RSB valid status check (was: Contribute to project)
Abhinav Jain jainab.2009 at gmail.com
Tue Feb 20 14:57:13 UTC 2018
Sir,
I will edit the current patch accordingly and will take care of this in the
future.
Thanks and Regards
Abhinav Jain
On Tue, Feb 20, 2018 at 7:31 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Oops, I should read my mail better. Thanks for breaking this out Chris.
> Abhinav,
> On Tue, Feb 20, 2018 at 1:12 AM, Abhinav Jain <jainab.2009 at gmail.com>
> wrote:
> > Sir,
> > I have attached the patch file with this mail. I have tried to follow all
> > the conventions that were listed in the User Git page. I request you to
> > please check and guide me whether I have done it correctly or not or
> whether
> > something more is to be done.
> I won't comment on the code, I'll let Chris do that. However, this
> patch has a few issues that should be addressed.
> 1. Use line breaks in your commit message. About 70-80 characters per
> line max, please.
> 2. The "short message" can omit "function added to", basically all
> patches add some code, so this is a bit redundant. You can just say
> "Check the validity ..."
> 3. The commit message should use "Closes #nnnn." somewhere, usually in
> the end of the commit, if it is fixing/closing a ticket.
> 4. The commit message may be less verbose, if the extra details about
> the change are already in the ticket.
> 5. Avoid adding extra white spaces randomly, e.g. hunk #2 of the
> patch, and avoid introducing white space new lines where one exists,
> creating 2 blank lines in a row.
> 6. You may like to try to get git-send-email to work for you. It is a
> little nicer for submitting patches to mailing list.
> https://devel.rtems.org/wiki/Developer/Git/Users#Configuringgit-send-
> emailtouseGMail
> -Gedare
> > Thanks and Regards
> > Abhinav Jain
> > On Tue, Feb 20, 2018 at 4:13 AM, Chris Johns <chrisj at rtems.org> wrote:
> >> On 19/02/2018 21:19, Abhinav Jain wrote:
> >> > I have made the changes suggested by you in the code and hopefully,
> the
> >> > issue
> >> > will be resolved as if the .git file is not found in the directory,
> the
> >> > process
> >> > will not go ahead and hence the wrong git repository will not be
> >> > changed.
> >> Excellent. Please post for review.
> >> > I request to please guide me whether anything more is to be done in
> the
> >> > code or
> >> > should I proceed with a pull request.
> >> I assume you mean a github pull request. RTEMS uses patches sent to this
> >> list
> >> for review. The top page of the Wiki has a section called RTEMS
> Developer
> >> Information and in that section are links to User Git access and
> >> submitting
> >> patches. You can also attach the patch to the ticket.
> >> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180220/80ffbaf5/attachment-0002.html>
