[rtems-test] powerpc/psim: RTEMS_POSIX_API: Passed:567 Failed:5 Timeout:2 Invalid:0 Wrong:0
Joel Sherrill
joel at rtems.org
Tue Dec 4 03:49:00 UTC 2018
On Mon, Dec 3, 2018, 9:34 PM Chris Johns <chrisj at rtems.org wrote:
> On 03/12/2018 17:27, Sebastian Huber wrote:
> > On 03/12/2018 05:53, Joel Sherrill wrote:
> >> Timeouts:
> >> unlimited.exe
> > It is strange that this times out. If I run it by hand, then it runs
> without a
> > failure:
> > time psim -i ./powerpc-rtems5/c/psim/testsuites/samples/unlimited.exe
> > TEST3 : signal task 0a0103e9 to delete, task 999 ending.
> > TEST3 : completed
> > *** END OF TEST UNLIMITED TASK ***
> > *** FATAL ***
> > fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
> > fatal code: 0 (0x00000000)
> > RTEMS version: 5.0.0.dedb34f9ef5527a596046ff9cbf19c8a93dfdaee
> > RTEMS tools: 7.3.0 20180125 (RTEMS 5, RSB
> > 30da0c720b78eba16a3f5272206c07415368617b, Newlib
> > 2ab57ad59bc35dafffa69cd4da5e228971de069f)
> > executing thread ID: 0x08a010001
> > executing thread name: UI1
> > real 0m2.573s
> > user 0m2.055s
> > sys 0m0.294s
> Is your rtems-tools fully updated?
A lot updated when I just pulled. I will leave it building again when I
head to bed.
> Is the host at full load when this test fails?
No. Idle otherwise
> What happens if just the samples directory is run? To do this just provide
> the
> path to the samples directory, rtems-test will find the executables there.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181203/94db72d9/attachment-0002.html>
