[PATCH] gcc: Use the RSB release for released tools.
Wed Feb 7 04:23:40 UTC 2018
Using the RSB release version for the gcc version string means the
tools have a version string that matches the release.
Close #3293
 rtems/config/rtems-base.bset           | 3 ++-
 source-builder/config/gcc-common-1.cfg | 9 +++++++++
 2 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/rtems/config/rtems-base.bset b/rtems/config/rtems-base.bset
index 04c9679..5a7cc98 100644
--- a/rtems/config/rtems-base.bset
+++ b/rtems/config/rtems-base.bset
@@ -20,7 +20,8 @@ package: rtems-%{rtems_version}-%{_target}-%{_host}-%{release}
 # Project custom message
-%define gcc_version_message RTEMS %{rtems_version}, RSB %{_sbgit_id}, Newlib %{newlib_version}
+%define rtems_gcc_version %{rtems_version}
+%define gcc_version_message RTEMS %{rtems_gcc_version}, RSB %{_sbgit_id}, Newlib %{newlib_version}
 # Pick up the RTEMS URLs.
diff --git a/source-builder/config/gcc-common-1.cfg b/source-builder/config/gcc-common-1.cfg
index 0bf59b6..eafd958 100644
--- a/source-builder/config/gcc-common-1.cfg
+++ b/source-builder/config/gcc-common-1.cfg
@@ -41,6 +41,15 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
 %define disable_MAKEINFO 1
+# The GCC version depends on the type of build we are doing.
+%if %{rsb_released}
+ %define rtems_gcc_version %{rsb_version}
+%else
+ %define rtems_gcc_version %{rtems_version}
+%endif
 # Prepare the source code.
2.14.1
