[PATCH] gcc: Use GNU's FTP rather than the package's home sites that change.
Chris Johns
chrisj at rtems.org
Mon Jan 15 23:56:10 UTC 2018
Close #3271
source-builder/config/gcc-4.3-1.cfg | 6 +++---
source-builder/config/gcc-4.4-1.cfg | 6 +++---
source-builder/config/gcc-4.5-1.cfg | 6 +++---
source-builder/config/gcc-4.6-1.cfg | 6 +++---
source-builder/config/gcc-4.7-1.cfg | 6 +++---
source-builder/config/gcc-4.8-1.cfg | 6 +++---
source-builder/config/gcc-4.9-1.cfg | 6 +++---
7 files changed, 21 insertions(+), 21 deletions(-)
diff --git a/source-builder/config/gcc-4.3-1.cfg b/source-builder/config/gcc-4.3-1.cfg
index d499a15..4c7a335 100644
--- a/source-builder/config/gcc-4.3-1.cfg
+++ b/source-builder/config/gcc-4.3-1.cfg
@@ -21,9 +21,9 @@
# Packages GCC requires
-%source set mpfr http://www.mpfr.org/mpfr-%{mpfr_version}/mpfr-%{mpfr_version}.tar.bz2
-%source set mpc http://www.multiprecision.org/mpc/download/mpc-%{mpc_version}.tar.gz
-%source set gmp ftp://ftp.gnu.org/gnu/gmp/gmp-%{gmp_version}.tar.bz2
+%source set mpfr https://ftp.gnu.org/gnu/mpfr/mpfr-%{mpfr_version}.tar.bz2
+%source set mpc https://ftp.gnu.org/gnu/mpc/mpc-%{mpc_version}.tar.gz
+%source set gmp https://ftp.gnu.org/gnu/gmp/gmp-%{gmp_version}.tar.bz2
# GCC Common build script.
diff --git a/source-builder/config/gcc-4.4-1.cfg b/source-builder/config/gcc-4.4-1.cfg
index 077792a..ecfa651 100644
--- a/source-builder/config/gcc-4.4-1.cfg
+++ b/source-builder/config/gcc-4.4-1.cfg
@@ -25,9 +25,9 @@
diff --git a/source-builder/config/gcc-4.5-1.cfg b/source-builder/config/gcc-4.5-1.cfg
index 0039f68..acca717 100644
--- a/source-builder/config/gcc-4.5-1.cfg
+++ b/source-builder/config/gcc-4.5-1.cfg
@@ -21,9 +21,9 @@
diff --git a/source-builder/config/gcc-4.6-1.cfg b/source-builder/config/gcc-4.6-1.cfg
index da5c0ab..4eff844 100644
--- a/source-builder/config/gcc-4.6-1.cfg
+++ b/source-builder/config/gcc-4.6-1.cfg
@@ -25,9 +25,9 @@
diff --git a/source-builder/config/gcc-4.7-1.cfg b/source-builder/config/gcc-4.7-1.cfg
index 923ef12..25ac233 100644
--- a/source-builder/config/gcc-4.7-1.cfg
+++ b/source-builder/config/gcc-4.7-1.cfg
@@ -30,9 +30,9 @@
diff --git a/source-builder/config/gcc-4.8-1.cfg b/source-builder/config/gcc-4.8-1.cfg
index 56074b0..a090717 100644
--- a/source-builder/config/gcc-4.8-1.cfg
+++ b/source-builder/config/gcc-4.8-1.cfg
@@ -21,9 +21,9 @@
diff --git a/source-builder/config/gcc-4.9-1.cfg b/source-builder/config/gcc-4.9-1.cfg
index 7d6a440..c73850f 100644
--- a/source-builder/config/gcc-4.9-1.cfg
+++ b/source-builder/config/gcc-4.9-1.cfg
@@ -21,9 +21,9 @@
2.14.1
