[PATCH] sb: Fix path.py
Stephan Gambke s7eph4n at protonmail.com
Sat Feb 3 15:02:45 UTC 2018
is_abspath() now considers zero-length strings
Also: Remove not needed line in expand()
 source-builder/sb/path.py | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/source-builder/sb/path.py b/source-builder/sb/path.py
index 679436c..f851139 100644
--- a/source-builder/sb/path.py
+++ b/source-builder/sb/path.py
@@ -54,7 +54,7 @@ def host(path):
     return path
 def is_abspath(path):
-    if path is not None:
+    if path is not None and len(path) > 0:
         return '/' == path[0]
     return False
@@ -218,7 +218,6 @@ def removeall(path):
         _remove_node(path)
 def expand(name, paths):
-    path = shell(path)
     l = []
     for p in paths:
         l += [join(shell(p), name)]
2.7.4
