[PATCH] rsb: Add '--patchdir' option description
    Maksim E. Kozlov
    maksim.e.kozlov at gmail.com
    Tue Feb 20 14:47:51 UTC 2018
According to commit d30be3129e9681a74efc80ce241aaf3c3a5b0efe in
rtems-source-builder repo.
Signed-off-by: Maksim E. Kozlov <maksim.e.kozlov at gmail.com>
 rsb/commands.rst | 7 +++++++
 1 file changed, 7 insertions(+)
diff --git a/rsb/commands.rst b/rsb/commands.rst
index 3ef7772..ab338c1 100644
--- a/rsb/commands.rst
+++ b/rsb/commands.rst
@@ -31,6 +31,7 @@ This commands checks your system is set up correctly. Most options are ignored::
     --configdir path       : Path to the configuration directory, default: ./config
     --builddir path        : Path to the build directory, default: ./build
     --sourcedir path       : Path to the source directory, default: ./source
+    --patchdir path        : Path to the patches directory, default: ./patches
     --tmppath path         : Path to the temp directory, default: ./tmp
     --macros file[,[file]  : Macro format files to load after the defaults
     --log file             : Log file where all build out is written too
@@ -72,6 +73,7 @@ arguments. Most options are ignored::
@@ -109,6 +111,7 @@ This command builds a set::
@@ -196,6 +199,9 @@ The ``arguments`` are a list of build sets to build.
 ``--sourcedir path``:
   Path to the source directory. This overrides the default of +source+.
+``--patchdir path``:
+  Path to the patches directory. This overrides the default of +patches+.
 ``--tmppath path``:
   Path to the temporary directory. This overrides the default of +tmp+.
@@ -311,6 +317,7 @@ file. Configuration files have the extension of ``.cfg``::
1.9.1
