tests using FP specifiers in prints
Fri Feb 9 12:21:38 UTC 2018
On 09/02/18 08:58, Sebastian Huber wrote:
> On 08/02/18 16:45, Joel Sherrill wrote:
>> sp19 and tm26 are not in that list. What about them?
> They should be fixed now.
The sp19 fails now on SPARC:
*** BEGIN OF TEST SP 19 ***
*** TEST VERSION: 5.0.0.dc8fd0152928649ac83632a712d96c0dbeca05ae
*** TEST STATE: EXPECTED-PASS
*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
*** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB
703532cb04c6990fb21e97cb7347a16e9df11108, Newlib 3.0.0)
FP1  - integer base = (0x6000)
FP1  - float base = (NA)
TA1  - integer base = (0x1000)
TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
   CPU 0:  breakpoint 1 hit
           0x4000bc98: 94102000  mov  0, %o2  <_Terminate+4>
   CPU 1:  Power down mode
   CPU 2:  Power down mode
   CPU 3:  Power down mode
grmon2> bt
        %pc          %sp
   #0   0x4000bc98   0x40025b68   <_Terminate+0x4>
   #1   0x4000bce8   0x40025bd0   <_Internal_error+0x8>
   #2   0x40005cf8   0x40025c30   <bsp_spurious_handler+0x24>
   #3   0x4001f848   0x40025c98
   #4   0x400172d8   0x40031ba0   <_vfprintf_r+0x2e8>
   #5   0x400198d8   0x40031e28   <__sbprintf+0x70>
   #6   0x40017280   0x40032308   <_vfprintf_r+0x290>
   #7   0x40014880   0x400324e0   <rtems_vprintf+0x28>
   #8   0x40013e44   0x40032540   <rtems_test_printf+0x2c>
   #9   0x40004688   0x400325a8   <Task_1+0x1ec>
   #10  0x4000f7a0   0x400326b8 <_Thread_Entry_adaptor_numeric+0x8>
   #11  0x4000f870   0x40032718   <_Thread_Handler+0x60>
   #12  0x4000f810   0x40032778   <_Thread_Handler+0>
I don't know how to fix this. The Task_1 is created with/without
RTEMS_FLOATING_POINT. Changing everything to RTEMS_FLOATING_POINT may
change the test objectives.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
