[PATCH v3 0/5] V3 - ARM and PowerPC Paravirtualization, etc.
Joel Sherrill
joel at rtems.org
Fri Feb 16 17:31:24 UTC 2018
V2-3 of the patch was needed to correct having a comma in an email address.
This patch series adds paravirtualization support to the ARM and
PowerPC plus some odd clean up encountered along the way.
Jennifer Averett (2):
Add PowerPC paravirtualization support
sp54: Fix warning
Joel Sherrill (3):
unhex.c: Remove unnecessary extern of errno
powerpc/shared/startup/linkcmds.base: Add wildcards on some sections
Add ARM Paravirtualization support
c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base | 6 +++---
c/src/lib/libcpu/powerpc/new-exceptions/cpu.c | 10 +++++++---
c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S | 16 ++++++++++++++++
cpukit/score/cpu/arm/cpu_asm.S | 2 ++
cpukit/score/cpu/arm/include/rtems/score/cpu.h | 6 ++++++
.../score/cpu/powerpc/include/rtems/powerpc/registers.h | 7 +++++++
cpukit/score/cpu/powerpc/include/rtems/score/cpu.h | 8 ++++++++
testsuites/sptests/sp54/init.c | 2 +-
tools/build/unhex.c | 2 --
9 files changed, 50 insertions(+), 9 deletions(-)
1.8.3.1
