tests using FP specifiers in prints
Joel Sherrill
joel at rtems.org
Thu Feb 8 15:45:55 UTC 2018
On Thu, Feb 8, 2018 at 9:13 AM, Sebastian Huber <
> On 08/02/18 16:02, Joel Sherrill wrote:
>> Hi
>> Jennifer noticed that sp19 prints %g instead of numbers now that
>> we switched to printk for the tests. I did a quick grep and found these:
>> testsuites$ grep -rl "%g" .
>> ./samples/fileio/init.c
>> ./samples/paranoia/paranoia.c
>> ./sptests/sp19/first.c
>> ./sptests/sp19/fptask.c
>> ./sptests/sp19/fptest.h
>> ./tmtests/tm26/fptest.h
>> Are fileio and paranoia using printf()?
> They use:
> testsuites/samples/pppd/init.c: rtems_print_printer_fprintf_pu
> tc(&rtems_test_printer);
> testsuites/samples/loopback/init.c: rtems_print_printer_fprintf_pu
> testsuites/samples/paranoia/init.c: rtems_print_printer_fprintf_pu
> testsuites/samples/hello/init.c: rtems_print_printer_fprintf_pu
> testsuites/samples/capture/init.c: rtems_print_printer_fprintf_pu
> testsuites/benchmarks/linpack/init.c: rtems_print_printer_fprintf_pu
> testsuites/benchmarks/whetstone/init.c: rtems_print_printer_fprintf_pu
> testsuites/benchmarks/dhrystone/init.c: rtems_print_printer_fprintf_pu
> testsuites/libtests/mathl/init.c: rtems_print_printer_fprintf_pu
> testsuites/libtests/mathf/init.c: rtems_print_printer_fprintf_pu
> testsuites/libtests/complex/init.c: rtems_print_printer_fprintf_pu
> testsuites/libtests/capture01/init.c: rtems_print_printer_fprintf_pu
> testsuites/libtests/math/init.c: rtems_print_printer_fprintf_pu
> testsuites/smptests/smpmigration01/init.c: rtems_print_printer_fprintf_pu
> testsuites/smptests/smpopenmp01/init.c: rtems_print_printer_fprintf_pu
> testsuites/sptests/spconsole01/init.c: rtems_print_printer_fprintf_pu
sp19 and tm26 are not in that list. What about them?
>> Do we need to eliminate these uses of %g in sptests and tmtests?
>> --joel
>> devel mailing list
>> devel at rtems.org
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180208/32c862bf/attachment.html>
