rtems-docs build failure
Joel Sherrill
joel at rtems.org
Fri Dec 21 14:52:09 UTC 2018
Hi
Just passing along that it still fails for me: Builds when not doing PDF
[joel at devel rtems-docs]$ ./waf configure --prefix=/tmp/docs --pdf
Setting top to : /home/joel/rtems-work/rtems-docs
Setting out to :
/home/joel/rtems-work/rtems-docs/build
Checking version : 5.0.0 (master)
Checking for program 'sphinx-build' :
/home/joel/.local/bin/sphinx-build
Checking for program 'aspell' : /usr/bin/aspell
Checking if Sphinx is at least 1.3 : yes (1.8)
Checking Sphinx Verbose : quiet
Checking for 'sphinx.ext.autodoc' : found
Checking for 'sphinx.ext.coverage' : found
Checking for 'sphinx.ext.doctest' : found
Checking for 'sphinx.ext.graphviz' : found
Checking for 'sphinx.ext.intersphinx' : found
Checking for 'sphinx.ext.mathjax' : found
Checking for 'sphinxcontrib.bibtex' : found
Checking for program 'tex' :
/usr/local/texlive/2018/bin/x86_64-linux/tex
Checking for program 'latex' :
/usr/local/texlive/2018/bin/x86_64-linux/latex
Checking for program 'pdflatex' :
/usr/local/texlive/2018/bin/x86_64-linux/pdflatex
Checking for program 'xelatex' :
/usr/local/texlive/2018/bin/x86_64-linux/xelatex
Checking for program 'bibtex' :
/usr/local/texlive/2018/bin/x86_64-linux/bibtex
Checking for program 'dvips' :
/usr/local/texlive/2018/bin/x86_64-linux/dvips
Checking for program 'dvipdf' : /usr/bin/dvipdf
Checking for program 'ps2pdf' : /usr/bin/ps2pdf
Checking for program 'makeindex' :
/usr/local/texlive/2018/bin/x86_64-linux/makeindex
Checking for program 'pdf2ps' : /usr/bin/pdf2ps
Checking for program 'makeglossaries' :
/usr/local/texlive/2018/bin/x86_64-linux/makeglossaries
Checking for program 'pygmentize' : /home/joel/.local/bin/pygmentize
Checking for Tex package 'Bjarne' : ok
Checking for Tex package 'alltt' : ok
Checking for Tex package 'amsmath' : ok
Checking for Tex package 'amssymb' : ok
Checking for Tex package 'amstext' : ok
Checking for Tex package 'anyfontsize' : ok
Checking for Tex package 'array' : ok
Checking for Tex package 'atbegshi' : ok
Checking for Tex package 'babel' : ok
Checking for Tex package 'calc' : ok
Checking for Tex package 'charter' : ok
Checking for Tex package 'cmap' : ok
Checking for Tex package 'color' : ok
Checking for Tex package 'enumitem' : ok
Checking for Tex package 'etoolbox' : ok
Checking for Tex package 'fancybox' : ok
Checking for Tex package 'fancyhdr' : ok
Checking for Tex package 'fancyvrb' : ok
Checking for Tex package 'float' : ok
Checking for Tex package 'fncychap' : ok
Checking for Tex package 'fontenc' : ok
Checking for Tex package 'footnote' : ok
Checking for Tex package 'framed' : ok
Checking for Tex package 'graphicx' : ok
Checking for Tex package 'hypcap' : ok
Checking for Tex package 'hyperref' : ok
Checking for Tex package 'ifthen' : ok
Checking for Tex package 'inputenc' : ok
Checking for Tex package 'keyval' : ok
Checking for Tex package 'kvoptions' : ok
Checking for Tex package 'lineno' : ok
Checking for Tex package 'longtable' : ok
Checking for Tex package 'makeidx' : ok
Checking for Tex package 'multirow' : ok
Checking for Tex package 'parskip' : ok
Checking for Tex package 'pdftexcmds' : ok
Checking for Tex package 'textcomp' : ok
Checking for Tex package 'threeparttable' : ok
Checking for Tex package 'times' : ok
Checking for Tex package 'titlesec' : ok
Checking for Tex package 'utf8' : ok
Checking for Tex package 'wrapfig' : ok
Checking for Tex package 'xcolor' : ok
Checking for Tex package 'xstring' : ok
Checking for Tex package 'inconsolata' : ok
Checking for Tex package 'lato' : ok
'configure' finished successfully (17.205s)
[joel at devel rtems-docs]$ ./waf && ./waf install
Waf: Entering directory `/home/joel/rtems-work/rtems-docs/build'
Waf: Leaving directory `/home/joel/rtems-work/rtems-docs/build'
invalid number of source/target for bld(posted=True,
target=[/home/joel/rtems-work/rtems-docs/build/user/latex/capt-of.sty,
/home/joel/rtems-work/rtems-docs/build/user/latex/eqparbox.sty,
/home/joel/rtems-work/rtems-docs/build/user/latex/environ.sty,
/home/joel/rtems-work/rtems-docs/build/user/latex/ifplatform.sty,
/home/joel/rtems-work/rtems-docs/build/user/latex/trimspaces.sty,
/home/joel/rtems-work/rtems-docs/build/user/latex/slantsc.sty,
/home/joel/rtems-work/rtems-docs/build/user/latex/upquote.sty,
/home/joel/rtems-work/rtems-docs/build/user/latex/rtemsextrafonts.sty],
idx=1, meths=['process_subst', 'process_rule', 'process_source'],
source=['../common/latex/capt-of.sty', '../common/latex/eqparbox.sty',
'../common/latex/environ.sty', '../common/latex/ifplatform.sty',
'../common/latex/trimspaces.sty', '../common/latex/slantsc.sty',
'../common/latex/upquote.sty'], path=/home/joel/rtems-work/rtems-docs/user,
is_copy=True, features=['subst']) in /home/joel/rtems-work/rtems-docs/user
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181221/c97277c2/attachment.html>
