POSIX Signature Test for sys/uio.h (GCI2018)
Abhimanyu Raghuvanshi
abhimanyuraghuvanshi29 at gmail.com
Wed Dec 12 17:07:19 UTC 2018
Sure thing.
ABR
On Wed, Dec 12, 2018 at 10:05 PM Shashvat Jain <shashvatjain2002 at gmail.com>
wrote:
> Hey Abhimanyu!!
> please note that all the tests must have the new license BSD-2 .
> It was added recently .
> here is the new license
> https://devel.rtems.org/wiki/GCI/Coding/AddPOSIXMethodSignatureComplianceTests
> if possible ,also submit a patch editing your previous test files with the
> new license .
> Thank you !!
> Regards
> Shashvat
> On Wed, Dec 12, 2018 at 9:33 PM Abhimanyu Raghuvanshi <
> abhimanyuraghuvanshi29 at gmail.com> wrote:
>> Patch attached
>> From 145613daf5bea789337540e488b626077ce03bef Mon Sep 17 00:00:00 2001
>> From: ABR290B <abhimanyuraghuvanshi29 at gmail.com>
>> Date: Wed, 12 Dec 2018 21:31:27 +0530
>> Subject: [PATCH] POSIX Signature Test for sys/uio.h (GCI2018)
>> testsuites/psxtests/Makefile.am | 4 ++-
>> testsuites/psxtests/psxhdrs/sys/uio/readv.c | 38 ++++++++++++++++++++
>> testsuites/psxtests/psxhdrs/sys/uio/writev.c | 38 ++++++++++++++++++++
>> 3 files changed, 79 insertions(+), 1 deletion(-)
>> create mode 100644 testsuites/psxtests/psxhdrs/sys/uio/readv.c
>> create mode 100644 testsuites/psxtests/psxhdrs/sys/uio/writev.c
>> diff --git a/testsuites/psxtests/Makefile.am
>> b/testsuites/psxtests/Makefile.am
>> index 3dd8fe0139..7c7a94f968 100644
>> --- a/testsuites/psxtests/Makefile.am
>> +++ b/testsuites/psxtests/Makefile.am
>> @@ -1815,7 +1815,9 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
>> psxhdrs/setjmp/longjmp.c \
>> psxhdrs/setjmp/setjmp.c \
>> psxhdrs/setjmp/siglongjmp.c \
>> - psxhdrs/setjmp/sigsetjmp.c
>> + psxhdrs/setjmp/sigsetjmp.c \
>> + psxhdrs/sys/uio/readv.c \
>> + psxhdrs/sys/uio/writev.c
>> ## Not supported by RTEMS, but POSIX API Compliance tests exist.
>> ## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
>> diff --git a/testsuites/psxtests/psxhdrs/sys/uio/readv.c
>> b/testsuites/psxtests/psxhdrs/sys/uio/readv.c
>> new file mode 100644
>> index 0000000000..8f6f3aa9f5
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxhdrs/sys/uio/readv.c
>> @@ -0,0 +1,38 @@
>> + * @file
>> + * @brief readv() API Conformance Test
>> + * COPYRIGHT (c) 2018.
>> + * Abhimanyu Raghuvanshi
>> + * Permission to use, copy, modify, and/or distribute this software
>> + * for any purpose with or without fee is hereby granted.
>> + * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
>> + * WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
>> + * WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE
>> AUTHOR
>> + * BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
>> + * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR
>> PROFITS,
>> + * WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
>> ACTION,
>> + * ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
>> SOFTWARE.
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +#include <sys/uio.h>
>> +#include <sys/types.h>
>> +int test(void);
>> +int test(void)
>> + int a = 0;
>> + const struct iovec b = {0,0};
>> + int c = 1;
>> + ssize_t ret = readv(a, &b, c);
>> + return ret!='\0';
>> \ No newline at end of file
>> diff --git a/testsuites/psxtests/psxhdrs/sys/uio/writev.c
>> b/testsuites/psxtests/psxhdrs/sys/uio/writev.c
>> index 0000000000..0e53e21815
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxhdrs/sys/uio/writev.c
>> @@ -0,0 +1,38 @@
>> + * @file
>> + * @brief writev() API Conformance Test
>> AUTHOR
>> PROFITS,
>> ACTION,
>> SOFTWARE.
>> +#endif
>> +int test(void);
>> +int test(void)
>> + int a = 0;
>> + int c = 1;
>> + ssize_t ret = writev(a, &b, c);
>> + return ret!='\0';
>> 2.19.1.windows.1
>> ABR
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181212/2bc79ad0/attachment-0002.html>
