPSW_WR_C_MISC_STAT_PEND	(1 << 3)
+#define	 CPSW_WR_C_MISC_HOST_PEND	(1 << 2)
+#define	 CPSW_WR_C_MISC_MDIOLINK	(1 << 1)
+#define	 CPSW_WR_C_MISC_MDIOUSER	(1 << 0)
+#define	CPSW_WR_C_RX_IMAX(p)		(CPSW_WR_OFFSET + (0x08 * (p)) + 0x70)
+#define	CPSW_WR_C_TX_IMAX(p)		(CPSW_WR_OFFSET + (0x08 * (p)) + 0x74)
+#define	 CPSW_WR_C_IMAX_MASK		0x3f
+#define	 CPSW_WR_C_IMAX_MAX		63
+#define	 CPSW_WR_C_IMAX_MIN		2
+#define	 CPSW_WR_C_IMAX_US_MAX		500
+#define	 CPSW_WR_C_IMAX_US_MIN		16
+#define	CPSW_CPPI_RAM_OFFSET		0x2000
+#define	CPSW_CPPI_RAM_SIZE		0x2000
+#define	CPSW_MEMWINDOW_SIZE		0x4000
+#define	 CPDMA_BD_SOP			(1 << 15)
+#define	 CPDMA_BD_EOP			(1 << 14)
+#define	 CPDMA_BD_OWNER			(1 << 13)
+#define	 CPDMA_BD_EOQ			(1 << 12)
+#define	 CPDMA_BD_TDOWNCMPLT		(1 << 11)
+#define	 CPDMA_BD_PASS_CRC		(1 << 10)
+#define	 CPDMA_BD_PKT_ERR_MASK		(3 << 4)
+#define	 CPDMA_BD_TO_PORT		(1 << 4)
+#define	 CPDMA_BD_PORT_MASK		3
+struct cpsw_cpdma_bd {
+	volatile uint32_t next;
+	volatile uint32_t bufptr;
+	volatile uint16_t buflen;
+	volatile uint16_t bufoff;
+	volatile uint16_t pktlen;
+	volatile uint16_t flags;
+#endif /*_IF_CPSWREG_H */
diff --git a/freebsd/sys/arm/ti/cpsw/if_cpswvar.h b/freebsd/sys/arm/ti/cpsw/if_cpswvar.h
index 00000000..9c51b76b
--- /dev/null
+++ b/freebsd/sys/arm/ti/cpsw/if_cpswvar.h
@@ -0,0 +1,151 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	_IF_CPSWVAR_H
+#define	_IF_CPSWVAR_H
+#define	CPSW_PORTS		2
+#define	CPSW_INTR_COUNT		4
+/* MII BUS  */
+#define	CPSW_MIIBUS_RETRIES	20
+#define	CPSW_MIIBUS_DELAY	100
+#define	CPSW_MAX_ALE_ENTRIES	1024
+#define	CPSW_SYSCTL_COUNT	34
+#define	CPSW_CPU_PORT		0
+#define	CPSW_PORTS_MASK		0x7
+#define	CPSW_VLANS		128	/* Arbitrary number. */
+struct cpsw_vlangroups {
+	int vid;
+#endif
+struct cpsw_slot {
+	uint32_t bd_offset;  /* Offset of corresponding BD within CPPI RAM. */
+	bus_dmamap_t dmamap;
+	struct mbuf *mbuf;
+	STAILQ_ENTRY(cpsw_slot) next;
+STAILQ_HEAD(cpsw_slots, cpsw_slot);
+struct cpsw_queue {
+	struct mtx	lock;
+	int		running;
+	int		teardown;
+	struct cpsw_slots active;
+	struct cpsw_slots avail;
+	uint32_t	queue_adds; /* total bufs added */
+	uint32_t	queue_removes; /* total bufs removed */
+	uint32_t	queue_removes_at_last_tick; /* Used by watchdog */
+	uint32_t	queue_restart;
+	int		queue_slots;
+	int		active_queue_len;
+	int		max_active_queue_len;
+	int		avail_queue_len;
+	int		max_avail_queue_len;
+	int		longest_chain; /* Largest # segments in a single packet. */
+	int		hdp_offset;
+struct cpsw_port {
+	device_t	dev;
+	int		phy;
+	int		vlan;
+struct cpsw_softc {
+	device_t	dev;
+	int		active_slave;
+	int		debug;
+	int		dualemac;
+	phandle_t	node;
+	struct bintime	attach_uptime; /* system uptime when attach happened. */
+	struct cpsw_port port[2];
+	unsigned	coal_us;
+	/* RX and TX buffer tracking */
+	struct cpsw_queue rx, tx;
+	/* We expect 1 memory resource and 4 interrupts from the device tree. */
+	int		mem_rid;
+	struct resource	*mem_res;
+	struct resource	*irq_res[CPSW_INTR_COUNT];
+	void		*ih_cookie[CPSW_INTR_COUNT];
+	/* A buffer full of nulls for TX padding. */
+	void		*nullpad;
+	bus_dma_tag_t	mbuf_dtag;
+	struct {
+		int resets;
+		int timer;
+		struct callout  callout;
+	} watchdog;
+	/* 64-bit versions of 32-bit hardware statistics counters */
+	uint64_t shadow_stats[CPSW_SYSCTL_COUNT];
+	/* CPPI STATERAM has 512 slots for building TX/RX queues. */
+	/* TODO: Size here supposedly varies with different versions
+	   of the controller.  Check DaVinci specs and find a good
+	   way to adjust this.  One option is to have a separate
+	   Device Tree parameter for number slots; another option
+	   is to calculate it from the memory size in the device tree. */
+	struct cpsw_slot _slots[CPSW_CPPI_RAM_SIZE / sizeof(struct cpsw_cpdma_bd)];
+struct cpswp_softc {
+	device_t	dev;
+	device_t	miibus;
+	device_t	pdev;
+	int		media_status;
+	int		unit;
+	int		vlan;
+	struct bintime	init_uptime; /* system uptime when init happened. */
+	struct callout	mii_callout;
+	struct mtx	lock;
+	uint32_t	if_flags;
+	uint32_t	phy;
+	uint32_t	phyaccess;
+	uint32_t	physel;
+#endif /*_IF_CPSWVAR_H */
2.20.1
