[PATCH 1/5] libdl: Clear error between dlerror invocations
Thu Feb 8 03:25:07 UTC 2018
Updates #2747
 cpukit/libdl/dlfcn.c     |  2 ++
 cpukit/libdl/rtl-error.c | 12 ++++++++++++
 cpukit/libdl/rtl-error.h |  5 +++++
 3 files changed, 19 insertions(+)
diff --git a/cpukit/libdl/dlfcn.c b/cpukit/libdl/dlfcn.c
index 3b31bb2e8e..4277caf757 100644
--- a/cpukit/libdl/dlfcn.c
+++ b/cpukit/libdl/dlfcn.c
@@ -18,6 +18,7 @@
 #include <stdint.h>
 #include <dlfcn.h>
 #include <rtems/rtl/rtl.h>
+#include "rtl-error.h"
 static rtems_rtl_obj_t*
 dl_get_obj_from_handle (void* handle)
@@ -130,6 +131,7 @@ dlerror (void)
   static char msg[64];
   rtems_rtl_get_error (msg, sizeof (msg));
+  rtems_rtl_clear_error ();
   return msg;
diff --git a/cpukit/libdl/rtl-error.c b/cpukit/libdl/rtl-error.c
index 5ec4b26ef7..a60074fcd0 100644
--- a/cpukit/libdl/rtl-error.c
+++ b/cpukit/libdl/rtl-error.c
@@ -52,3 +52,15 @@ rtems_rtl_get_error (char* message, size_t max_message)
   return EIO;
+void
+rtems_rtl_clear_error (void)
+  rtems_rtl_data_t* rtl = rtems_rtl_lock ();
+  if (rtl != NULL)
+    rtl->last_errno = 0;
+    rtl->last_error[0] = '\0';
+    rtems_rtl_unlock ();
diff --git a/cpukit/libdl/rtl-error.h b/cpukit/libdl/rtl-error.h
index 0badf51e21..f1cf4ea72c 100644
--- a/cpukit/libdl/rtl-error.h
+++ b/cpukit/libdl/rtl-error.h
@@ -37,6 +37,11 @@ extern "C" {
 void rtems_rtl_set_error (int error, const char* format, ...) RTEMS_RTL_PRINTF_ATTR;
+ * Clears the error.
+void rtems_rtl_clear_error (void);
 #ifdef __cplusplus
 #endif /* __cplusplus */
2.14.1
