Failures on Master (31 Jan)
Fri Feb 2 06:09:33 UTC 2018
On 01/02/18 19:44, Joel Sherrill wrote:
> ========> (2)  Leon3 can't find cache_.h. This appears to be when SMP
> enabled.
> This looks like a bug introduced by all the file movement recently.
> 14 smp-debug sparc/leon3 build:
>       configure: /home/joel/rtems-work/rtems/configure --target=sparc-\
>       rtems5 --enable-rtemsbsp=leon3 --prefix=/home/joel/rtems-work/bsps\
>       --enable-debug --enable-smp
>      error: c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c:19:10: fatal
>             error: cache_.h: No such file or directory
Sorry, I forgot to push the fix. It should work now.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
