[PATCH] rtems-docs: Eliminate UTF-8 characters, PDF still broken
Joel Sherrill
joel at rtems.org
Thu Dec 20 23:42:06 UTC 2018
On Thu, Dec 20, 2018, 5:02 PM Chris Johns <chrisj at rtems.org wrote:
> On 21/12/2018 09:38, Chris Johns wrote:
> > The base need for a release is being able to build on sync.rtems.org as
> this is
> > the place the releases are created. I have a virtualenv environment
> which has [4]:
> I should have checked before posting. The master online docs are being
> built
> again. This now leaves us with the longer term issue of proper unicode
> support.
I would like us to restrict when we use it. Names are ok. I would prefer we
use Rest markup for sub and super script but I couldn't make that work.
Just make some guidelines. I don't want smart quotes or dashes for sure.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181220/9f71f373/attachment-0001.html>
