[PATCH 0/9] 4.10 Maintenance
Fri Jan 12 21:02:56 UTC 2018
I pushed these patches, and I also updated the 4.10 release notes page
for changes in 4.10.3 with these and a few others that had not been
documented yet.
On Thu, Jan 11, 2018 at 2:24 PM, Joel Sherrill <joel at rtems.org> wrote:
> These are all obviously known issues which were worthy of being included
> on the 4.11 branch and/or master which applied to 4.10.
> Since this are the final approved patch, my vote is to apply them. The only
> discussion should be if the bug exists in 4.10.
> --joel
> On Thu, Jan 11, 2018 at 12:13 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> I went through commits between the 4.10/4.11 split and
>> January 2013, and selected the following as suitable
>> to apply for 4.10 maintenance. Not all of these had
>> open PRs/tickets, and I did not reformat any patches
>> but simply cherry-picked and corrected any conflicts.
>> Ralf Kirchner (1):
>>   dosfs: Fix msdos_format()
>> Sebastian Huber (6):
>>   dosfs: Fix for no space left on device condition
>>   librpc: PR2066: Fix for short enums
>>   rtems: PR1844: Fix MP process packet size
>>   score: Use _Workspace_Allocate_or_fatal_error()
>>   libnetworking: Disconnect after mbuf shortage
>>   bsps: Fix rtems_interrupt_server_handler_remove()
>> Sebastien Bourdeauducq (2):
>>   network/dhcp: PR1841: Fix DNS processing in DHCP
>>   network/bootp: PR2031: Add and use header file
>>  c/src/lib/libbsp/shared/src/irq-server.c           |  4 +-
>>  cpukit/libfs/src/dosfs/fat_file.c                  |  8 ++-
>>  cpukit/libfs/src/dosfs/msdos_format.c              |  2 +-
>>  cpukit/libnetworking/Makefile.am                   |  1 +
>>  cpukit/libnetworking/netinet/udp_usrreq.c          |  5 +-
>>  cpukit/libnetworking/nfs/bootp_subr.c              | 16 +----
>>  cpukit/libnetworking/rtems/bootp.h                 | 41 ++++++++++++
>>  cpukit/libnetworking/rtems/rtems_bootp.c           |  2 +
>>  cpukit/libnetworking/rtems/rtems_bsdnet_internal.h |  1 -
>>  cpukit/libnetworking/rtems/rtems_dhcp.c            | 74
>>  cpukit/librpc/include/rpc/auth.h                   |  3 +-
>>  cpukit/librpc/include/rpc/clnt_stat.h              |  3 +-
>>  cpukit/librpc/include/rpc/rpc_msg.h                | 12 ++--
>>  cpukit/librpc/include/rpc/svc.h                    |  3 +-
>>  cpukit/librpc/include/rpcsvc/nis_db.h              |  6 +-
>>  cpukit/librpc/include/rpcsvc/yp_prot.h             |  3 +-
>>  cpukit/librpc/src/xdr/xdr.c                        |  8 +--
>>  cpukit/rtems/src/msgmp.c                           |  4 +-
>>  cpukit/score/src/objectextendinformation.c         | 13 ++--
>>  19 files changed, 140 insertions(+), 69 deletions(-)
>>  create mode 100644 cpukit/libnetworking/rtems/bootp.h
>> 2.7.4
>> devel mailing list
>> devel at rtems.org
