[PATCH 0/9] 4.10 Maintenance
Gedare Bloom
gedare at rtems.org
Thu Jan 11 18:13:02 UTC 2018
I went through commits between the 4.10/4.11 split and
January 2013, and selected the following as suitable
to apply for 4.10 maintenance. Not all of these had
open PRs/tickets, and I did not reformat any patches
but simply cherry-picked and corrected any conflicts.
Ralf Kirchner (1):
dosfs: Fix msdos_format()
Sebastian Huber (6):
dosfs: Fix for no space left on device condition
librpc: PR2066: Fix for short enums
rtems: PR1844: Fix MP process packet size
score: Use _Workspace_Allocate_or_fatal_error()
libnetworking: Disconnect after mbuf shortage
bsps: Fix rtems_interrupt_server_handler_remove()
Sebastien Bourdeauducq (2):
network/dhcp: PR1841: Fix DNS processing in DHCP
network/bootp: PR2031: Add and use header file
c/src/lib/libbsp/shared/src/irq-server.c | 4 +-
cpukit/libfs/src/dosfs/fat_file.c | 8 ++-
cpukit/libfs/src/dosfs/msdos_format.c | 2 +-
cpukit/libnetworking/Makefile.am | 1 +
cpukit/libnetworking/netinet/udp_usrreq.c | 5 +-
cpukit/libnetworking/nfs/bootp_subr.c | 16 +----
cpukit/libnetworking/rtems/bootp.h | 41 ++++++++++++
cpukit/libnetworking/rtems/rtems_bootp.c | 2 +
cpukit/libnetworking/rtems/rtems_bsdnet_internal.h | 1 -
cpukit/libnetworking/rtems/rtems_dhcp.c | 74 ++++++++++++++--------
cpukit/librpc/include/rpc/auth.h | 3 +-
cpukit/librpc/include/rpc/clnt_stat.h | 3 +-
cpukit/librpc/include/rpc/rpc_msg.h | 12 ++--
cpukit/librpc/include/rpc/svc.h | 3 +-
cpukit/librpc/include/rpcsvc/nis_db.h | 6 +-
cpukit/librpc/include/rpcsvc/yp_prot.h | 3 +-
cpukit/librpc/src/xdr/xdr.c | 8 +--
cpukit/rtems/src/msgmp.c | 4 +-
cpukit/score/src/objectextendinformation.c | 13 ++--
19 files changed, 140 insertions(+), 69 deletions(-)
create mode 100644 cpukit/libnetworking/rtems/bootp.h
2.7.4
