Contribute to project
Tue Feb 20 13:52:56 UTC 2018
On Sun, Feb 18, 2018 at 3:19 AM, Abhinav Jain <jainab.2009 at gmail.com> wrote:
> Sir,
> I have gone through the code concerning the issue raised. I also read about
> the working of git status command and the problem that I am able to figure
> out is that although the existing code is able to check whether the current
> path exists or not but since it is relying on git status to check whether
> the .git file is available or not, a problem is there. The git status checks
> the current directory for the .git file but in case the current directory
> doesn't have the .git file, it will look for it in the parent directory and
> if found there it will return True, which voids the purpose.
> So, I think, if a second check is given to validate whether the current
> directory contains .git file or not will solve the issue.
> So the code may be:
> def valid(self):
>         if path.exists(self.path):
> if path.exists(path.join(self.path, ".git")):
>             ec, output = self._run(['status'])
>             return ec == 0
>         return False
> I request you to please guide me whether I proceeded in a right way or not.
That appears to be the code from the patch on the Trac, with Chris'
comment to replace os.path.join with path.join. But, have you been
able to (1) reproduce the problem, and (2) confirm this fixes it?
> Thanks and Regards
> Abhinav Jain
> On Tue, Feb 13, 2018 at 10:50 AM, Abhinav Jain <jainab.2009 at gmail.com>
> wrote:
>> Sir,
>> Thanks for the guidance. I will study the code available and will try to
>> resolve the issue as soon as possible.
>> Thanks and Regards
>> Abhinav Jain
>> On Tue, Feb 13, 2018 at 4:47 AM, Chris Johns <chrisj at rtems.org> wrote:
>>> On 13/02/2018 06:05, Gedare Bloom wrote:
>>> > Abhinav,
>>> > Attempt to reproduce the reported problem, try out the patch and see
>>> > if it works. I see this was reported for 4.10. See if the problem also
>>> > affects 4.11, master, and if the fix works for them too.
>>> I suspect it is common to all branches.
>>> > On Mon, Feb 12, 2018 at 11:55 AM, Abhinav Jain <jainab.2009 at gmail.com>
>>> > wrote:
>>> >> Sir,
>>> >> I have gone through the projects available in the link provided by you
>>> >> and I
>>> >> am interested in an issue (RSB can sometimes change the wrong local
>>> >> git
>>> >> repository (includes a fix).) listed there.
>>> >> Link: https://devel.rtems.org/ticket/2522#no1
>>> >> I request you to please provide some more information regarding this
>>> >> so that
>>> >> I can proceed with the coding part.
>>> As Gedare suggests take a look at the master and 4.11 branches and if
>>> present
>>> work I suggest you work on the master branch and then we can take git.py
>>> and
>>> back port to 4.11 and 4.10 by simply coping git.py to those branches.
>>> Chris
