rtems-docs build failure
Shashvat Jain
shashvatjain2002 at gmail.com
Sat Dec 22 15:52:45 UTC 2018
Hello Chris
I would like to add my problem here .
I am unable to properly install sphinx.
When I run ./waf Configure , it gives the following error ,
______________________________________
Setting top to : /home/shashvat/rtems-docs
Setting out to : /home/shashvat/rtems-docs/build
Checking version : 5.0.0 (master)
Checking for program 'sphinx-build' : /usr/bin/sphinx-build
Checking for program 'aspell' : /usr/bin/aspell
Checking if Sphinx is at least 1.3 : Traceback (most recent call
last):
File "/home/shashvat/rtems-docs/.waf-1.9.7-d27222240ebc8bcbca7fcd8f4ae914fb/waflib/Scripting.py",
line 120, in waf_entry_point
run_commands()
line 181, in run_commands
ctx=run_command(cmd_name)
line 172, in run_command
ctx.execute()
File "/home/shashvat/rtems-docs/.waf-1.9.7-d27222240ebc8bcbca7fcd8f4ae914fb/waflib/Configure.py",
line 85, in execute
super(ConfigurationContext,self).execute()
File "/home/shashvat/rtems-docs/.waf-1.9.7-d27222240ebc8bcbca7fcd8f4ae914fb/waflib/Context.py",
line 88, in execute
self.recurse([os.path.dirname(g_module.root_path)])
line 129, in recurse
user_function(self)
File "/home/shashvat/rtems-docs/wscript", line 36, in configure
conf.recurse(b)
user_function(self)
File "/home/shashvat/rtems-docs/common/waf.py", line 216, in cmd_configure
ver = check_sphinx_version(ctx, sphinx_min_version)
File "/home/shashvat/rtems-docs/common/waf.py", line 124, in
ctx.fatal("Sphinx version cannot be checked: %s" % version)
UnboundLocalError: local variable 'version' referenced before assignment
Please help
I think Dr. Joel is facing a problem while
Running ./waf Configure with --pdf option
Enable.
Thank you
Regards
Shashvat
On Sat 22 Dec, 2018, 2:31 AM Chris Johns <chrisj at rtems.org wrote:
> On 22/12/18 1:52 am, Joel Sherrill wrote:
> > Just passing along that it still fails for me: Builds when not doing PDF
> What failed?
> > [joel at devel rtems-docs]$ ./waf configure --prefix=/tmp/docs --pdf
> > [joel at devel rtems-docs]$ ./waf && ./waf install
> The build or the install? Please run as separate commands.
> Thanks
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181222/654a7185/attachment.html>
