[PATCH] rsb: Minor fixes.
Chris Johns
chrisj at rtems.org
Mon Feb 5 04:54:29 UTC 2018
Close #2910
rsb/hosts.rst | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/rsb/hosts.rst b/rsb/hosts.rst
index ba565d5..a4226f3 100644
--- a/rsb/hosts.rst
+++ b/rsb/hosts.rst
@@ -156,7 +156,7 @@ Mavericks
The RSB works on Mavericks and the GNU tools can be built for RTEMS using the
Mavericks clang LLVM tool chain. You will need to build and install a couple of
-packages to make the RSB pass the +sb-check+. These are CVS and XZ. You can get
+packages to make the RSB pass the ``sb-check``. These are CVS and XZ. You can get
these tools from a packaging tool for MacOS such as *MacPorts* or *HomeBrew*.
I do not use 3rd party packaging on MacOS and prefer to build the packages from
@@ -165,8 +165,8 @@ however they sometimes bring in extra dependence and that complicates my build
environment and I want to know the minimal requirements when building
tools. The following are required:
-. The XZ package's home page is http://tukaani.org/xz/ and I use version
- 5.0.5. XZ builds and installs cleanly.
+#. The XZ package's home page is http://tukaani.org/xz/ and I use version
+ 5.0.5. XZ builds and installs cleanly.
Serria
2.14.1
