[PATCH] 4.10: Disable building the simulator in GDB for SPARC and LM32.
Chris Johns
chrisj at rtems.org
Wed Feb 7 03:07:10 UTC 2018
There is POSIX code that does not build on Windows.
Close #3291
rtems/config/4.10/rtems-lm32.bset | 3 +++
rtems/config/4.10/rtems-sparc.bset | 3 +++
2 files changed, 6 insertions(+)
diff --git a/rtems/config/4.10/rtems-lm32.bset b/rtems/config/4.10/rtems-lm32.bset
index c227def..64906ed 100644
--- a/rtems/config/4.10/rtems-lm32.bset
+++ b/rtems/config/4.10/rtems-lm32.bset
@@ -4,4 +4,7 @@
%define release 1
%define rtems_arch lm32
+%define win32-gdb-disable-sim 1
%include 4.10/rtems-defaults.bset
diff --git a/rtems/config/4.10/rtems-sparc.bset b/rtems/config/4.10/rtems-sparc.bset
index 4917c4d..2204299 100644
--- a/rtems/config/4.10/rtems-sparc.bset
+++ b/rtems/config/4.10/rtems-sparc.bset
@@ -4,4 +4,7 @@
%define release 1
%define rtems_arch sparc
2.14.2
