POSIX and return codes...
    Jakob Viketoft
    jakob.viketoft at aacmicrotec.com
    Mon Feb 26 13:27:13 UTC 2018
Hello Joel,
Sent: Monday, February 26, 2018 12:21
> On Feb 26, 2018 5:13 AM, "Jakob Viketoft" <jakob.viketoft at aacmicrotec.com> wrote:
>> E.g. could it be possible for the translation mechanism to look if there is already an errno defined and then return this instead of doing the error code translation?
>> It seems like the translation I'm talking about happens in the rtems_deviceio_write() function in cpukit/libcsupport/src/sup_fs_deviceio.c
> Completely random thought as I sit on a plane without code.
> Add a field to the arguments structure for errno. See it to zero before the call. If it is set to non-zero after the call, then the driver wanted to return errno directly. Otherwise translate.
This was my thought as well, I just wanted to bounce it off the RTEMS list and also possibly get official support for a feature as this.
> A middle step is to see if any of the unused RTEMS status codes make sense to use and cover your use cases.
This is the way we do it today. Unfortunately, so many of the different RTEMS codes are translated into the same errno codes which makes it very hard to have an intelligent error reporting/differentiation.
      /Jakob
