[PATCH] eng/vc-users: Convert wiki page to Rest
    Joel Sherrill
    joel at rtems.org
    Mon Dec  3 17:35:24 UTC 2018
Pushed! The conversion looks really nice!
Thanks.
--joel
On Mon, Dec 3, 2018 at 11:12 AM Marçal Comajoan Cara <
mcomajoancara at gmail.com> wrote:
> Converted https://devel.rtems.org/wiki/Developer/Git/Users
> to Rest, and TBDs and wiki TODOs into comments. Also changed http
> links to https (the ones that are possible), corrected typos, updated
> learning resources links and added formattings.
> This work was part of GCI 2018.
>  eng/vc-users.rst | 643 ++++++++++++++++++++++++++++++++++++++++++++++-
>  1 file changed, 641 insertions(+), 2 deletions(-)
> diff --git a/eng/vc-users.rst b/eng/vc-users.rst
> index ebd79bb..47864b4 100644
> --- a/eng/vc-users.rst
> +++ b/eng/vc-users.rst
> @@ -7,5 +7,644 @@
>  Software Development (Git Users)
> -TBD - Convert https://devel.rtems.org/wiki/Developer/Git/Users to Rest
> -TBD - and insert here.
> +.. COMMENT: TBD - Convert
> +.. COMMENT: TBD - Rest and insert here.
> +.. COMMENT: TBD - Managing a (private/public) Git mirror, using GitHub,
> +.. COMMENT: TBD - submitting pull requests...
> +Browse the Git Repository Online
> +You can browse all available repositories online by
> +accessing https://git.rtems.org/.
> +Using the Git Repository
> +The following examples demonstrate how to use the RTEMS' Git repos. These
> +examples are provided for the main rtems module, but they are also valid
> +for the other modules.
> +First, we need to obtain our own local copy of the RTEMS Git repository:
> +.. code-block:: shell
> +  git clone git://git.rtems.org/rtems.git rtems
> +This command will create a folder named rtems in the current directory.
> This
> +folder will contain a full-featured RTEMS' Git repository and the current
> HEAD
> +revision checked out. Since all the history is available we can check out
> any
> +release of RTEMS. Major RTEMS releases are available as separate branches
> in
> +the repo.
> +To see all available remote branches issue the following command:
> +  git branch -r
> +We can check out one of those remote branches (e.g. rtems-4.10 branch)
> using
> +the command:
> +  git checkout -b rtems410 origin/4.10
> +This will create a local branch named "rtems410", containing the
> rtems-4.10
> +release, that will track the remote branch "rtems-4-10-branch" in origin
> +(git://git.rtems.org/rtems.git). The ``git branch`` command prints a
> list of
> +the current local branches, indicating the one currently checked out.
> +If you want to switch between local branches:
> +  git checkout <branch-name>
> +With time your local repository will diverge from the main RTEMS
> repository. To
> +keep your local copy up to date you need to issue:
> +  git pull origin
> +This command will update all your local branches with any new code
> revisions
> +available on the central repository.
> +Making Changes
> +Git allows you to make changes in the RTEMS source tree and track those
> changes
> +locally. We recommend you make all your changes in local branches. If you
> are
> +working on a few different changes or a progression of changes it is best
> to
> +use a local branch for each change.
> +A branch for each change lets your repo's master branch track the upstream
> +RTEMS' master branch without interacting with any of the changes you are
> +working on. A completed change is emailed to the developer's list for
> review
> +and this can take time. While this is happening the upstream's master
> branch
> +may be updated and you may need to rebase your work and test again if you
> are
> +required to change or update your patch. A local branch isolates a
> specific
> +change from others and helps you manage the process.
> +First, you need to clone the repository:
> +Or if you already cloned it before, then you might want to update to the
> latest
> +version before making your changes:
> +  cd rtems
> +  git pull
> +Create a local branch to make your changes in, in this example, the
> change is
> +``faster-context-switch``:
> +  git checkout -b faster-context-switch
> +Next, make your changes to files. If you add, delete ormove/rename files
> you
> +need to inform Git
> +  git add /some/new/file
> +  git rm /some/old/file
> +  git mv /some/old/file /some/new/file
> +When you're satisfied with the changes you made, commit them (locally)
> +  git commit -a
> +The ``-a`` flag commits all the changes that were made, but you can also
> +control which changes to commit by individually adding files as you modify
> +them by using. You can also specify other options to commit, such as a
> message
> +with the ``-m`` flag.
> +  git add /some/changed/files
> +  git commit
> +Create a patch from your branch, in this case, we have two commits we
> want to
> +send for review:
> +  git format-patch -2
> + There are new changes pushed to the RTEMS' master branch and our local
> branch
> + needs to be updated:
> +  git checkout master
> +  git pull
> +  git checkout faster-context-switch
> +  git rebase master
> +Working with Branches
> +Branches facilitate trying out new code and creating patches.
> +The previous releases of RTEMS are available through remote branches. To
> check
> +out a remote branch, first query the Git repository for the list of
> branches:
> +  git branch -r
> +Then check out the desired remote branch, for example:
> +Or if you have previously checked out the remote branch then you should
> see it
> +in your local branches:
> +  git branch
> +You can change to an existing local branch easily:
> +  git checkout rtems410
> +You can also create a new branch and switch to it:
> +  git branch temporary
> +  git checkout temporary
> +Or more concisely:
> +  git checkout -b temporary
> +If you forget which branch you are on
> +  git branch
> +shows you by placing a * next to the current one.
> +When a branch is no longer useful you can delete it.
> +  git branch -d temporary
> +If you have unmerged changes in the old branch Git complains and you need
> to
> +use ``-D`` instead of ``-d``.
> +Viewing Changes
> +To view all changes since the last commit:
> +  git diff HEAD
> +To view all changes between the current branch and another branch, say
> master:
> +  git diff master..HEAD
> +To view descriptions of committed changes:
> +  git log
> +Or view the changeset for some file (or directory):
> +  git log /some/file
> +To view the changesets made between two branches:
> +  git log master..HEAD
> +Or for a more brief description use shortlog:
> +  git shortlog master..HEAD
> +Reverting Changes
> +To remove all (uncommitted) changes on a branch
> +  git checkout -f
> +Or to selectively revert (uncommited) files, for example if you
> +accidentally deleted ./some/file
> +  git checkout -- ./some/file
> +or
> +  git checkout HEAD ./some/file
> +To remove commits there are two useful options, reset and revert. ``git
> reset``
> +should only be used on local branches that no one else is accessing
> remotely.
> +``git revert`` is cleaner and is the right way to revert changes that have
> +already been pushed/pulled remotely.
> +git reset
> +``git reset`` is a powerful and tricky command that should only be used on
> +local (un-pushed) branches): A good description of what it enables to do
> can be
> +found here. The following are a few useful examples. Note that adding a ~
> +after HEAD refers to the most recent commit, and you can add a number
> after
> +the ~ to refer to commits even further back; HEAD by itself refers to the
> +current working directory (changes since the last commit).
> +  git reset HEAD~
> +Will undo the last commit and unstage those changes. Your working
> directory
> +will remain the same, therefore a ``git status`` will yield any changes
> you
> +made plus the changes made in your last commit. This can be used to fix
> the
> +last commit. You will need to add the files again.
> +  git reset --soft HEAD~
> +Will just undo the last commit. The changes from the last commit will
> still be
> +staged (just as if you finished git adding them). This can be used to
> amend the
> +last commit (e.g. You forgot to add a file to the last commit).
> +  git reset --hard HEAD~
> +Will revert everything, including the working directory, to the previous
> +commit. This is dangerous and can lead to you losing all your changes; the
> +``--hard`` flag ignores errors.
> +  git reset HEAD
> +Will unstage any change. This is used to revert a wrong ``git add``.
> (e.g. You
> +added a file that shouldn't be there, but you haven't 'committed')
> +Will revert your working directory to a HEAD state. You will lose any
> change
> +you made to files after the last commit. This is used when you just want
> to
> +destroy all changes you made since the last commit.
> +git revert
> +``git revert`` does the same as reset but creates a new commit with the
> +reverted changes instead of modifying the local repository directly.
> +  git revert HEAD
> +This will create a new commit which undoes the change in HEAD. You will be
> +given a chance to edit the commit message for the new commit.
> +Merging Changes
> +Suppose you commit changes in two different branches, branch1 and branch2,
> +and want to create a new branch containing both sets of changes:
> +  git checkout -b merged
> +  git merge branch1
> +  git merge branch2
> +Or you might want to bring the changes in one branch into the other:
> +  git checkout branch1
> +  git merge branch2
> +And now that branch2 is merged you might get rid of it:
> +  git branch -d branch2
> +If you have done work on a branch, say branch1, and have gone out-of-sync
> +with the remote repository, you can pull the changes from the remote repo
> and
> +then merge them into your branch:
> +  git pull
> +  git merge master
> +If all goes well the new commits you pulled into your master branch will
> be
> +merged into your branch1, which will now be up-to-date. However, if
> branch1
> +has not been pushed remotely then rebasing might be a good alternative to
> +merging because the merge generates a commit.
> +Rebasing
> +An alternative to the merge command is rebase, which replays the changes
> +(commits) on one branch onto another. ``git rebase`` finds the common
> ancestor
> +of the two branches, stores each commit of the branch you’re on to
> temporary
> +files and applies each commit in order.
> +For example
> +  git rebase master
> +or more concisely
> +  git rebase master branch1
> +will bring the changes of master into branch1, and then you can
> fast-forward
> +master to include branch1 quite easily
> +  git merge branch1
> +Rebasing makes a cleaner history than merging; the log of a rebased branch
> +looks like a linear history as if the work was done serially rather than
> in
> +parallel. A primary reason to rebase is to ensure commits apply cleanly
> on a
> +remote branch, e.g. when submitting patches to RTEMS that you create by
> working
> +on a branch in a personal repository. Using rebase to merge your work
> with the
> +remote branch eliminates most integration work for the
> committer/maintainer.
> +There is one caveat to using rebase: Do not rebase commits that you have
> pushed
> +to a public repository. Rebase abandons existing commits and creates new
> ones
> +that are similar but different. If you push commits that others pull
> down, and
> +then you rewrite those commits with ``git rebase`` and push them up
> again, the
> +others will have to re-merge their work and trying to integrate their work
> +into yours can become messy.
> +Accessing a developer's repository
> +RTEMS developers with Git commit access have personal repositories
> +on https://git.rtems.org/ that can be cloned to view cutting-edge
> +development work shared there.
> +Creating a Patch
> +Before submitting a patch read about `Contributing
> +<https://devel.rtems.org/wiki/Developer/Contributing>`_ to RTEMS and the
> +`Commit Message <https://devel.rtems.org/wiki/Developer/Git#GitCommits>`_
> +formatting we require.
> +The recommended way to create a patch is to branch the Git repository
> master
> +and use one commit for each logical change. Then you can use
> +``git format-patch`` to turn your commits into patches and easily submit
> them.
> +  git format-patch master
> +Creates a separate patch for each commit that has been made between the
> master
> +branch and the current branch and writes them in the current directory.
> Use the
> +``-o`` flag to redirect the files to a different directory.
> +If you are re-submitting a patch that has previously been reviewed, you
> should
> +specify a version number for your patch, for example, use
> +  git format-patch -v2 ...
> +to indicate the second version of a patch, ``-v3`` for a third, and so
> forth.
> +Patches created using ``git format-patch`` are formatted so they can be
> emailed
> +and rely on having Git configured with your name and email address, for
> example
> +  git config --global user.name "Your Name"
> +  git config --global user.email name at domain.com
> +Please use a real name, we do not allow pseudonyms or anonymous
> contributions.
> +Submitting a Patch
> +Using ``git send-email`` you can easily contribute your patches. You will
> need
> +to install ``git send-email`` first:
> +  sudo yum install git-email
> +or
> +  sudo dnf install git-email
> +or
> +  sudo apt install git-email
> +Then you will need to configure an SMTP server. You could install one on
> your
> +localhost, or you can connect to a mail server such as Gmail.
> +Configuring git send-email to use Gmail
> +Configure Git to use Gmail:
> +  git config --global sendemail.smtpserver smtp.gmail.com
> +  git config --global sendemail.smtpserverport 587
> +  git config --global sendemail.smtpencryption tls
> +  git config --global sendemail.smtpuser your_email at gmail.com
> +It will ask for your password each time you use ``git send-email``.
> Optionally
> +you can also put it in your ``git config``:
> +  git config --global sendemail.smtppass your_password
> +Sending Email
> +To send your patches just
> +  git send-email /path/to/patch --to devel at rtems.org
> +To send multiple related patches (if you have more than one commit in your
> +branch) specify a path to a directory containing all of the patches
> created by
> +``git format-patch``. ``git send-email`` has some useful options such as:
> +* ``--annotate`` to show/edit your patch
> +* ``--cover-letter`` to prepend a summary
> +* ``--cc=<address>`` to cc someone
> +You can configure the to address:
> +  git config --global sendemail.to devel at rtems.org
> +So all you need is:
> +Troubleshooting
> +Some restrictive corporate firewalls block access through the Git protocol
> +(git://). If you are unable to reach the server git://git.rtems.org/
> you can
> +try accessing through http. To clone the rtems repository using the http
> +protocol use the following command:
> +  git clone http://git.rtems.org/rtems/ rtems
> +This access through http is slower (way slower!) than through the git
> protocol,
> +therefore, the Git protocol is preferred.
> +Manage Your Code
> +You may prefer to keep your application and development work in a Git
> +repository for all the good reasons that come with version control.
> +For public repositories, you may like to try `GitHub <https://github.com/
> >`_
> +or `BitBucket <https://bitbucket.org/>`_. RTEMS maintains
> +`mirrors on GitHub <https://github.com/RTEMS>`_ which can make
> synchronizing
> +with upstream changes relatively simple. If you need to keep your work
> private,
> +you can use one of those services with private repositories or manage
> your own
> +server. The details of setting up a server are outside the scope of this
> +document, but if you have a server with SSH access you should be able to
> `find
> +instructions
> +<https://git-scm.com/book/en/v2/Git-on-the-Server-Setting-Up-the-Server>`_
> on
> +how to set up Git access. Once you have git configured on the server,
> adding
> +repositories is a snap.
> +Private Servers
> +In the following, replace @USER@ with your username on your server,
> @REPO@ with
> +the name of your repository, and @SERVER@ with your server's name or
> address.
> +To push a mirror to your private server, first create a bare repository
> on your
> +server.
> +  cd /home/@USER@
> +  mkdir git
> +  mkdir git/@REPO at .git
> +  cd git/@REPO at .git
> +  git --bare init
> +Now from your client machine (e.g. your work laptop/desktop), push a git,
> +perhaps one you cloned from elsewhere, or one that you made locally with
> +``git init``, by adding a remote and pushing:
> +  git remote add @SERVER@ ssh://@SERVER@/home/@USER@/git/@REPO@.git
> +  git push @SERVER@ master
> +You can replace the @SERVER@ with another name for your remote if you
> like.
> +And now you can push other branches that you might have created. Now you
> can
> +push and pull between your client and your server. Use SSH keys to
> authenticate
> +with your server if you want to save on password typing; remember to put a
> +passphrase on your SSH key if there is a risk the private key file might
> get
> +compromised.
> +The following is an example scenario that might be useful for RTEMS users
> that
> +uses a slightly different approach than the one just outlined:
> +  ssh @SERVER@
> +  mkdir git
> +  git clone --mirror git://git.rtems.org/rtems.git
> +  ## Add your ssh key to ~/.ssh/authorized_keys
> +  exit
> +  git clone ssh://@SERVER@/home/@USER@/git/rtems.git
> +  cd rtems
> +  git remote add upstream git://git.rtems.org/rtems.git
> +  git fetch upstream
> +  git pull upstream master
> +  git push
> +  ## If you want to track RTEMS on your personal master branch,
> +  ## you should only push changes to origin/master that you pull
> +  ## from upstream. The basic workflow should look something like:
> +  git push
> +  git checkout -b anewbranch
> +  ## Repeat: do work, git commit -a
> +  git push origin anewbranch
> +  ## delete a remote branch
> +  git push origin :anewbranch
> +  ## delete a local branch
> +  git branch -d anewbranch
> +Learn more about Git
> +Links to the sites with good Git information:
> +* http://gitready.com/ - An excellent resource from beginner to very
> advanced.
> +* http://progit.org/book/ - Covers Git basics and some advanced features.
> +  Includes some useful workflow examples.
> +* https://lab.github.com/ - Learn to use Git and GitHub while doing a
> series of
> +  projects.
> +* https://git-scm.com/docs - The official Git reference.
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181203/b7a4ee42/attachment-0002.html>
