Failures on Master (31 Jan)
Thu Feb 1 18:44:14 UTC 2018
Hi
I did a full sweep with the bsp builder overnight. There appear to be two
classes of failures:
========> (1) Qemuppc BSP Family with --enable-smp
- qemuppc
- qemuprep-altivec
- qemuprep
I don't see others fail in the bsp builder log.
Does this mean that these BSPs need to be added to the
"exclude-smp" list?
========> (2)  Leon3 can't find cache_.h. This appears to be when SMP
enabled.
This looks like a bug introduced by all the file movement recently.
14 smp-debug sparc/leon3 build:
      configure: /home/joel/rtems-work/rtems/configure --target=sparc-\
      rtems5 --enable-rtemsbsp=leon3 --prefix=/home/joel/rtems-work/bsps\
      --enable-debug --enable-smp
     error: c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c:19:10: fatal
            error: cache_.h: No such file or directory
  15 smp-network sparc/leon3 build:
      --enable-networking --enable-smp
  16 smp-network-debug sparc/leon3 build:
      --enable-debug --enable-networking --enable-smp
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180201/0d9e2695/attachment.html>
