[PATCH 0/3] v3 - Paravirtualization Patch Series
Thu Feb 22 02:25:53 UTC 2018
----- Am 21. Feb 2018 um 21:07 schrieb joel joel at rtems.org:
> Hi
> This patch series reworks the ARM and PowerPC support addition
> as well as reworks the i386 paravirtualization support based
> on Chris Johns' suggestion. He suggested adding a
> rtems/score/paravirt.h for each architecture
This is not what you are doing. You added one rtems/score/paravirt.h for all architectures.
> and using
> derived feature macros instead of RTEMS_PARAVIRT directly.
> This has the nice side-effect of paravirt.h documenting
> what the paravirtualization environment is for each
> architecture as well as precisely the purpose of each
> introduced conditional compilation.
This new rtems/score/paravirt.h is completely against the current score/cpu/* structure. Architecture-specific stuff should not be aggregated in one file, instead the existing architecture-specific cpu.h, etc. files should be used.
Architecture-specific names should use an ARCH_ or _Arch prefix and not CPU_ARCH or _CPU_Arch.
This
CPU_DISABLE_INLINE_ISR_DISABLE_ENABLE
is an architecture-specific implementation detail which doesn't propagate to generic files, e.g. rtems/score/isrlevel.h, so it should not be introduced from my point of view.
I don't think it is worth to add a rtems/score/paravirt.h for each architecture.  The changes introduced by RTEMS_PARAVIRT are too small to justify this.  I am also not sure if you can encapsulate this in one header in all cases.
