[PATCH] rtems-docs: Eliminate UTF-8 characters, PDF still broken
Thu Dec 20 23:02:33 UTC 2018
On 21/12/2018 09:38, Chris Johns wrote:
> The base need for a release is being able to build on sync.rtems.org as this is
> the place the releases are created. I have a virtualenv environment which has [4]:
I should have checked before posting. The master online docs are being built
again. This now leaves us with the longer term issue of proper unicode support.
