[PATCH v2 0/5] Misc Patch Series
Fri Feb 16 17:27:02 UTC 2018
V2 of the patch was needed to correct having a comma in an email address.
This patch series adds paravirtualization support to the ARM and
PowerPC plus some odd clean up encountered along the way.
Jennifer Averett (1):
  Add PowerPC paravirtualization support
Joel Sherrill (3):
  unhex.c: Remove unnecessary extern of errno
  powerpc/shared/startup/linkcmds.base: Add wildcards on some sections
  Add ARM Paravirtualization support
jennifer (1):
  sp54: Fix warning
 c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base    |  6 +++---
 c/src/lib/libcpu/powerpc/new-exceptions/cpu.c            | 10 +++++++---
 c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S        | 16 ++++++++++++++++
 cpukit/score/cpu/arm/cpu_asm.S                           |  2 ++
 cpukit/score/cpu/arm/include/rtems/score/cpu.h           |  6 ++++++
 .../score/cpu/powerpc/include/rtems/powerpc/registers.h  |  7 +++++++
 cpukit/score/cpu/powerpc/include/rtems/score/cpu.h       |  8 ++++++++
 testsuites/sptests/sp54/init.c                           |  2 +-
 tools/build/unhex.c                                      |  2 --
 9 files changed, 50 insertions(+), 9 deletions(-)
1.8.3.1
