[PATCH 01/11] libblock: Use self-contained mutex for nvdisk
    Sebastian Huber
    Tue Feb  6 15:51:19 UTC 2018
Update #2843.
 cpukit/libblock/src/nvdisk.c | 92 +++++++++++++++++++-------------------------
 1 file changed, 39 insertions(+), 53 deletions(-)
diff --git a/cpukit/libblock/src/nvdisk.c b/cpukit/libblock/src/nvdisk.c
index 1df0ca2ae4..bb1fc5dbe9 100644
--- a/cpukit/libblock/src/nvdisk.c
+++ b/cpukit/libblock/src/nvdisk.c
@@ -25,9 +25,10 @@
 #include <inttypes.h>
-#include "rtems/blkdev.h"
-#include "rtems/diskdevs.h"
-#include "rtems/nvdisk.h"
+#include <rtems/blkdev.h>
+#include <rtems/diskdevs.h>
+#include <rtems/nvdisk.h>
+#include <rtems/thread.h>
  * @note
@@ -102,7 +103,7 @@ typedef struct rtems_mvdisk
   rtems_nvdisk_device_ctl*  devices;      /**< The NV devices for this disk. */
   uint32_t                  device_count; /**< The number of NV devices. */
   uint32_t                  cs_pages;     /**< The num of pages of checksums. */
-  rtems_id                  lock;         /**< Mutex for threading protection.*/
+  rtems_mutex               lock;         /**< Mutex for threading protection.*/
   uint32_t info_level;                    /**< The info trace level. */
 } rtems_nvdisk;
@@ -690,7 +691,6 @@ rtems_nvdisk_ioctl (rtems_disk_device *dd, uint32_t req, void* argp)
   dev_t                     dev = rtems_disk_get_device_identifier (dd);
   rtems_device_minor_number minor = rtems_filesystem_dev_minor_t (dev);
   rtems_blkdev_request*     r = argp;
-  rtems_status_code         sc;
   if (minor >= rtems_nvdisk_count)
@@ -706,49 +706,42 @@ rtems_nvdisk_ioctl (rtems_disk_device *dd, uint32_t req, void* argp)
   errno = 0;
-  sc = rtems_semaphore_obtain (rtems_nvdisks[minor].lock, RTEMS_WAIT, 0);
-  if (sc != RTEMS_SUCCESSFUL)
-    errno = EIO;
-  else
-    errno = 0;
-    switch (req)
-      case RTEMS_BLKIO_REQUEST:
-        switch (r->req)
-          case RTEMS_BLKDEV_REQ_READ:
-            errno = rtems_nvdisk_read (&rtems_nvdisks[minor], r);
-            break;
-          case RTEMS_BLKDEV_REQ_WRITE:
-            errno = rtems_nvdisk_write (&rtems_nvdisks[minor], r);
-            break;
-          default:
-            errno = EINVAL;
-            break;
-        break;
-      case RTEMS_NVDISK_IOCTL_ERASE_DISK:
-        errno = rtems_nvdisk_erase_disk (&rtems_nvdisks[minor]);
-        break;
-      case RTEMS_NVDISK_IOCTL_INFO_LEVEL:
-        rtems_nvdisks[minor].info_level = (uintptr_t) argp;
-        break;
-      default:
-        rtems_blkdev_ioctl (dd, req, argp);
-        break;
+  rtems_mutex_lock (&rtems_nvdisks[minor].lock);
-    sc = rtems_semaphore_release (rtems_nvdisks[minor].lock);
-      errno = EIO;
+  switch (req)
+    case RTEMS_BLKIO_REQUEST:
+      switch (r->req)
+        case RTEMS_BLKDEV_REQ_READ:
+          errno = rtems_nvdisk_read (&rtems_nvdisks[minor], r);
+          break;
+        case RTEMS_BLKDEV_REQ_WRITE:
+          errno = rtems_nvdisk_write (&rtems_nvdisks[minor], r);
+          break;
+        default:
+          errno = EINVAL;
+          break;
+      break;
+    case RTEMS_NVDISK_IOCTL_ERASE_DISK:
+      errno = rtems_nvdisk_erase_disk (&rtems_nvdisks[minor]);
+      break;
+    case RTEMS_NVDISK_IOCTL_INFO_LEVEL:
+      rtems_nvdisks[minor].info_level = (uintptr_t) argp;
+      break;
+    default:
+      rtems_blkdev_ioctl (dd, req, argp);
+      break;
+  rtems_mutex_unlock (&rtems_nvdisks[minor].lock);
   return errno == 0 ? 0 : -1;
@@ -830,14 +823,7 @@ rtems_nvdisk_initialize (rtems_device_major_number major,
       return sc;
-    sc = rtems_semaphore_create (rtems_build_name ('N', 'V', 'D', 'K'), 1,
-                                 RTEMS_PRIORITY | RTEMS_BINARY_SEMAPHORE |
-                                 RTEMS_INHERIT_PRIORITY, 0, &nvd->lock);
-      rtems_nvdisk_error ("disk lock create failed");
-      return sc;
+    rtems_mutex_init (&nvd->lock, "NV Disk");
   rtems_nvdisk_count = rtems_nvdisk_configuration_size;
2.12.3
