[PATCH 3/5] bsp/atsam: Fix cache / DMA handling in SPI.
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Feb 12 13:39:38 UTC 2018
This patch fixes the cache handling for the atsam SPI driver. Note that
this solution might doesn't have the best performance for small packets.
 bsps/arm/atsam/headers.am                          |   1 +
 bsps/arm/atsam/include/bsp/iocopy.h                |  37 ++++
 c/src/lib/libbsp/arm/atsam/Makefile.am             |   3 +
 .../arm/atsam/libraries/libchip/source/qspi.c      |  36 +---
 c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c     | 205 +++++++++++++++++++--
 c/src/lib/libbsp/arm/atsam/utils/iocopy.c          |  49 +++++
 6 files changed, 287 insertions(+), 44 deletions(-)
 create mode 100644 bsps/arm/atsam/include/bsp/iocopy.h
 create mode 100644 c/src/lib/libbsp/arm/atsam/utils/iocopy.c
diff --git a/bsps/arm/atsam/headers.am b/bsps/arm/atsam/headers.am
index 1ec34a2e69..70473c7ea1 100644
--- a/bsps/arm/atsam/headers.am
+++ b/bsps/arm/atsam/headers.am
@@ -11,6 +11,7 @@ include_bsp_HEADERS += ../../../../../../bsps/arm/atsam/include/bsp/atsam-clock-
 include_bsp_HEADERS += ../../../../../../bsps/arm/atsam/include/bsp/atsam-i2c.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/atsam/include/bsp/atsam-spi.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/atsam/include/bsp/i2c.h
+include_bsp_HEADERS += ../../../../../../bsps/arm/atsam/include/bsp/iocopy.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/atsam/include/bsp/irq.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/atsam/include/bsp/pin-config.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/atsam/include/bsp/power.h
diff --git a/bsps/arm/atsam/include/bsp/iocopy.h b/bsps/arm/atsam/include/bsp/iocopy.h
new file mode 100644
index 0000000000..27e374747e
--- /dev/null
+++ b/bsps/arm/atsam/include/bsp/iocopy.h
@@ -0,0 +1,37 @@
+ * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef ATSAM_IOCOPY_H
+#define ATSAM_IOCOPY_H
+#include <rtems.h>
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * Note: This functions are for copying from or to memory that is marked as
+ * Peripheral memory. In this regions a misaligned access is not allowed.
+ * Therefore memcopy would not work in all cases.
+void atsam_copy_to_io(void *dst, const void *src, size_t n);
+void atsam_copy_from_io(void *dst, const void *src, size_t n);
+#ifdef __cplusplus
+#endif /* ATSAM_IOCOPY_H */
diff --git a/c/src/lib/libbsp/arm/atsam/Makefile.am b/c/src/lib/libbsp/arm/atsam/Makefile.am
index 10f34dab55..aa97025568 100644
--- a/c/src/lib/libbsp/arm/atsam/Makefile.am
+++ b/c/src/lib/libbsp/arm/atsam/Makefile.am
@@ -156,6 +156,9 @@ libbsp_a_SOURCES += spi/sc16is752.c
 libbsp_a_SOURCES += ../../shared/tod.c
 libbsp_a_SOURCES += rtc/rtc-config.c
+# Helper functions
+libbsp_a_SOURCES += utils/iocopy.c
 # Includes
 libbsp_a_CPPFLAGS += -I$(srcdir)/../shared/CMSIS/Include
 libbsp_a_CPPFLAGS += -I$(srcdir)/libraries/libboard
diff --git a/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/qspi.c b/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/qspi.c
index c80d0dd53a..314cfdf16c 100644
--- a/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/qspi.c
+++ b/c/src/lib/libbsp/arm/atsam/libraries/libchip/source/qspi.c
@@ -75,6 +75,7 @@
 #include "string.h"
 #include <stdint.h>
+#include <bsp/iocopy.h>
 #define SCRAMBLE_KEY    0x0BADDEAD
@@ -211,35 +212,6 @@ __STATIC_INLINE void QSPI_ScrambleData(Qspi *pQspi, uint32_t wKey,
 	pQspi->QSPI_SMR = (EnableFlag | (Random << 1));
-static void do_copy(uint8_t *dst, const uint8_t *src, size_t n, bool aligned)
-	if (aligned) {
-		while (n > 3) {
-			*(uint32_t *)dst = *(uint32_t *)src;
-			dst += 4;
-			src += 4;
-			n -= 4;
-	while (n > 0) {
-		*dst = *src;
-		++dst;
-		++src;
-		--n;
-static void copy_to_io(void *dst, const void *src, size_t n)
-	do_copy(dst, src, n, ((uintptr_t)dst) % 4 == 0);
-static void copy_from_io(void *dst, const void *src, size_t n)
-	do_copy(dst, src, n, ((uintptr_t)src) % 4 == 0);
  *        Exported functions
@@ -766,9 +738,11 @@ QspidStatus_t QSPI_ReadWriteMem(Qspid_t *pQspid, Access_t const ReadWrite)
 			  && (ReadWrite <= WriteAccess)) ? true : false);
 	if (ReadWrite == WriteAccess) {
-		copy_to_io(pQspiMem, pBuffer.pDataTx , pBuffer.TxDataSize);
+		atsam_copy_to_io(pQspiMem, pBuffer.pDataTx ,
+		    pBuffer.TxDataSize);
 	} else {
-		copy_from_io(pBuffer.pDataRx, pQspiMem, pBuffer.RxDataSize);
+		atsam_copy_from_io(pBuffer.pDataRx, pQspiMem,
+		    pBuffer.RxDataSize);
 	memory_sync();
 	QSPI_EndTransfer(pQspid->pQspiHw);
diff --git a/c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c b/c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c
index 24850c8327..35f44f525d 100644
--- a/c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c
+++ b/c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c
@@ -30,6 +30,7 @@
 #include <bsp/atsam-clock-config.h>
 #include <bsp/atsam-spi.h>
 #include <dev/spi/spi.h>
@@ -37,16 +38,33 @@
 #define MAX_SPI_FREQUENCY 50000000
+#define DMA_NR_DESC_PER_DIR 3
+#define DMA_DESC_ALLIGNMENT 4
+#define DMA_BUF_RX 0
+#define DMA_BUF_TX 1
+#define DMA_BUF_DIRS 2
+struct atsam_spi_xdma_buf {
+  LinkedListDescriporView0 desc[DMA_NR_DESC_PER_DIR];
+  uint8_t leadbuf[CPU_CACHE_LINE_BYTES];
+  uint8_t trailbuf[CPU_CACHE_LINE_BYTES];
 typedef struct {
   spi_bus base;
   bool msg_cs_change;
   const spi_ioc_transfer *msg_current;
+  const spi_ioc_transfer *msg_next;
   uint32_t msg_todo;
   int msg_error;
   rtems_id msg_task;
   Spid spi;
   uint32_t dma_tx_channel;
   uint32_t dma_rx_channel;
+  struct atsam_spi_xdma_buf *dma_bufs;
+  size_t leadbuf_rx_buffered_len;
+  size_t trailbuf_rx_buffered_len;
   int transfer_in_progress;
   bool chip_select_active;
   bool chip_select_decode;
@@ -127,17 +145,155 @@ static void atsam_configure_spi(atsam_spi_bus *bus)
   SPI_ConfigureNPCS(bus->spi.pSpiHw, cs, csr);
+static void atsam_spi_check_alignment_and_set_up_dma_descriptors(
+  atsam_spi_bus *bus,
+  struct atsam_spi_xdma_buf *buf,
+  const uint8_t *start,
+  size_t len,
+  bool tx
+  LinkedListDescriporView0 *curdesc = buf->desc;
+  size_t misaligned_begin;
+  size_t misaligned_end;
+  size_t len_main;
+  const uint8_t *start_main;
+  const uint8_t *start_trail;
+  /* Check alignments. */
+  if (len < CPU_CACHE_LINE_BYTES) {
+    misaligned_begin = len;
+    misaligned_end = 0;
+    len_main = 0;
+  } else {
+    misaligned_begin = ((uint32_t) start) % CPU_CACHE_LINE_BYTES;
+    misaligned_end = (((uint32_t) start) + len) % CPU_CACHE_LINE_BYTES;
+    len_main = len - misaligned_begin - misaligned_end;
+  start_main = start + misaligned_begin;
+  start_trail = start_main + len_main;
+  /* Store length for copying data back. */
+  if (!tx) {
+    bus->leadbuf_rx_buffered_len = misaligned_begin;
+    bus->trailbuf_rx_buffered_len = misaligned_end;
+  /* Handle misalignment on begin. */
+  if (misaligned_begin != 0) {
+    if (tx) {
+      atsam_copy_to_io(buf->leadbuf, start, misaligned_begin);
+    curdesc->mbr_nda = (uint32_t) (&curdesc[1]);
+    curdesc->mbr_ta = (uint32_t) buf->leadbuf;
+    curdesc->mbr_ubc = misaligned_begin;
+  /* Main part */
+  if (len_main > 0) {
+    curdesc->mbr_ubc |= tx ? XDMA_UBC_NSEN_UPDATED : XDMA_UBC_NDEN_UPDATED;
+    curdesc->mbr_ubc |= XDMA_UBC_NVIEW_NDV0;
+    curdesc->mbr_ubc |= XDMA_UBC_NDE_FETCH_EN;
+    ++curdesc;
+    curdesc->mbr_ta = (uint32_t) start_main;
+    curdesc->mbr_ubc = len_main;
+    if (tx) {
+      rtems_cache_flush_multiple_data_lines(start_main, len_main);
+    } else {
+      rtems_cache_invalidate_multiple_data_lines(start_main, len_main);
+  /* Handle misalignment on end */
+  if (misaligned_end != 0) {
+    ++curdesc;
+    if (tx) {
+      atsam_copy_to_io(buf->trailbuf, start_trail, misaligned_end);
+    curdesc->mbr_nda = 0;
+    curdesc->mbr_ta = (uint32_t) buf->trailbuf;
+    curdesc->mbr_ubc = misaligned_end;
+    curdesc->mbr_ubc |= XDMA_UBC_NDE_FETCH_DIS;
+static void atsam_spi_copy_back_rx_after_dma_transfer(
+  if (bus->leadbuf_rx_buffered_len != 0) {
+      bus->msg_current->rx_buf,
+      bus->dma_bufs[DMA_BUF_RX].leadbuf,
+  if (bus->trailbuf_rx_buffered_len != 0) {
+      bus->msg_current->rx_buf + bus->msg_current->len -
+        bus->trailbuf_rx_buffered_len,
+      bus->dma_bufs[DMA_BUF_RX].trailbuf,
 static void atsam_spi_start_dma_transfer(
   atsam_spi_bus *bus,
   Xdmac *pXdmac = XDMAC;
+  size_t i;
+  atsam_spi_check_alignment_and_set_up_dma_descriptors(
+    bus,
+    &bus->dma_bufs[DMA_BUF_RX],
+    msg->rx_buf,
+    msg->len,
+    false
+    bus,
+    &bus->dma_bufs[DMA_BUF_TX],
+    msg->tx_buf,
+    msg->len,
+    true
+  XDMAC_SetDescriptorAddr(
+    pXdmac,
+    bus->dma_rx_channel,
+    (uint32_t) bus->dma_bufs[DMA_BUF_RX].desc,
+    0
+  XDMAC_SetDescriptorControl(
+    pXdmac,
+    XDMAC_CNDC_NDVIEW_NDV0 |
+    XDMAC_CNDC_NDDUP_DST_PARAMS_UPDATED |
+    XDMAC_CNDC_NDE_DSCR_FETCH_EN
+    pXdmac,
+    bus->dma_tx_channel,
+    (uint32_t) bus->dma_bufs[DMA_BUF_TX].desc,
+    0
+    pXdmac,
+    XDMAC_CNDC_NDSUP_SRC_PARAMS_UPDATED |
-  XDMAC_SetDestinationAddr(pXdmac, bus->dma_rx_channel, (uint32_t)msg->rx_buf);
-  XDMAC_SetSourceAddr(pXdmac, bus->dma_tx_channel, (uint32_t)msg->tx_buf);
-  XDMAC_SetMicroblockControl(pXdmac, bus->dma_rx_channel, msg->len);
-  XDMAC_SetMicroblockControl(pXdmac, bus->dma_tx_channel, msg->len);
   XDMAC_StartTransfer(pXdmac, bus->dma_rx_channel);
   XDMAC_StartTransfer(pXdmac, bus->dma_tx_channel);
@@ -205,11 +361,12 @@ static void atsam_spi_setup_transfer(atsam_spi_bus *bus)
   if (msg_todo > 0) {
-    const spi_ioc_transfer *msg = bus->msg_current;
+    const spi_ioc_transfer *msg = bus->msg_next;
     int error;
     bus->msg_cs_change = msg->cs_change;
-    bus->msg_current = msg + 1;
+    bus->msg_next = msg + 1;
+    bus->msg_current = msg;
     bus->msg_todo = msg_todo - 1;
     error = atsam_check_configure_spi(bus, msg);
@@ -231,6 +388,7 @@ static void atsam_spi_dma_callback(uint32_t channel, void *arg)
   --bus->transfer_in_progress;
   if (bus->transfer_in_progress == 0) {
+    atsam_spi_copy_back_rx_after_dma_transfer(bus);
     atsam_spi_setup_transfer(bus);
@@ -241,15 +399,18 @@ static int atsam_spi_transfer(
   uint32_t msg_count
+  rtems_status_code sc;
   atsam_spi_bus *bus = (atsam_spi_bus *)base;
   bus->msg_cs_change = false;
-  bus->msg_current = &msgs[0];
+  bus->msg_next = &msgs[0];
+  bus->msg_current = NULL;
   bus->msg_todo = msg_count;
   bus->msg_error = 0;
   bus->msg_task = rtems_task_self();
-  rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  assert(sc == RTEMS_SUCCESSFUL);
   return bus->msg_error;
@@ -281,6 +442,8 @@ static void atsam_spi_destroy(spi_bus *base)
   SPI_Disable(bus->spi.pSpiHw);
   PMC_DisablePeripheral(bus->spi.spiId);
+  rtems_cache_coherent_free(bus->dma_bufs);
   spi_bus_destroy_and_free(&bus->base);
@@ -305,6 +468,14 @@ static void atsam_spi_init_xdma(atsam_spi_bus *bus)
   uint32_t xdmaInt;
   uint8_t channel;
   eXdmadRC rc;
+  uint32_t xdma_cndc;
+  bus->dma_bufs = rtems_cache_coherent_allocate(
+    DMA_BUF_DIRS * sizeof(*(bus->dma_bufs)),
+    DMA_DESC_ALLIGNMENT,
+    0
+  assert(bus->dma_bufs != NULL);
   bus->dma_tx_channel = XDMAD_AllocateChannel(
     bus->spi.pXdmad,
@@ -342,7 +513,7 @@ static void atsam_spi_init_xdma(atsam_spi_bus *bus)
   rc = XDMAD_PrepareChannel(bus->spi.pXdmad, bus->dma_tx_channel);
   assert(rc == XDMAD_OK);
-  /* Put all interrupts on for non LLI list setup of DMA */
+  /* Put all relevant interrupts on */
   xdmaInt =  (
     XDMAC_CIE_BIE |
     XDMAC_CIE_DIE |
@@ -366,12 +537,16 @@ static void atsam_spi_init_xdma(atsam_spi_bus *bus)
     XDMAC_CC_SAM_FIXED_AM |
     XDMAC_CC_DAM_INCREMENTED_AM |
     XDMAC_CC_PERID(channel);
+  xdma_cndc = XDMAC_CNDC_NDVIEW_NDV0 |
+    XDMAC_CNDC_NDE_DSCR_FETCH_EN |
+    XDMAC_CNDC_NDSUP_SRC_PARAMS_UNCHANGED;
   rc = XDMAD_ConfigureTransfer(
     bus->spi.pXdmad,
     &cfg,
-    0,
-    0,
+    xdma_cndc,
     xdmaInt
@@ -391,12 +566,16 @@ static void atsam_spi_init_xdma(atsam_spi_bus *bus)
     XDMAC_CC_SAM_INCREMENTED_AM |
     XDMAC_CC_DAM_FIXED_AM |
+    XDMAC_CNDC_NDDUP_DST_PARAMS_UNCHANGED |
+    XDMAC_CNDC_NDSUP_SRC_PARAMS_UPDATED;
     bus->spi.pXdmad,
     &cfg,
-    0,
-    0,
+    xdma_cndc,
     xdmaInt
diff --git a/c/src/lib/libbsp/arm/atsam/utils/iocopy.c b/c/src/lib/libbsp/arm/atsam/utils/iocopy.c
index 0000000000..b91282dac6
--- /dev/null
+++ b/c/src/lib/libbsp/arm/atsam/utils/iocopy.c
@@ -0,0 +1,49 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+static void atsam_do_copy(
+  uint8_t *dst,
+  const uint8_t *src,
+  size_t n,
+  bool aligned
+  if (aligned) {
+    while (n > 3) {
+      *(uint32_t *)dst = *(uint32_t *)src;
+      dst += 4;
+      src += 4;
+      n -= 4;
+  while (n > 0) {
+    *dst = *src;
+    ++dst;
+    ++src;
+    --n;
+  atsam_do_copy(dst, src, n, ((uintptr_t)dst) % 4 == 0);
+  atsam_do_copy(dst, src, n, ((uintptr_t)src) % 4 == 0);
2.13.6
