RSB valid status check (was: Contribute to project)
Abhinav Jain
jainab.2009 at gmail.com
Thu Feb 22 01:22:14 UTC 2018
Sir,
I request you to please guide me whether I have done the task correctly or
not and if something more is to be modified in this.
If this is done correctly, please tell me how should I proceed further for
the memory management project, which I was discussing earlier.
Thanks and Regards
Abhinav Jain
On Feb 20, 2018 10:17 PM, "Abhinav Jain" <jainab.2009 at gmail.com> wrote:
> Sir,
> I have tried to incorporate the changes suggested by you.
> I request you to please check the new patch file and guide me if some more
> improvement is needed to be done.
> Thanks and Regards
> Abhinav Jain
> On Tue, Feb 20, 2018 at 8:27 PM, Abhinav Jain <jainab.2009 at gmail.com>
> wrote:
>> Sir,
>> I will edit the current patch accordingly and will take care of this in
>> the future.
>> Thanks and Regards
>> Abhinav Jain
>> On Tue, Feb 20, 2018 at 7:31 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> Oops, I should read my mail better. Thanks for breaking this out Chris.
>>> Abhinav,
>>> On Tue, Feb 20, 2018 at 1:12 AM, Abhinav Jain <jainab.2009 at gmail.com>
>>> wrote:
>>> > Sir,
>>> > I have attached the patch file with this mail. I have tried to follow
>>> all
>>> > the conventions that were listed in the User Git page. I request you to
>>> > please check and guide me whether I have done it correctly or not or
>>> whether
>>> > something more is to be done.
>>> I won't comment on the code, I'll let Chris do that. However, this
>>> patch has a few issues that should be addressed.
>>> 1. Use line breaks in your commit message. About 70-80 characters per
>>> line max, please.
>>> 2. The "short message" can omit "function added to", basically all
>>> patches add some code, so this is a bit redundant. You can just say
>>> "Check the validity ..."
>>> 3. The commit message should use "Closes #nnnn." somewhere, usually in
>>> the end of the commit, if it is fixing/closing a ticket.
>>> 4. The commit message may be less verbose, if the extra details about
>>> the change are already in the ticket.
>>> 5. Avoid adding extra white spaces randomly, e.g. hunk #2 of the
>>> patch, and avoid introducing white space new lines where one exists,
>>> creating 2 blank lines in a row.
>>> 6. You may like to try to get git-send-email to work for you. It is a
>>> little nicer for submitting patches to mailing list.
>>> https://devel.rtems.org/wiki/Developer/Git/Users#Configuring
>>> git-send-emailtouseGMail
>>> -Gedare
>>> > Thanks and Regards
>>> > Abhinav Jain
>>> > On Tue, Feb 20, 2018 at 4:13 AM, Chris Johns <chrisj at rtems.org> wrote:
>>> >> On 19/02/2018 21:19, Abhinav Jain wrote:
>>> >> > I have made the changes suggested by you in the code and hopefully,
>>> the
>>> >> > issue
>>> >> > will be resolved as if the .git file is not found in the directory,
>>> the
>>> >> > process
>>> >> > will not go ahead and hence the wrong git repository will not be
>>> >> > changed.
>>> >> Excellent. Please post for review.
>>> >> > I request to please guide me whether anything more is to be done in
>>> the
>>> >> > code or
>>> >> > should I proceed with a pull request.
>>> >> I assume you mean a github pull request. RTEMS uses patches sent to
>>> this
>>> >> list
>>> >> for review. The top page of the Wiki has a section called RTEMS
>>> Developer
>>> >> Information and in that section are links to User Git access and
>>> >> submitting
>>> >> patches. You can also attach the patch to the ticket.
>>> >> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180222/fcb4233d/attachment-0002.html>
