Compressed patch to move make/custom/* to make/*
Joel Sherrill
joel at rtems.org
Thu Feb 8 15:08:09 UTC 2018
On Thu, Feb 8, 2018 at 3:05 AM, Sebastian Huber <
> On 08/02/18 09:11, Sebastian Huber wrote:
>> On 08/02/18 01:00, Joel Sherrill wrote:
>>> Hi
>>> The patch was quite large and rightly blocked from being sent to
>>> everyone (~900k). Compressed, it is only 63K
>>> This eliminates the custom directory and moves everything up
>>> one level. No failures in the build as shown here.
>>> https://lists.rtems.org/pipermail/build/2018-February/000398.html
>> If we move this stuff, then why not to
>> bsps/@RTEMS_CPU/@RTEMS_BSP_FAMILY@/make
OK. I can pick at that but what does from testsuites this change to?
include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
Will RTEMS_ROOT need to change to something like $(top_srcdir)/...?
Is there a Makefile.am variable that really points to the top of the source
tree?
The other common pattern is
include $(RTEMS_ROOT)/make/custom/default.cfg
in all the BSP .cfg files? What will that need to be to work before and
after install?
RTEMS_ROOT is the build tree and later the install point. I don't
know how to make that one work.
Any thoughts?
> The corresponding ticket is:
> https://devel.rtems.org/ticket/3285
I thought I put that in the commit message
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180208/b2fdecd0/attachment.html>
