[PATCH] testsuites/libtest: The configure order effects how it works.
Chris Johns
chrisj at rtems.org
Thu Feb 8 03:04:45 UTC 2018
Close #3297
testsuites/libtests/configure.ac | 5 ++---
1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index d41d135b64..f740183206 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -12,15 +12,12 @@ AM_INIT_AUTOMAKE([no-define foreign 1.12.2])
AM_MAINTAINER_MODE
RTEMS_ENABLE_CXX
-AC_PROG_CXX
RTEMS_ENV_RTEMSBSP
RTEMS_CHECK_RTEMS_TEST_NO_PAUSE
RTEMS_PROJECT_ROOT
RTEMS_PROG_CC_FOR_TARGET
RTEMS_PROG_CXX_FOR_TARGET
RTEMS_CANONICALIZE_TOOLS
@@ -30,6 +27,8 @@ RTEMS_CHECK_CXX(RTEMS_BSP)
RTEMS_CHECK_CPUOPTS([RTEMS_NETWORKING])
RTEMS_CHECK_CPUOPTS([RTEMS_POSIX_API])
+AC_PROG_CXX
AC_PROG_LN_S
AC_PATH_PROG([PAX],[pax],no)
2.14.1
