N2X, GR740 and coverage: The impact of a linkcmds patch from 2014 to gcov_init calls
Wed Feb 28 12:08:07 UTC 2018
It was a bug in the linker command file. See attached patches.
----- Am 28. Feb 2018 um 12:50 schrieb Thanassis Tsiodras Thanassis.Tsiodras at esa.int:
>> However, I am not able to reproduce this problem.
> Hi Sebastian.
> Look at the reply I sent this morning to the mailing list - I uploaded the
> code in a GitHub repository and provided instructions in the mailing list
> with the exact invocations that reproduce the issue.
> Hope this helps!
> Thanassis.
> Thanassis Tsiodras
> Real-time Embedded Software Engineer
> System, Software and Technology Department
> ESTEC
> Keplerlaan 1, PO Box 299
> NL-2200 AG Noordwijk, The Netherlands
> Thanassis.Tsiodras at esa.int | www.esa.int
> T +31 71 565 5332
> From:   Sebastian Huber <sebastian.huber at embedded-brains.de>
> To:     Thanassis Tsiodras <Thanassis.Tsiodras at esa.int>
> Cc:     devel <devel at rtems.org>
> Date:   28/02/2018 12:11
> Subject:        Re: N2X, GR740 and coverage: The impact of a linkcmds
> ----- Am 27. Feb 2018 um 17:30 schrieb Thanassis Tsiodras
>> After quite a lot of hunting, we traced this failure to a patch in the
>> "linkcmds.base" - done back in 2014 ( commit 95cb09ed746 ) :
>> This commit changed
> "c/src/lib/libbsp/sparc/shared/startup/linkcmds.base"
>> from this:
>>    KEEP (*(SORT(.ctors.*)))
>>    KEEP (*(.ctors))
>>    KEEP (*crtbegin.o(.dtors))
>>    KEEP (*crtbegin?.o(.dtors))
>>    KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
>>    KEEP (*(SORT(.dtors.*)))
>>    KEEP (*(.dtors))
>> ...to this:
>>    KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
>>    KEEP (*(SORT(.ctors*)))
>>    KEEP (*(SORT(.dtors*)))
>> Reverting this change, the gcov stubs revert back to their proper place,
>> and __gcov_inits are called properly.
>> The reason I tried this patch, was because I noticed that the coverage
>> stubs are no longer placed in ".ctor" sections - they are instead placed
>> by the newer compilers at ".ctor.NUMBER" sections (with NUMBER set to
>> 65435 in my case - but I am guessing this will change from invocation to
>> invocation).
>> The comment provided by Joel back in 2014, only indicated that this
> patch
>> was done to address C++ concerns:
>> commit 95cb09ed746e7daeca2158c7ecdf0249cfcbc5c8
>> Author: Joel Sherrill <joel.sherrill at oarcorp.com>
>> Date:   Wed Apr 2 11:39:20 2014 -0500
>>    sparc/shared/.../linkcmds.base: Correct C++ support
>>    Add KEEP() for .eh_frame*, .ctor*, and .dtor*.
> It could be a bug in the linker. The standard sections should be exactly
> like the Binutils default:
> sparc-rtems5-ld --verbose | grep ctor -C 3
>      *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
>      *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
>      *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
>      *(.rela.ctors)
>      *(.rela.dtors)
>      *(.rela.got)
>      *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
>  .init_array     :
>    PROVIDE_HIDDEN (__init_array_start = .);
>    KEEP (*(SORT_BY_INIT_PRIORITY(.init_array.*)
> SORT_BY_INIT_PRIORITY(.ctors.*)))
>    KEEP (*(.init_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o
>    PROVIDE_HIDDEN (__init_array_end = .);
>  .fini_array     :
>    KEEP (*(.fini_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o
>    PROVIDE_HIDDEN (__fini_array_end = .);
>  .ctors          :
>    /* gcc uses crtbegin.o to find the start of
>       the constructors, so we make sure it is
>       first.  Because this is a wildcard, it
>       doesn't matter if the user does not
>       actually link against crtbegin.o; the
>       linker won't look for a file to match a
>       wildcard.  The wildcard also means that it
>       doesn't matter which directory crtbegin.o
>       is in.  */
>    KEEP (*crtbegin.o(.ctors))
>    KEEP (*crtbegin?.o(.ctors))
>    /* We don't want to include the .ctor section from
>       the crtend.o file until after the sorted ctors.
>       The .ctor section from the crtend file contains the
>       end of ctors marker and it must be last */
>    KEEP (*(.ctors))
>  .dtors          :
> However, I am not able to reproduce this problem. For example in the
> sptls04 linker map file (-Wl,-Map,map.txt) we have this:
> *crtbegin.o(.ctors)
> .ctors         0x0000000002011330        0x4
> /opt/rtems/5/lib/gcc/sparc-rtems5/7.3.0/crtbegin.o
> *(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
> .ctors         0x0000000002011334        0x4 init.o
> *(SORT_BY_NAME(.ctors*))
> .ctors         0x0000000002011338        0x4
> /opt/rtems/5/lib/gcc/sparc-rtems5/7.3.0/crtend.o
> Who do the linker map files look in your test case?
> This message and any attachments are intended for the use of the addressee or
> addressees only.
> The unauthorised disclosure, use, dissemination or copying (either in whole or
> in part) of its
> content is not permitted.
> If you received this message in error, please notify the sender and delete it
> from your system.
> Emails can be altered and their integrity cannot be guaranteed by the sender.
> Please consider the environment before printing this email.
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180228/79498ef6/attachment-0004.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180228/79498ef6/attachment-0005.bin>
