lpc40xx BSPs do not build on master
Joel Sherrill
joel at rtems.org
Tue Jan 16 00:17:11 UTC 2018
On Jan 15, 2018 5:59 PM, "Chris Johns" <chrisj at rtems.org> wrote:
On 16/1/18 4:53 am, Joel Sherrill wrote:
> Does anyone else see this? If so, any idea what's up? It is failing quite
early
> in the build process.
I did not see this building Sebastian's no-preinstall branch for just
'tests':
https://lists.rtems.org/pipermail/build/2018-January/000330.html
Thanks.
I have most of the architectures and targets building with empty bsp_spec
files. I will try it with an unmodified tree.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180115/39ab6467/attachment.html>
