Contribute to project
Mon Feb 12 19:05:20 UTC 2018
Abhinav,
Attempt to reproduce the reported problem, try out the patch and see
if it works. I see this was reported for 4.10. See if the problem also
affects 4.11, master, and if the fix works for them too.
Gedare
On Mon, Feb 12, 2018 at 11:55 AM, Abhinav Jain <jainab.2009 at gmail.com> wrote:
> Sir,
> I have gone through the projects available in the link provided by you and I
> am interested in an issue (RSB can sometimes change the wrong local git
> repository (includes a fix).) listed there.
> Link: https://devel.rtems.org/ticket/2522#no1
> I request you to please provide some more information regarding this so that
> I can proceed with the coding part.
> Thanks and Regards
> Abhinav Jain
> On Wed, Feb 7, 2018 at 9:12 AM, Abhinav Jain <jainab.2009 at gmail.com> wrote:
>> Sir,
>> Thanks a lot for the guidance. I will start with contributing to an
>> existing project.
>> Thanks and Regards
>> Abhinav jain
>> On Feb 6, 2018 10:55 PM, "Gedare Bloom" <gedare at rtems.org> wrote:
>>> Hello Abhinav Jain,
>>> It is good that you are studying. Now, you should pursue two paths:
>>> 1. Produce some code for RTEMS, perhaps by fixing a bug. A good place
>>> to start is the tickets on the open releases:
>>> https://devel.rtems.org/query?status=assigned&status=accepted&status=reopened&group=status&milestone=4.11.3
>>> https://devel.rtems.org/query?status=accepted&status=assigned&status=new&status=reopened&milestone=4.10.3&group=status&order=priority
>>> 2. Prepare your project idea. You will want to convert your learning
>>> into a concrete, achievable plan for code that can be implemented in
>>> RTEMS and will be beneficial to someone.
>>> Gedare
>>> On Tue, Feb 6, 2018 at 10:23 AM, Abhinav Jain <jainab.2009 at gmail.com>
>>> wrote:
>>> > Sir,
>>> > I have studied about SASOS. It's really a great approach to make the
>>> > process
>>> > faster by avoiding multiple copies of the data. I read about two SASOS
>>> > namely Angel system(developed at City University, London) and Mungi
>>> > system(developed by University of New South Wales, Australia). I also
>>> > studied about Memory Protection in SASOS, where the concept of address
>>> > protection is replaced by protection domain. I studied about
>>> > Multithreading,
>>> > POSIX, Race condition and Synchronization to avoid the Race condition.
>>> > Please guide me, am I  on the right path and what all do I need to
>>> > learn
>>> > further?
>>> > Thanks and Regards
>>> > Abhinav Jain
>>> > On Wed, Jan 31, 2018 at 11:17 PM, Abhinav Jain <jainab.2009 at gmail.com>
>>> > wrote:
>>> >> Sir,
>>> >> Thanks for the guidance. The mail is very informative and I will
>>> >> follow
>>> >> the way suggested by you.
>>> >> Thanks and regards
>>> >> Abhinav Jain
>>> >> On Jan 31, 2018 5:41 PM, "Sebastian Huber"
>>> >> <sebastian.huber at embedded-brains.de> wrote:
>>> >>> The MMU support is a very challenging project. The scope of the
>>> >>> project
>>> >>> and potential use cases must be determined. You need a lot of
>>> >>> experience to
>>> >>> design good APIs and it helps if you know the APIs for this kind of
>>> >>> stuff on
>>> >>> other systems like QNX, Linux, FreeBSD, etc. For the architecture
>>> >>> support a
>>> >>> lot of background knowledge is required at least on PowerPC,
>>> >>> ARMv5..8,
>>> >>> SPARC, Nios2, MIPS, etc. For example, changing the TLB1 based MMU
>>> >>> during
>>> >>> application run-time on PowerPC (including SMP support, cache
>>> >>> consistency)
>>> >>> is not easy. There are some optimization problems involved if you
>>> >>> want to
>>> >>> determine a good cover with memory areas (alignment restrictions,
>>> >>> limited
>>> >>> number of areas in the MMU/MPU if not page based, e.g. 16).
>>> >>> Sebastian Huber, embedded brains GmbH
>>> >>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> >>> Phone   : +49 89 189 47 41-16
>>> >>> Fax     : +49 89 189 47 41-09
>>> >>> E-Mail  : sebastian.huber at embedded-brains.de
>>> >>> PGP     : Public key available on request.
>>> >>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
