Contribute to project
Tue Feb 6 17:25:05 UTC 2018
Hello Abhinav Jain,
It is good that you are studying. Now, you should pursue two paths:
1. Produce some code for RTEMS, perhaps by fixing a bug. A good place
to start is the tickets on the open releases:
https://devel.rtems.org/query?status=assigned&status=accepted&status=reopened&group=status&milestone=4.11.3
https://devel.rtems.org/query?status=accepted&status=assigned&status=new&status=reopened&milestone=4.10.3&group=status&order=priority
2. Prepare your project idea. You will want to convert your learning
into a concrete, achievable plan for code that can be implemented in
RTEMS and will be beneficial to someone.
Gedare
On Tue, Feb 6, 2018 at 10:23 AM, Abhinav Jain <jainab.2009 at gmail.com> wrote:
> Sir,
> I have studied about SASOS. It's really a great approach to make the process
> faster by avoiding multiple copies of the data. I read about two SASOS
> namely Angel system(developed at City University, London) and Mungi
> system(developed by University of New South Wales, Australia). I also
> studied about Memory Protection in SASOS, where the concept of address
> protection is replaced by protection domain. I studied about Multithreading,
> POSIX, Race condition and Synchronization to avoid the Race condition.
> Please guide me, am I  on the right path and what all do I need to learn
> further?
> Thanks and Regards
> Abhinav Jain
> On Wed, Jan 31, 2018 at 11:17 PM, Abhinav Jain <jainab.2009 at gmail.com>
> wrote:
>> Sir,
>> Thanks for the guidance. The mail is very informative and I will follow
>> the way suggested by you.
>> Thanks and regards
>> Abhinav Jain
>> On Jan 31, 2018 5:41 PM, "Sebastian Huber"
>> <sebastian.huber at embedded-brains.de> wrote:
>>> The MMU support is a very challenging project. The scope of the project
>>> and potential use cases must be determined. You need a lot of experience to
>>> design good APIs and it helps if you know the APIs for this kind of stuff on
>>> other systems like QNX, Linux, FreeBSD, etc. For the architecture support a
>>> lot of background knowledge is required at least on PowerPC, ARMv5..8,
>>> SPARC, Nios2, MIPS, etc. For example, changing the TLB1 based MMU during
>>> application run-time on PowerPC (including SMP support, cache consistency)
>>> is not easy. There are some optimization problems involved if you want to
>>> determine a good cover with memory areas (alignment restrictions, limited
>>> number of areas in the MMU/MPU if not page based, e.g. 16).
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone   : +49 89 189 47 41-16
>>> Fax     : +49 89 189 47 41-09
>>> E-Mail  : sebastian.huber at embedded-brains.de
>>> PGP     : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
